MSP430F2013: Need help understanding the function of negative analog input
Part Number: MSP430F2013
Hello everyone
My question is stated in the title, I have recently came across this MCU in search for a high bit# ADC that has enough resolution for our project, we found this MCU and is not sure of the negative analog input because we never used this type of adc, so what I want to get cleared is that does this negative analog input take negative value from an amplifer, because if that is the case than we can skip on inverting the negative output of amps. Another concern is what is the common clock frequency to use on this MCU because the sample rate we want is around 10 sample per second, so probably have to use the sample rate command for sample trigger.
Kind regards
Richard
