Part Number: MSP430FR2311
I'm attempting to implement i2c slave on the MSP430. I found a register example called "msp430fr231x_eusci_i2C_standard_slave.c". I am able to perform a read operation and a write operation with this code as long as the command codes are different. This code basically assumes registers are only read or write. Not read and write because when you start a read sequence that contains a repeat start, the device fails. One way to work around this is to create two commands that point to the same register, but one handles read and one handles a write. This seems inefficient, but since I control both ends of the link, I suppose it is possible.
What I am hung up on is how to handle this repeat start case. Do I need to detect a new start condition in the interrupt routine? One issue I've noticed is that when the command is a CMD_TYPE_X_MASTER it goes and disables the RX interrupt which pretty much leaves the whole things in a bad state because the MSP430 thinks its going to start transmitting data, when really the master is going to send it an address again. At this point communication is pretty much done once this happens. I've looked all over the internet for any clues on how to do this and it appears it isn't done very often. Any help would be greatly appreciated.
// MSP430FR231x Demo - eUSCI_B0, SPI 3-Wire Master Incremented Data
// Description: SPI master talks to SPI slave using 3-wire mode. Incrementing
// data is sent by the master starting at 0x01. Received data is expected to
// be same as the previous transmission TXData = RXData-1.
// USCI RX ISR is used to handle communication with the CPU, normally in LPM0.
// ACLK = 32.768kHz, MCLK = SMCLK = DCO ~1MHz. BRCLK = ACLK/2
// MSP430FR2311 4.7k |
// ----------------- | 4.7k
// /|\ | P1.3|---+---|-- I2C Clock (UCB0SCL)
// ---|RST P1.2|-------+-- I2C Data (UCB0SDA)
// Nima Eskandari and Ryan Meredith
// Texas Instruments Inc.
// February 2018
// Built with CCS V7.3
#include <msp430.h>
#include <stdint.h>
// Pin Config ******************************************************************
#define LED0_OUT P1OUT
#define LED0_DIR P1DIR
#define LED0_PIN BIT0
#define LED1_OUT P2OUT
#define LED1_DIR P2DIR
#define LED1_PIN BIT0
// Example Commands ************************************************************
#define SLAVE_ADDR 0x48
/* CMD_TYPE_X_SLAVE are example commands the master sends to the slave.
* The slave will send example SlaveTypeX buffers in response.
* CMD_TYPE_X_MASTER are example commands the master sends to the slave.
* The slave will initialize itself to receive MasterTypeX example buffers.
#define CMD_TYPE_0_SLAVE 0
#define CMD_TYPE_1_SLAVE 1
#define CMD_TYPE_2_SLAVE 2
#define CMD_TYPE_0_MASTER 3
#define CMD_TYPE_1_MASTER 4
#define CMD_TYPE_2_MASTER 5
#define TYPE_0_LENGTH 1
#define TYPE_1_LENGTH 2
#define TYPE_2_LENGTH 6
#define MAX_BUFFER_SIZE 20
/* MasterTypeX are example buffers initialized in the master, they will be
* sent by the master to the slave.
* SlaveTypeX are example buffers initialized in the slave, they will be
* sent by the slave to the master.
uint8_t MasterType2 [TYPE_2_LENGTH] = {0};
uint8_t MasterType1 [TYPE_1_LENGTH] = { 0, 0};
uint8_t MasterType0 [TYPE_0_LENGTH] = { 0};
uint8_t SlaveType2 [TYPE_2_LENGTH] = {'A', 'B', 'C', 'D', '1', '2'};
uint8_t SlaveType1 [TYPE_1_LENGTH] = {15, 16};
uint8_t SlaveType0 [TYPE_0_LENGTH] = {12};
// General I2C State Machine ***************************************************
typedef enum I2C_ModeEnum{
IDLE_MODE,
NACK_MODE,
TX_REG_ADDRESS_MODE,
RX_REG_ADDRESS_MODE,
TX_DATA_MODE,
RX_DATA_MODE,
SWITCH_TO_RX_MODE,
SWITHC_TO_TX_MODE,
TIMEOUT_MODE
} I2C_Mode;
/* Used to track the state of the software state machine*/
I2C_Mode SlaveMode = RX_REG_ADDRESS_MODE;
/* The Register Address/Command to use*/
uint8_t ReceiveRegAddr = 0;
/* ReceiveBuffer: Buffer used to receive data in the ISR
* RXByteCtr: Number of bytes left to receive
* ReceiveIndex: The index of the next byte to be received in ReceiveBuffer
* TransmitBuffer: Buffer used to transmit data in the ISR
* TXByteCtr: Number of bytes left to transfer
* TransmitIndex: The index of the next byte to be transmitted in TransmitBuffer
uint8_t ReceiveBuffer[MAX_BUFFER_SIZE] = {0};
uint8_t RXByteCtr = 0;
uint8_t ReceiveIndex = 0;
uint8_t TransmitBuffer[MAX_BUFFER_SIZE] = {0};
uint8_t TXByteCtr = 0;
uint8_t TransmitIndex = 0;
/* Initialized the software state machine according to the received cmd
* cmd: The command/register address received
void I2C_Slave_ProcessCMD(uint8_t cmd);
/* The transaction between the slave and master is completed. Uses cmd
* to do post transaction operations. (Place data from ReceiveBuffer
* to the corresponding buffer based in the last received cmd)
* cmd: The command/register address corresponding to the completed
* transaction
void I2C_Slave_TransactionDone(uint8_t cmd);
void CopyArray(uint8_t *source, uint8_t *dest, uint8_t count);
ReceiveIndex = 0;
TransmitIndex = 0;
RXByteCtr = 0;
TXByteCtr = 0;
switch (cmd)
case (CMD_TYPE_0_SLAVE): //Send slave device id (This device's id)
SlaveMode = TX_DATA_MODE;
TXByteCtr = TYPE_0_LENGTH;
//Fill out the TransmitBuffer
CopyArray(SlaveType0, TransmitBuffer, TYPE_0_LENGTH);
UCB0IE &= ~UCRXIE; // Disable RX interrupt
UCB0IE |= UCTXIE; // Enable TX interrupt
break;
case (CMD_TYPE_1_SLAVE): //Send slave device time (This device's time)
TXByteCtr = TYPE_1_LENGTH;
CopyArray(SlaveType1, TransmitBuffer, TYPE_1_LENGTH);
break;
case (CMD_TYPE_2_SLAVE): //Send slave device location (This device's location)
TXByteCtr = TYPE_2_LENGTH;
CopyArray(SlaveType2, TransmitBuffer, TYPE_2_LENGTH);
break;
case (CMD_TYPE_0_MASTER):
SlaveMode = RX_DATA_MODE;
RXByteCtr = TYPE_0_LENGTH;
UCB0IE &= ~UCTXIE; // Disable RX interrupt
UCB0IE |= UCRXIE; // Enable TX interrupt
break;
case (CMD_TYPE_1_MASTER):
RXByteCtr = TYPE_1_LENGTH;
break;
case (CMD_TYPE_2_MASTER):
RXByteCtr = TYPE_2_LENGTH;
break;
default:
__no_operation();
break;
switch (cmd)
case (CMD_TYPE_0_SLAVE): //Slave device id was sent(This device's id)
break;
case (CMD_TYPE_1_SLAVE): //Slave device time was sent(This device's time)
break;
break;
CopyArray(ReceiveBuffer, MasterType0, TYPE_0_LENGTH);
break;
CopyArray(ReceiveBuffer, MasterType1, TYPE_1_LENGTH);
break;
CopyArray(ReceiveBuffer, MasterType2, TYPE_2_LENGTH);
break;
default:
__no_operation();
break;
uint8_t copyIndex = 0;
for (copyIndex = 0; copyIndex < count; copyIndex++)
dest[copyIndex] = source[copyIndex];
// Device Initialization *******************************************************
void initGPIO()
//LEDs
LED0_OUT &= ~LED0_PIN;
LED0_DIR |= LED0_PIN;
LED1_OUT &= ~LED1_PIN;
LED1_DIR |= LED1_PIN;
// I2C pins
P1SEL0 |= BIT2 | BIT3;
P1SEL1 &= ~(BIT2 | BIT3);
// Disable the GPIO power-on default high-impedance mode to activate
// previously configured port settings
PM5CTL0 &= ~LOCKLPM5;
void initI2C()
UCB0CTLW0 = UCSWRST; // Software reset enabled
UCB0CTLW0 |= UCMODE_3 | UCSYNC; // I2C mode, sync mode
UCB0I2COA0 = SLAVE_ADDR | UCOAEN; // Own Address and enable
UCB0CTLW0 &= ~UCSWRST; // clear reset register
UCB0IE |= UCRXIE + UCSTPIE;
void initClockTo16MHz()
// Configure one FRAM waitstate as required by the device datasheet for MCLK
// operation beyond 8MHz _before_ configuring the clock system.
FRCTL0 = FRCTLPW | NWAITS_1;
__bis_SR_register(SCG0); // disable FLL
CSCTL3 |= SELREF__REFOCLK; // Set REFO as FLL reference source
CSCTL0 = 0; // clear DCO and MOD registers
CSCTL1 &= ~(DCORSEL_7); // Clear DCO frequency select bits first
CSCTL1 |= DCORSEL_5; // Set DCO = 16MHz
CSCTL2 = FLLD_0 + 487; // set to fDCOCLKDIV = (FLLN + 1)*(fFLLREFCLK/n)
// = (487 + 1)*(32.768 kHz/1)
// = 16 MHz
__delay_cycles(3);
__bic_SR_register(SCG0); // enable FLL
while(CSCTL7 & (FLLUNLOCK0 | FLLUNLOCK1)); // FLL locked
CSCTL4 = SELMS__DCOCLKDIV | SELA__REFOCLK;
// Main ************************************************************************
// Enters LPM0 and waits for I2C interrupts. The data sent from the master is *
// then interpreted and the device will respond accordingly *
int main(void) {
WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer
initClockTo16MHz();
initGPIO();
initI2C();
__bis_SR_register(LPM0_bits + GIE);
return 0;
// I2C Interrupt ***************************************************************
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector = USCI_B0_VECTOR
__interrupt void USCI_B0_ISR(void)
#elif defined(__GNUC__)
void __attribute__ ((interrupt(USCI_B0_VECTOR))) USCI_B0_ISR (void)
#else
#error Compiler not supported!
#endif
//Must read from UCB0RXBUF
uint8_t rx_val = 0;
switch(__even_in_range(UCB0IV, USCI_I2C_UCBIT9IFG))
case USCI_NONE: break; // Vector 0: No interrupts
case USCI_I2C_UCALIFG: break; // Vector 2: ALIFG
case USCI_I2C_UCNACKIFG: // Vector 4: NACKIFG
break;
case USCI_I2C_UCSTTIFG: break; // Vector 6: STTIFG
case USCI_I2C_UCSTPIFG:
UCB0IFG &= ~(UCTXIFG0);
break; // Vector 8: STPIFG
case USCI_I2C_UCRXIFG3: break; // Vector 10: RXIFG3
case USCI_I2C_UCTXIFG3: break; // Vector 12: TXIFG3
case USCI_I2C_UCRXIFG2: break; // Vector 14: RXIFG2
case USCI_I2C_UCTXIFG2: break; // Vector 16: TXIFG2
case USCI_I2C_UCRXIFG1: break; // Vector 18: RXIFG1
case USCI_I2C_UCTXIFG1: break; // Vector 20: TXIFG1
case USCI_I2C_UCRXIFG0: // Vector 22: RXIFG0
rx_val = UCB0RXBUF;
switch (SlaveMode)
case (RX_REG_ADDRESS_MODE):
ReceiveRegAddr = rx_val;
I2C_Slave_ProcessCMD(ReceiveRegAddr);
break;
case (RX_DATA_MODE):
ReceiveBuffer[ReceiveIndex++] = rx_val;
RXByteCtr--;
if (RXByteCtr == 0)
//Done Receiving MSG
UCB0IE &= ~(UCTXIE);
UCB0IE |= UCRXIE; // Enable RX interrupt
I2C_Slave_TransactionDone(ReceiveRegAddr);
break;
default:
__no_operation();
break;
break;
case USCI_I2C_UCTXIFG0: // Vector 24: TXIFG0
switch (SlaveMode)
case (TX_DATA_MODE):
UCB0TXBUF = TransmitBuffer[TransmitIndex++];
TXByteCtr--;
if (TXByteCtr == 0)
//Done Transmitting MSG
break;
default:
__no_operation();
break;
break; // Interrupt Vector: I2C Mode: UCTXIFG
default: break;
