MSP430F6736A: EVM430F6736
Part Number: MSP430F6736A
Other Parts Discussed in Thread: MSP-FET, MSP430F6736
Hi all,
I have been using the EVM430-F6736
Now, i pretend using only the msp430f6736A's microcontroller whith the academic objective (i am a Master's student) of programming the micro for doing a a system similar to the e-meter but much more simply. I pretend only doing measures of current, voltage, active power, reactive power and energies, power factor and frequency for a single phase. Not much more at first. I have the idea of my program, with similar files of the slaa517's files (www.ti.com/lit/zip/slaa517). The next step is reprogramming the EVM430F6736 (www.ti.com/.../slaa517e.pdf) with IAR software.
Some weeks ago i read there are some problems with new versions of IAR software (i read this post https://e2e.ti.com/support/microcontrollers/msp430/f/166/t/587616?tisearch=e2e-sitesearch&keymatch=emeter-setup.c) . I thought using IAR 5.60 and my plans were programm the MSP430F6736 with that version. The problem is that when i bought the MSP-FET Flash Emulation Tool (www.ti.com/.../MSP-FET) for programming the MSP430F6736A i discovered that i have to use a new IAR version because it doesnt admite IAR 5.60 (i discovered here https://e2e.ti.com/support/microcontrollers/msp430/f/166/t/614826 ). First it says you to download an old version of IAR and then a new one, which is contradictory i think, but that's what it says ...
I downloaded the IAR 7.11.3 and i rebuilded the projects (as it says at page 18/32 www.ti.com/.../slaa517e.pdf ). When i do that i have problems (when i rebuild emeter-toolkit-6736.ewp i have a lot of mistakes that i hadn't with IAR 5.60 and when i rebuild emeter-6736.ewp the program closes). How can i solve my problem?
The problem with emeter-6736.ewp is this:
Building configuration: emeter-toolkit-6733 - Debug
Updating build tree...
54 file(s) deleted.
accum48.s43
bin2bcd16.s43
bin2bcd32.s43
dc_filter16.s43
dc_filter24.s43
imul16.s43
isqrt16.s43
mul48_32_16.s43
mul48u_32_16.s43
q1_15_mul.s43
q1_15_mulq.s43
q1_15_mulr.s43
shift48.s43
sqac48_16.s43
sqac64_24.s43
debounce.c
Fatal Error[Pe035]: #error directive: Compiler not recognised. C:\Users\Miguel\Desktop\slaa517_nuevo\slaa517\Source\emeter-toolkit\isr_compat.h 82
Error while running C/C++ Compiler
dds.c
div48.c
div_sh48.c
flash_replace16.c
flash_memcpy.c
flash_replace32.c
flash_clr.c
flash_write_int16.c
flash_secure.c
flash_write_int8.c
flash_write_int32.c
host_dec32.c
hex2ASCII.c
host_dec16.c
host_char.c
host_hex32.c
host_hex16.c
host_decu32.c
host_decu16.c
isqrt32i.c
host_str.c
isqrt32.c
iiceeprom.c
isqrt64i.c
isqrt64.c
LCD-module.c
LCD-internal.c
LCD-sim.c
LCDdec16.c
LCDdec32.c
LCDdecu16.c
mul48.c
LCDdecu32.c
rand16.c
rtc.c
setdco.c
rtc_data.c
Total number of errors: 38
Total number of warnings: 20
Thanks in advance!
    To resolve this compiler error, you'll need to change the upper version limit to be greater than the version you're using. For example, if you're using v7.x.y, you'll need to change the value (highlighted below in yellow) from 700 (or whatever is there by default) to 800.
    Also, we'll be releasing the new Energy Measurement Design Center and Library shortly, which features CCS support.
    James
    MSP Customer Applications
  • Hi James,
    You have resolved my first problem, thanks a lot!
    But i am having the other problem too... When i charge emeter-6733.ewp (from emeter-ng) the IAR programm closes. It doesnt say what error it is, only appears this at the end:
    I try to charge the file and rebuild again and again and the result is the same, do you know why?
    Thanks in advance!
  • This seems to be an issue with the newest version of IAR. For now, you may want to go back to an older version until IAR fixes this issue. The user in the following thread seems to be having the same issue.
    e2e.ti.com/.../2487251
    James
  • Hi James,
    At first i have solved some of my problems, but there are any more now (Thanks by solve them).
    Now i have downloaded the IAR 6.50.1 and my problem now is this when i rebuild the emeter-6733.ewp (no problem now with emeter-toolkit-6736.ewp, only warnings):
    Building configuration: emeter-6733 - Debug
    Failed to delete C:\Users\Miguel\Desktop\slaa517_nuevooo\SLAA517\Source\emeter-ng\Debug\Obj\emeter-background.pbi
    43 file(s) deleted.
    emeter-basic-display.c
    emeter-dlt645.c
    emeter-communication.c
    emeter-background.c
    emeter-main.c
    emeter-iiceeprom.c
    emeter-foreground.c
    emeter-fir-table.c
    emeter-phase-corrections.c
    emeter-multirate.c
    emeter-setup.c
    emeter-rtc.c
    Warning[Pe550]: variable "i" was set but never used C:\Users\Miguel\Desktop\slaa517_nuevooo\SLAA517\Source\emeter-ng\emeter-rtc.c 97
    hal_pmm.c
    hal_UCS.c
    Linking
    Fatal Error[e89]: Too much object code produced (more than 0x2000 bytes) for this package
    Error while running Linker
    Total number of errors: 1
    Total number of warnings: 1
    I have probed with both free licenses' number ( Restrictions to the 30-day time-limited evaluation and Restrictions to the Kickstart, size-limited evaluation). I don't know why this issue appears in both cases, do you know?
    Thanks in advance
