Thanks, this was very helpful. I am trying to read data from (MAX31855 ), so I connected the MAX31855 pins, SCK to pin 3.5, CS to pin 3.6, SO to pin 3.7 of the MSP432p401R EVM. I also changed in the example code as follows: 1. removed the value defined for dummyTx. 2. changed uint8_t rxBuffer[4]; as I need to read the buffer more to get data from MAX31855. When I run the code I see the interrupts happen as they should, thanks to your explanation. But the value in the RX buffer is not correct. I know my MAX31855 is working because I can test it just when I use a normal interrupt to read SPI without the DMA. I checked it with another code that I know it works.
This is the code with my changes:
/* --COPYRIGHT--,BSD,BSD * Copyright (c) 2017, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * --/COPYRIGHT--*/ /******************************************************************************* * MSP432 DMA - Scatter-Gather between eUSCIB2 memory and eUSCIB1 * * Description: In this code example, two software initiated DMA transfers are * setup and executed. The scatter-gather transfers initiated from software * perform two tasks. The first task is to read three bytes from the eUSCIB2 * SPI and the second task is to transmit two bytes from the eUSCIB1 SPI. * In addition to the SPI communication the tasks also manage the chip select * via the port registers. * During the first interrupt a simple computation is performed to transfer * the information read to the information transmitted. * * MSP432P401 * ------------------ * /|\| | * | | | * --|RST P3.0|--> CS * | P3.5(eUSCIB2)|--> CLK --- connect to SCK of MAX31855 * | P3.6|--> SIMO --- connect to CS of MAX31855 * | P3.7|<-- SOMI --- connect to SO of MAX431855 * | | * | P6.1|--> CS * | P6.3(eUSCIB1)|--> CLK * | P6.4|--> SIMO * | P6.5|<-- SOMI * ******************************************************************************/ #include <stdint.h> #include <string.h> #include <stdbool.h> #include <ti/devices/msp432p4xx/driverlib/driverlib.h> #include <ti/devices/msp432p4xx/inc/msp.h> #define RX_TASKS 9 #define TX_TASKS 7 /* SPI Configuration Parameter */ const eUSCI_SPI_MasterConfig spiMasterConfig_B2 = { EUSCI_B_SPI_CLOCKSOURCE_SMCLK, 3000000, 1000000, EUSCI_B_SPI_MSB_FIRST, EUSCI_B_SPI_PHASE_DATA_CAPTURED_ONFIRST_CHANGED_ON_NEXT, EUSCI_B_SPI_CLOCKPOLARITY_INACTIVITY_HIGH, EUSCI_B_SPI_3PIN }; /* SPI Configuration Parameter */ const eUSCI_SPI_MasterConfig spiMasterConfig_B1 = { EUSCI_B_SPI_CLOCKSOURCE_SMCLK, 3000000, 1000000, EUSCI_B_SPI_MSB_FIRST, EUSCI_B_SPI_PHASE_DATA_CAPTURED_ONFIRST_CHANGED_ON_NEXT, EUSCI_B_SPI_CLOCKPOLARITY_INACTIVITY_HIGH, EUSCI_B_SPI_3PIN }; /* DMA Control Table */ #if defined(__TI_COMPILER_VERSION__) #pragma DATA_ALIGN(MSP_EXP432P401RLP_DMAControlTable, 1024) #elif defined(__IAR_SYSTEMS_ICC__) #pragma data_alignment=1024 #elif defined(__GNUC__) __attribute__ ((aligned (1024))) #elif defined(__CC_ARM) __align(1024) #endif static DMA_ControlTable MSP_EXP432P401RLP_DMAControlTable[16]; // 8 primary and 8 alternate uint8_t outputLow = 0; uint8_t ADC_CS = BIT0; /* P3.0 is Chip Select */ uint8_t DAC_CS = BIT1; /* P6.1 is Chip Select */ uint8_t dummyTX = 0; uint8_t dummyRX; uint8_t rxBuffer[4]; uint8_t txBuffer[2]; /* * ADC_DMA Sequence: This sequence sets CS, reads data, and clears CS * The 'MEM' instructions are automatic while the 'PER' requires a * peripheral trigger, which is the EUSCI_B2_RX. The trigger is configured * before the sequence is started. */ DMA_ControlTable spiAdcDmaSeq[RX_TASKS] = { /* Task1, Dummy read RX buffer to clear IFG */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &EUSCI_B2_SPI->RXBUF, UDMA_DST_INC_NONE, &dummyRX, UDMA_ARB_4, (UDMA_MODE_MEM_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* Task2, Clear Chip select */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &outputLow, UDMA_DST_INC_NONE, &P3->OUT, UDMA_ARB_4, (UDMA_MODE_MEM_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* Task3, load TX buffer to initiate SPI */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &dummyTX, UDMA_DST_INC_NONE, &EUSCI_B2_SPI->TXBUF, UDMA_ARB_4, (UDMA_MODE_PER_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* Task4, read RX buffer to clear IFG */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &EUSCI_B2_SPI->RXBUF, UDMA_DST_INC_NONE, &rxBuffer[0], UDMA_ARB_4, (UDMA_MODE_MEM_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* Task5, load TX buffer to initiate SPI */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &dummyTX, UDMA_DST_INC_NONE, &EUSCI_B2_SPI->TXBUF, UDMA_ARB_4, (UDMA_MODE_PER_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* Task6, read RX buffer to initiate SPI */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &EUSCI_B2_SPI->RXBUF, UDMA_DST_INC_NONE, &rxBuffer[1], UDMA_ARB_4, (UDMA_MODE_MEM_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* Task7, load TX buffer to initiate SPI */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &dummyTX, UDMA_DST_INC_NONE, &EUSCI_B2_SPI->TXBUF, UDMA_ARB_4, (UDMA_MODE_PER_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* Task8, read RX buffer to initiate SPI */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &EUSCI_B2_SPI->RXBUF, UDMA_DST_INC_NONE, &rxBuffer[2], UDMA_ARB_4, (UDMA_MODE_MEM_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* Task9, load TX buffer to initiate SPI */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &dummyTX, UDMA_DST_INC_NONE, &EUSCI_B2_SPI->TXBUF, UDMA_ARB_4, (UDMA_MODE_PER_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* Task10, read RX buffer to initiate SPI */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &EUSCI_B2_SPI->RXBUF, UDMA_DST_INC_NONE, &rxBuffer[3], UDMA_ARB_4, (UDMA_MODE_MEM_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* Task 11, set GPIO, chip select */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &ADC_CS, UDMA_DST_INC_NONE, &P3->OUT, UDMA_ARB_4, UDMA_MODE_BASIC) }; /* * DAC_DMA Sequence: This sequence sets CS, reads data, and clears CS * The 'MEM' instructions are automatic while the 'PER' requires a * peripheral trigger, which is the EUSCI_B1_TX. The trigger is configured * before the sequence is started. */ DMA_ControlTable spiDacDmaSeq[TX_TASKS] = { /* Task1, Dummy read RX buffer to clear IFG */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &EUSCI_B1_SPI->RXBUF, UDMA_DST_INC_NONE, &dummyRX, UDMA_ARB_4, (UDMA_MODE_MEM_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* Task2, Clear Chip select P6.2 */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &outputLow, UDMA_DST_INC_NONE, &P6->OUT, UDMA_ARB_4, (UDMA_MODE_MEM_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* Task3, load TX buffer to initiate SPI */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &txBuffer[0], UDMA_DST_INC_NONE, &EUSCI_B1_SPI->TXBUF, UDMA_ARB_4, (UDMA_MODE_PER_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* Task4, Dummy read RX buffer to clear IFG, wait for RXIFG trigger */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &EUSCI_B1_SPI->RXBUF, UDMA_DST_INC_NONE, &dummyRX, UDMA_ARB_4, (UDMA_MODE_MEM_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* Task 5, load TX buffer to initiate SPI */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &txBuffer[1], UDMA_DST_INC_NONE, &EUSCI_B1_SPI->TXBUF, UDMA_ARB_4, (UDMA_MODE_PER_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* * Task 6, Dummy read RX buffer to clear IFG * This delay ensures that the chip select happens after the last byte is transmitted */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &EUSCI_B1_SPI->RXBUF, UDMA_DST_INC_NONE, &dummyRX, UDMA_ARB_4, (UDMA_MODE_MEM_SCATTER_GATHER+UDMA_MODE_ALT_SELECT)), /* Task 7, set GPIO, chip select */ DMA_TaskStructEntry(1, UDMA_SIZE_8, UDMA_SRC_INC_NONE, &DAC_CS, UDMA_DST_INC_NONE, &P6->OUT, UDMA_ARB_4, UDMA_MODE_BASIC) }; void main(void) { /* Halt watchdog timer */ MAP_WDT_A_holdTimer(); /* * Configuring P1.1 as an input and enabling interrupts */ MAP_GPIO_setAsInputPinWithPullUpResistor(GPIO_PORT_P1, GPIO_PIN1); MAP_GPIO_clearInterruptFlag(GPIO_PORT_P1, GPIO_PIN1); MAP_GPIO_enableInterrupt(GPIO_PORT_P1, GPIO_PIN1); MAP_Interrupt_enableInterrupt(INT_PORT1); /* * DAC SPI * Configure CLK, MOSI & MISO for SPI0 (EUSCI_B1) * P6.3 UCB1CLK * P6.4 SIMO * P6.5 SOMI * */ MAP_GPIO_setAsPeripheralModuleFunctionOutputPin(GPIO_PORT_P6, GPIO_PIN3 | GPIO_PIN4, GPIO_PRIMARY_MODULE_FUNCTION); MAP_GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P6, GPIO_PIN5, GPIO_PRIMARY_MODULE_FUNCTION); /* * ADC SPI * Configure CLK, MOSI & MISO for SPI0 (EUSCI_B2) * 3.5 CLK * 3.6 SIMO * 3.7 SOMI */ MAP_GPIO_setAsPeripheralModuleFunctionOutputPin(GPIO_PORT_P3, GPIO_PIN5 | GPIO_PIN6, GPIO_PRIMARY_MODULE_FUNCTION); MAP_GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P3, GPIO_PIN7, GPIO_PRIMARY_MODULE_FUNCTION); /* Configure CS pin P3.0 */ P3->OUT |= BIT0; P3->DIR |= BIT0; /* Configure CS pin P6.1 */ P6->OUT |= BIT1; P6->DIR |= BIT1; /* Debug Port P1.0 */ P1->DIR |= BIT0; /* * LDO, Vcore0 (default) * 24Mhz MCLK, * 3Mhz SMCLK */ MAP_CS_setDCOCenteredFrequency(CS_DCO_FREQUENCY_24); MAP_CS_initClockSignal(CS_MCLK,CS_DCOCLK_SELECT,CS_CLOCK_DIVIDER_1); MAP_CS_initClockSignal(CS_SMCLK,CS_DCOCLK_SELECT,CS_CLOCK_DIVIDER_8); /* Configuring SPI module */ MAP_SPI_initMaster(EUSCI_B2_BASE, &spiMasterConfig_B2); MAP_SPI_initMaster(EUSCI_B1_BASE, &spiMasterConfig_B1); /* Enable the SPI module */ MAP_SPI_enableModule(EUSCI_B2_BASE); MAP_SPI_enableModule(EUSCI_B1_BASE); MAP_SPI_clearInterruptFlag(EUSCI_B2_BASE,EUSCI_B_SPI_RECEIVE_INTERRUPT); MAP_SPI_clearInterruptFlag(EUSCI_B1_BASE,EUSCI_B_SPI_RECEIVE_INTERRUPT); /* Configuring DMA module */ MAP_DMA_enableModule(); MAP_DMA_setControlBase(MSP_EXP432P401RLP_DMAControlTable); /* * Assign DMA triggers * channel 2 to EUSCI_B1_TX0 * channel 5 to EUSCI_B2_RX0 */ MAP_DMA_assignChannel(DMA_CH3_EUSCIB1RX0); MAP_DMA_assignChannel(DMA_CH5_EUSCIB2RX0); /* Enable DMA interrupt */ /* * Debug * Change to Channel1 eUSCI_B2_RX2 */ MAP_DMA_assignInterrupt(INT_DMA_INT1, 5); /* Channel 5 is the ADC (RX) */ MAP_DMA_assignInterrupt(INT_DMA_INT2, 3); /* Channel 3 is the DAC (TX) */ while(1) { MAP_PCM_gotoLPM0(); } } /* Completion interrupt for DMA */ void DMA_INT1_IRQHandler(void) { MAP_DMA_disableChannel(5); MAP_DMA_disableInterrupt(INT_DMA_INT1); MAP_Interrupt_disableInterrupt(INT_DMA_INT1); MAP_SPI_clearInterruptFlag(EUSCI_B2_BASE,EUSCI_B_IFG_RXIFG0); MAP_DMA_clearInterruptFlag(5); /* * Translate ADC data to DAC data * 0 -> MSB (transmit first) * 1 -> LSB (transmit second) */ txBuffer[0] = (rxBuffer[0] & 0x3) << 6; txBuffer[0] |= (rxBuffer[1] & 0xFC) >> 2; txBuffer[1] = (rxBuffer[1] & 0x3) << 6; txBuffer[1] |= (rxBuffer[2] & 0xFC) >> 2; MAP_SPI_clearInterruptFlag(EUSCI_B1_BASE,EUSCI_B_SPI_RECEIVE_INTERRUPT); MAP_DMA_setChannelScatterGather(DMA_CH3_EUSCIB1RX0,TX_TASKS,(void*)&spiDacDmaSeq[0],0); MAP_DMA_clearInterruptFlag(DMA_CH3_EUSCIB1RX0 & 0x0F); /* Assigning/Enabling Interrupts */ MAP_DMA_enableInterrupt(INT_DMA_INT2); MAP_Interrupt_enableInterrupt(INT_DMA_INT2); MAP_DMA_enableChannel(3); EUSCI_B1_SPI->IFG |= EUSCI_B_IFG_RXIFG0; } void DMA_INT2_IRQHandler(void) { MAP_DMA_disableChannel(3); MAP_DMA_disableInterrupt(INT_DMA_INT2); MAP_Interrupt_disableInterrupt(INT_DMA_INT2); MAP_SPI_clearInterruptFlag(EUSCI_B1_BASE,EUSCI_B_IFG_RXIFG0); MAP_DMA_clearInterruptFlag(3); P1->OUT ^= BIT0; } void PORT1_IRQHandler(void) { uint32_t status; status = MAP_GPIO_getEnabledInterruptStatus(GPIO_PORT_P1); MAP_GPIO_clearInterruptFlag(GPIO_PORT_P1, status); /* Toggling the output on the LED */ if(status & GPIO_PIN1) { rxBuffer[0] = 1; rxBuffer[1] = 2; rxBuffer[2] = 3; rxBuffer[3] = 4; txBuffer[0] = 5; txBuffer[1] = 6; /* * Start SPI read */ while(status & GPIO_PIN1) { status = MAP_GPIO_getEnabledInterruptStatus(GPIO_PORT_P1); MAP_GPIO_clearInterruptFlag(GPIO_PORT_P1, status); } /* * Peripheral trigger. Memory Scatter Gather */ MAP_DMA_setChannelScatterGather(DMA_CH5_EUSCIB2RX0,RX_TASKS,(void*)&spiAdcDmaSeq[0],0); MAP_DMA_clearInterruptFlag(DMA_CH5_EUSCIB2RX0 & 0x0F); /* Assigning/Enabling Interrupts */ MAP_DMA_enableInterrupt(INT_DMA_INT1); MAP_Interrupt_enableInterrupt(INT_DMA_INT1); MAP_DMA_enableChannel(5); /* * The DMA channel5 is set to trigger off of theEUSCIB0RX IFG. This * did not really happen but is forced manually to start the * scatter-gather sequence. Because the setting is 'memory' * scatter-gather all triggers (transitions) from primary to * auxiliary actions will be automatic. The auxiliary action triggers * are defined in the task list. */ EUSCI_B2_SPI->IFG |= EUSCI_B_IFG_RXIFG0; } }
