MSP430F2013: Programming connector part number
Part Number: MSP430F2013
Other Parts Discussed in Thread: MSP-FET
Please suggest me programming connector for below attached MSP430F2013 Part reference J2 in Schematics.
Ashok
  • Hi Ashok,
    Thanks for your post! Did this schematic snippet come from one of our designs? If so, could you please share the link with me?
    The 10-pin J2 connector shown in the schematic snippet above is used for JTAG programming. If you're working on a custom design, you may want to use a smaller connector/pads to save space on your board. If space isn't a concern, then I would actually recommend using our 14-pin connector that's compatible with our MSP-FET debugger. To answer your question, I searched through our MSP430 Hardware Tools User's Guide and found a part number for a 10-pin connector from one of our target socket boards.
    HRP10H-ND
    They don't seem to be in stock at Digi-key, but you may find them at other vendors. I hope this helps!
    James
  • Hi james,
    Thanks for the information.its our custom design and placement is not an issue but connector height should below 6mm.
    can u suggest me 14pin  programming connector partnumber please.
    Ashok
  • I found it in the MSP430 Hardware Tools User's Guide by searching for "14-pin". I'm not sure about the height.
    HRP14H-ND
    I've seen where some designers with space constraints (either area or height) will use the legged Tag-Connect JTAG connectors with the MSP-FET.
    James
