Part Number: MSP430FR5969
Other Parts Discussed in Thread: MSP430WARE,
Debugging expressions always read 0xFF (eg, the variables respective maximums depending on the data type).
The programs do not work as intended, as if the variables are in fact at their maximums.
Without debugging the whole thing seems to work as intended.
The whole thing used to work, suddenly does not work anymore. Updated to CCS 7.3, problem still remains.
Problem occures also with the simple examples directly out of tirex.
In this case msp430fr59xx_lpm3-5_02.c which always sets the LED to light up because ledstate always reads 0xFF while debugging.
Without debugging the LED seems to flash even though it should not - eg. the LED goes off while the MSP is in LPM3.5 which i think it should not.
(Thus it may be possible that it still reads 0xFF but goes only off while in LPM3.5 and on bootup again restores it to 0xFF...?)
Am I doing anything wrong? Any advice is welcome.
For your reference the lpm3.5 sample directly out of tirex:
/* --COPYRIGHT--,BSD_EX
* Copyright (c) 2012, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* MSP430 CODE EXAMPLE DISCLAIMER
* MSP430 code examples are self-contained low-level programs that typically
* demonstrate a single peripheral function or device feature in a highly
* concise manner. For this the code may rely on the device's power-on default
* register values and settings such as the clock configuration and care must
* be taken when combining code from several examples to avoid potential side
* effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
* for an API functional library-approach to peripheral configuration.
* --/COPYRIGHT--*/
// MSP430FR59xx Demo - RTC_B in LPM3.5 with 2 second wake-up interval
// Description: The RTC_B module is in counter mode with counter interrupt
// triggers every 2 seconds. The device will then enter LPM3.5 waiting for
// RT1PSIFG interrupt. Upon wake-up from LPMx.5, the device restores the
// previous state of P1.0 LED based on the ledState variable. It then toggles
// the P1.0 LED on the board and stores the LED state into FRAM memory 0x4400.
// This is a good example to demonstrate how to save the GPIO state before
// entering LPMx.5 and restoring the GPIO state upon wake-up.
// P4.6 is used as a heartbeat showcasing that the device is either waking
// up from a BOR reset or LPMx.5.
// ACLK = 32.768kHz, MCLK = SMCLK = DCO = ~1MHz
// MSP430FR59xx
// /|\| XIN|-
// | | | 32kHz
// --|RST XOUT|-
// | P1.0|--> LED
// | P4.6|--> Probe out/LED
// William Goh
// Texas Instruments Inc.
// January 2013
// Built with Code Composer Studio v5.5 and Embedded Workbench v5.60
#include <msp430.h>
void initBoard(void);
void initRtc(void);
void WakeUpLPM35(void);
// Stores the state of the LED in FRAM where this variable
// is not C-initialized during start-up. This allows
// certain variables to easily be restored and managed
// in a non-volatile memory with no flash charge-pump required.
// This allows faster start-up time.
#if defined(__TI_COMPILER_VERSION__)
#pragma NOINIT(ledState);
#pragma location=0x4400
unsigned char ledState;
#elif defined(__IAR_SYSTEMS_ICC__)
__persistent unsigned char ledState;
#else
// For other compilers, insert this variable into FRAM memory
#endif
int main(void)
WDTCTL = WDTPW | WDTHOLD; // Stop WDT
// Initialize board
initBoard(); // Regular init code for GPIO and CS
// Determine whether we are coming out of an LPMx.5 or a regular RESET.
if (SYSRSTIV == SYSRSTIV_LPM5WU)
// When woken up from LPM3.5, reinit
WakeUpLPM35(); // LPMx.5 wakeup specific init code
__enable_interrupt(); // The RTC interrupt should trigger now...
else
ledState = 0; // Initialize LED state variable
P1OUT = 0x00; // For initialize P1OUT to zero initially
initRtc(); // Regular init code for RTC_B
// Use P4.6 LED as a heart beat for to represent device restarted either
// from LPMx.5 or a complete power-up
P4OUT |= BIT6;
// Use Timer A for a short delay to blink P1.0 LED
TA0CCTL0 = CCIE; // TACCR0 interrupt enabled
TA0CCR0 = 1000;
TA0CTL = TASSEL__ACLK | MC__UP; // SMCLK, UP mode
__bis_SR_register(LPM3_bits | GIE);
TA0CTL &= ~(MC__UP); // Stop Timer
P4OUT &= ~BIT6; // Clear P4.6 LED
// Sequence to enter LPM3.5.
PMMCTL0_H = PMMPW_H; // Open PMM Registers for write
PMMCTL0_L |= PMMREGOFF; // and set PMMREGOFF
// Enter LPM3.5 mode with interrupts enabled. Note that this operation does
// not return. The LPM3.5 will exit through a RESET event, resulting in a
// re-start of the code.
__no_operation();
return 1;
// Port Configuration
// Restore P1.0 LED state before reset from a variable
// stored in FRAM
P1OUT = ledState;
P1DIR = 0xFF;
P2OUT = 0x00;
P2DIR = 0xFF;
P3OUT = 0x00;
P3DIR = 0xFF;
P4OUT = 0x00;
P4DIR = 0xFF;
PJOUT = 0x00;
PJSEL0 |= BIT4 | BIT5;
PJDIR = 0xFFFF;
// Disable the GPIO power-on default high-impedance mode to activate
// previously configured port settings
PM5CTL0 &= ~LOCKLPM5;
// Setup Clocks
CSCTL0_H = CSKEY >> 8; // Unlock CS registers
CSCTL1 = DCOFSEL_0; // Set DCO to 1MHz
CSCTL2 = SELA_0 | SELS_3 | SELM_3; // set ACLK = XT1; MCLK = DCO
CSCTL3 = DIVA_0 | DIVS_0 | DIVM_0; // Set all dividers to 1
CSCTL4 &= ~LFXTOFF; // Enable LFXT1
do
CSCTL5 &= ~LFXTOFFG; // Clear XT1 fault flag
SFRIFG1 &= ~OFIFG;
} while (SFRIFG1 & OFIFG); // Test oscillator fault flag
CSCTL0_H = 0; // Lock CS registers
void initRtc(void)
// Configure RTC_B
// Configure BCD mode, stop the RTC, and enable RTC
RTCCTL01 = RTCBCD | RTCHOLD | RTCTEV_0;
// Set the RTC second stage divider to 256
// RTC interrupts every 2 seconds
RTCPS1CTL = RT1IP_7 | RT1PSIE;
// Start RTC calendar mode
RTCCTL01 &= ~RTCHOLD;
// Re-configure / start RTC
RTCCTL01 |= RTCBCD | RTCHOLD | RTCTEV_0;
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=RTC_VECTOR
__interrupt void RTC_ISR(void)
#elif defined(__GNUC__)
void __attribute__ ((interrupt(RTC_VECTOR))) RTC_ISR (void)
#else
#error Compiler not supported!
#endif
switch (__even_in_range(RTCIV, RTCIV_RTCOFIFG))
case RTCIV_NONE: break;
case RTCIV_RTCRDYIFG: break;
case RTCIV_RTCTEVIFG: break;
case RTCIV_RTCAIFG: break;
case RTCIV_RT0PSIFG: break;
case RTCIV_RT1PSIFG:
// Toggle the LED on P1.0
P1OUT ^= BIT0;
// Store P1.0 output state to a variable
ledState = (P1OUT & BIT0);
break;
case RTCIV_RTCOFIFG: break;
// Timer A0 interrupt service routine
#pragma vector=TIMER0_A0_VECTOR
__interrupt void Timer_A(void)
void __attribute__ ((interrupt(TIMER0_A0_VECTOR))) Timer_A (void)
#else
#endif
__bic_SR_register_on_exit(LPM4_bits);
