CCS/MSP430FR2433: How to locate 1KByte variable on FRAM starting 0xC400~
Part Number: MSP430FR2433
Hello Experts,
We would like to use FRAM as SRAM since there are 1KB variable data and not enough for SRAM. CPU frequency is lower than 8MHz so access performance would not matter.
Trying several #pragma but not succeed.
Could you please provide any sample code for this use-case?
Uchikoshi
  • Hi Uchikoshi,
    You could define a section in FRAM for your variables, modify the lnk_msp430fr2433.cmd, and then use the #pragma DATA_SECTION
    step 1 -- define the section .textB in GROUP(READ_WRITE_MEMORY)
    /* Specify the sections allocation into memory                              */
    SECTIONS
        GROUP(ALL_FRAM)
              .TI.persistent : {}                /* For #pragma persistent            */
              .textB      : {}
           GROUP(READ_ONLY_MEMORY)
              .cinit      : {}                   /* Initialization tables             */
              .pinit      : {}                   /* C++ constructor tables            */
              .binit      : {}                   /* Boot-time Initialization tables   */
              .init_array : {}                   /* C++ constructor tables            */
              .mspabi.exidx : {}                 /* C++ constructor tables            */
              .mspabi.extab : {}                 /* C++ constructor tables            */
              .const      : {}                   /* Constant data                     */
           GROUP(EXECUTABLE_MEMORY)
              .textA      : {}                   /* I2C BSL Code */
              .text      : {}
        } > FRAM
    step 2 -- link you data into the .textB section by #pragma DATA_SECTION. Guides could be found here:
    http://downloads.ti.com/docs/esd/SLAU132K/#SLAU132K_HTML/msp430_c_c_language_implementation.html#STDZ0559962
     (page48 B4) www.ti.com/.../slau157ap.pdf
