Part Number: MSP430F5342
I have found problems with some msp430f5342 microcontroller when I need to erase and write main flash memory from RAM. I applied routine described in SLAU208Q document but not all devices terminate erase procedure correctly. In some case the cpu stop working and it doesn't restart work also I use the debugger. Please can you show me some code example in order to describe the correct procedure when I need to start an erase procedure from RAM and the following procedure from RAM.
