Practical Sleep Modes
Other Parts Discussed in Thread: MSP430F5515
What's the most power efficient way to go into a low power mode (sleep) and be able to wake up periodically without any external event? Assume I have no responsibility during sleep mode besides staying asleep and waking up periodically. What is the current draw I expect while sleeping in this way? I'm using an MSP430F5515, but if there is some capability that a different MSP430 has for this type of operation I'd be interested in hearing that too.
  • You can go to LPM3 and use WDT or RTC sourced by VLO to wake it up. Current consumption is down to a few uA. See:
    "Low-Power Mode Supply Currents (Into VCC) Excluding External Current"
    on page 51 of the data-sheet SLAS590D –OCTOBER 2009–REVISED APRIL 2010
  • In addition to OYC response, you can also divide the system clock down from the VLO.
    You can probably get to 500na or less with running from the VLO and a divided down system clock. I have boards running on my bench at 600nA, and that is running from an external 32khz crystal which requires some additiona currents.
    Brief summary:
    LPM3 + VLO + DIVIDED system clock = Lowest power mode and still have internal wake up.
    -Jason
  • @Jason,
    Thanks, that's kind of what I was hoping to hear, and it makes sense to me at a high level. Would you be willing to provide a minimal code example that achieves this current consumption during sleep and periodically wakes up to say toggle a pin, so that I might be able to independently verify your results?
    I would recommend posting the code to something like pastebin.com and providing a link to it here as the forum editor isn't the greatest for formatting code.
    Kind Regards,
    Vic
