Part Number: MSP430G2553
Hi all,
I've found an example for the internal temperature sensor and it works just fine. the problem starts when I'm trying to use this code along side with other ADCs channel. meaning, I have to other channels that being used and all of the different in the settings is the ADC10SHT_3 of ADC10CTL0. in the other channels I use ADC10SHT_2. When Sampling and conversion is enabled in the other channels, the numbers of the temperature measurement is NOT OK and there's no changing at the output of the ADC under different temperatures. I did gave the ADC 30us and more to be accurate but still not good.
I believe that something is different with the internal temperature, I just don't know what.
pls help.
10X a lot
