Part Number: MSP432P401R
Is ir possible to cut off MSP432 Launchpad at Jumper Block Isolation Line without any issues. What will be the recommended setup for programming it.
Sudhir Gupta
I am interested in using the Launchpad for a target application, including a robot controller. It is easier to design a smaller pcb that will mate with launchpad minus XDS emulator. Does Ti have any policy as not to allow the launchpads be used in a final application?
Sudhir Gupta
Sudhir,
You can view the terms for TI's EVMs here: http://www.ti.com/lit/ml/sszz027n/sszz027n.pdf
These terms do not allow our EVMs to be used in final applications. This is because the EVMs are not tested or certified for end applications and do not undergo the same quality processes that our semiconductor products go through.
You can detach the XDS portion of the MSP432 LaunchPad using the debug jumper block (J101) for testing purposes. I can’t guarantee that if you physically cut off the XDS110 portion of the EVM it will work, but there aren’t any signals that pass over this barrier so it may still work. I would recommend looking at the schematics and layout for the LaunchPad here: http://software-dl.ti.com/msp430/msp430_public_sw/mcu/msp430/MSP-EXP432P401R/latest/index_FDS.html If you want to reprogram the MSP432 device, you can use the 10-pin ARM header (J8) with an external debugger or another XDS110 emulator.
Hi Daniel,
Thank you for the long awaited reply. I shall try separating the MSP432 board. I have a few questions and comments about product usage and these may best be answered by your legal dept.
Looking forward to Ti reply.
Kind Regards,
Sudhir Gupta
