Part Number: MSP432P401R
I have an unusual problem, after I initialize the clock frequency for my uC, it will randomly enter the ISRFault loop or NmiSR. I'm using an exemple of program for a e-ink pervasive display, but I can't test anything cause after I do the init for the microcontroller, I get this faulty interrupt and can't understand the why.
#include "conf_EPD.h"
/* Glossary of Acronyms
* GU = Global Update
* PU = Partial Update
* LUT = Look-up table, the array to define the parameters of driving waveform
* OTP = One Time Programming, the LUTs are pre-programmed in driver IC
* \brief define the timing controller type and size of EPD
* \note
* - eTC=external timing controller (driver IC)
* - iTC=internal timing controller */
// eTC
#define sz_eTC_144 0 //J7 Switches 0000 001x
#define sz_eTC_190 1 //J7 Switches 0000 000x
#define sz_eTC_200 2 //J7 Switches 0000 001x
#define sz_eTC_260 3 //J7 Switches 0000 000x
#define sz_eTC_271 4 //J7 Switches 0000 000x
// iTC
#define sz_iTC_215 5 //J7 Switches 1010 000x
#define sz_iTC_287 6 //J7 Switches 0101 010x
#define sz_iTC_420 7 //J7 Switches 0101 010x
* \brief define the EPD drivers with film material
* \note
* - BW=black and white colors, Aurora film
* - BWR=black, white and red colors, Spectra-red film
* - a=Aurora Ma (V230)
* - b=Aurora Mb (V231) */
#define dr_eTC_BWa 0
#define dr_eTC_BWb 1
#define dr_iTC_BWb 2
* \brief Configure the following two definitions by your connected display model */
#define USE_EPD_Type dr_eTC_BWb
#define USE_EPD_Size sz_eTC_190
#if (USE_EPD_Type==dr_eTC_BWa || USE_EPD_Type==dr_eTC_BWb)
#if(USE_EPD_Type==dr_eTC_BWa)
#define EPD_Type dr_eTC_G2_Aurora_Ma
#else
#define EPD_Type dr_eTC_G2_Aurora_Mb
#endif
#if(USE_EPD_Size==sz_eTC_144)
extern unsigned char const Image_eTC_144_01[];
extern unsigned char const Image_eTC_144_02[];
#define EPD_Size EPD_144_BW
#define Image1 (uint8_t *)&Image_eTC_144_01
#define Image2 (uint8_t *)&Image_eTC_144_02
#elif(USE_EPD_Size==sz_eTC_190)
extern unsigned char const Image_eTC_190_01[];
extern unsigned char const Image_eTC_190_02[];
#define EPD_Size EPD_190_BW
#define Image1 (uint8_t *)&Image_eTC_190_01
#define Image2 (uint8_t *)&Image_eTC_190_02
#elif(USE_EPD_Size==sz_eTC_200)
extern unsigned char const Image_eTC_200_01[];
extern unsigned char const Image_eTC_200_02[];
#define EPD_Size EPD_200_BW
#define Image1 (uint8_t *)&Image_eTC_200_01
#define Image2 (uint8_t *)&Image_eTC_200_02
#elif(USE_EPD_Size==sz_eTC_260)
extern unsigned char const Image_eTC_260_01[];
extern unsigned char const Image_eTC_260_02[];
#define EPD_Size EPD_260_BW
#define Image1 (uint8_t *)&Image_eTC_260_01
#define Image2 (uint8_t *)&Image_eTC_260_02
#elif(USE_EPD_Size==sz_eTC_271)
extern unsigned char const Image_eTC_271_01[];
extern unsigned char const Image_eTC_271_02[];
#define EPD_Size EPD_271_BW
#define Image1 (uint8_t *)&Image_eTC_271_01
#define Image2 (uint8_t *)&Image_eTC_271_02
#endif
#elif(USE_EPD_Type==dr_iTC_BWb)
#if(USE_EPD_Size==sz_iTC_215)
extern unsigned char const Image_iTC_215_01[];
extern unsigned char const Image_iTC_215_02[];
#define EPD_Type dr_iTC_215_Aurora_Mb
#define EPD_Size EPD_215_BW
#define Image1 (uint8_t *)&Image_iTC_215_01
#define Image2 (uint8_t *)&Image_iTC_215_02
#elif(USE_EPD_Size==sz_iTC_287)
extern unsigned char const Image_iTC_287_01[];
extern unsigned char const Image_iTC_287_02[];
#define EPD_Type dr_iTC_287_Aurora_Mb
#define EPD_Size EPD_287_BW
#define Image1 (uint8_t *)&Image_iTC_287_01
#define Image2 (uint8_t *)&Image_iTC_287_02
#elif(USE_EPD_Size==sz_iTC_420)
extern unsigned char const Image_iTC_420_01[];
extern unsigned char const Image_iTC_420_02[];
#define EPD_Type dr_iTC_420_Aurora_Mb
#define EPD_Size EPD_420_BW
#define Image1 (uint8_t *)&Image_iTC_420_01
#define Image2 (uint8_t *)&Image_iTC_420_02
#endif
#endif
void main(void)
system_init();
EPD_display_init();
Systick_Configuration();
//EPD_delay_ms(1000);
Set_AssignEPD_Drive(EPD_Type,EPD_Size,USE_Temperature_Sensor);
//EPD_display_GU_from_pointer(Image2,Image1,GU_Mode,true);
__delay_cycles(200000);
while(true)
EPD_delay_ms(5000);
EPD_display_GU_from_pointer(Image1,Image2,GU_Mode,true);
EPD_delay_ms(5000);
void system_init(void)
/* Halting the Watchdog */
MAP_WDT_A_holdTimer();
/* Enabling FPU for DCO Frequency calculation */
MAP_FPU_enableModule();
/* Setting DCO to 48MHz (upping Vcore) */
MAP_PCM_setCoreVoltageLevel(PCM_VCORE1);
/* Setting the DCO Frequency to a non-standard 48MHz */
//MAP_CS_setDCOFrequency(48000000);
CS_setDCOCenteredFrequency(CS_DCO_FREQUENCY_48);
MAP_Interrupt_enableMaster();
//MAP_PCM_setCoreVoltageLevel(PCM_VCORE1);
//CS_setDCOCenteredFrequency(CS_DCO_FREQUENCY_48);
The code will enter the faulty interrupt function at random after the init of the DCO Frenquency.
Thanks.
André
