Part Number: TIDM-BPM
Other Parts Discussed in Thread: MSP430F6638
for adding bluetooth and wifi interface is there any inbuilt library function available. can you provide code modification for that if required.
Hi Pooja,
TIDM-BPM use MSP430F6638 MCU as the controller. There is no integrated RF module inside the MCU. Therefore, you need to add a separate module if you want to add wifi or bluetooth, and use corresponding protocol to communicate with it. The following link is the code example we provide. Maybe useful for you.
http://dev.ti.com/tirex/explore/node?node=AKdBlqImUz6tvVbABDpt4g__IOGqZri__LATEST
Best Regards
Johnson
