I used Captivate design center (CDC) to generate CCS codes for my sensor board which has MSP430FR2532. I defined a self-capacitance sensor for one of the CAP pins and the pin is connected to an electrode. I am monitoring the results in the serial port.
The sensor works great and the serial port shows numbers ranged from 20 to ~ 500.
Can you please tell me how I can calibrate the sensor? in other words, what should be the real capacitance values of the represented numbers in the serial port? what is the expected range of capacitance of my sensor?
For calibration, can I choose five capacitors with different values, for example, and connect the electrode to one capacitor pin while the other pin is grounded? So I can find the representative values.
Aref
