I'm currently implement my HID interface on MSP430F5528. I detected an undocumented requirement on sendData_inBackground() and USBHID_sendData().
Both function require that the parameter dataBuf (or data) are present for a while after calling the function. Best is to use a static buffer.
As far as I detected copies USBHID_sendData the content in interrupt (DMA?) after being called. If you use a local object from stack (as I did) then some parts might be overwritten by succeding functions while USBHID_sendData is still copying (from a corrupt stack).
Guenther
