MSP430G2553: MSP430G2553: UNIQUE ID
Part Number: MSP430G2553
Hi
I would like to know any unique serial number for each device(MSP430G2553) manufactured, if not so is there any approach to  embed the serial number or unique ID for each device ? it should not erasable or programmable?
Kind Regards,
satya
  • Hi Satya,
    Sorry there is no unique serial number programmed to the G2553 device.
    Lukas
  • Hi Satya,
    as far as I understood you, you're looking for a unique ID for each of the different dies that are manufactured, depicting the lot, position on the wafer etc.
    We provide this kind of ID in some of our device families, such as the MSP430F5xx, but unfortunately not for the MSP430G2553 class of devices.
    In case your looking for it on other devices, too, this information can be found in the device datasheet, section "Device Descriptors" where there is a table including the "Die Record".
    I'm sorry I can't help your with regards to the MSP430G2553 though.
    Britta
    Is it possible with MSP-GANG programmer to incorporate the serial number for device(MSP430G2553)? if any method is there to incorporate serial number please because we are developing  security project to identify each device.
    if any body is done previously.please cooperate in this regard.
    kind regards,
    satya
  • Hi Satya,
    we might be talking about different things here.
    Could you be specific about
    Are you talking about putting the device name, i.e. MSP430G2553, into the memory?
    As said before per default the MSP430G2553 does not contain the unique device ID and there is also no way for you to program it as we can't provide you the unique IDs of the MSP430G2553 devices we're shipping.
    Please let me know in case you are actually trying to do something different than I understood.
    Britta
  • Dear Britta
    Thanks for your response. shall we use INFO memory for serial number incorporation. how can write into this memory
    kind regards,
    satya
  • Hi Satya,
    one option could be to write the serial number into segment A of the information memory.
    You'll find the description of how to do so in the Flash Controller section of the MSP430x2xx Family User's Guide.
    The reason why Segment A could be preferred over other segments is that it is locked separately from all other segments and thus offer some extra protection against unintended writes. Please check the documentation for the exact details.
    Britta
  • Hi Satya,
    as I didn't hear back from you on this thread I assume that your issue has been solved with my answer.
    Please verify the given answer or otherwise reply back to further describe your issue. Note that I will close this thread in case I don't hear back anymore.
    Britta
