MSP430F2416: msp430f2416
Part Number: MSP430F2416
Hi
We are using an msp430f2416 processor in our project i had loaded the bootloader firmware in to RAM. even after the  power recycle the bootloader firmware still retains on the RAM memory.
so i could not understand how the firmware retains even the processor does not have the FRAM . I have also attached the bootloader linker file below.
/* Copyright (c) 2017, Texas Instruments Incorporated                           */
/*  All rights reserved.                                                        */
/*  Redistribution and use in source and binary forms, with or without          */
/*  modification, are permitted provided that the following conditions          */
/*  are met:        */
/*  *  Redistributions of source code must retain the above copyright           */
/*     notice, this list of conditions and the following disclaimer.            */
/*  *  Redistributions in binary form must reproduce the above copyright        */
/*     notice, this list of conditions and the following disclaimer in the      */
/*     documentation and/or other materials provided with the distribution.     */
/*  *  Neither the name of Texas Instruments Incorporated nor the names of      */
/*     its contributors may be used to endorse or promote products derived      */
/*     from this software without specific prior written permission.            */
/*  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" */
/*  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,       */
/*  THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR      */
/*  PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR            */
/*  CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,       */
/*  EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,         */
/*  PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; */
/*  OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,    */
/*  WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR     */
/*  OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,              */
/*  EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.                          */
/* lnk_msp430f2416.cmd - LINKER COMMAND FILE FOR LINKING MSP430F2416 PROGRAMS     */
/*   Usage:  lnk430 <obj files...>    -o <out file> -m <map file> lnk.cmd     */
/*           cl430  <src files...> -z -o <out file> -m <map file> lnk.cmd     */
/* These linker options are for command line linking only.  For IDE linking,  */
/* you should set your linker options in Project Properties                   */
/* -c                                               LINK USING C CONVENTIONS  */
/* -stack  0x0100                                   SOFTWARE STACK SIZE       */
/* -heap   0x0100                                   HEAP AREA SIZE            */
/* Version: 1.201                                                             */
/* Specify the system memory map                                            */
MEMORY
    SFR                     : origin = 0x0000, length = 0x0010
    PERIPHERALS_8BIT        : origin = 0x0010, length = 0x00F0
    PERIPHERALS_16BIT       : origin = 0x0100, length = 0x0100
    //RAM                     : origin = 0x1100, length = 0x1000
    //RAM      : origin = 0x1110, length = 0x07F0 //2kb
    RAM      : origin = 0x1100, length = 0x08CC //3kb
    INFOA                   : origin = 0x10C0, length = 0x0040
    INFOB                   : origin = 0x1080, length = 0x0040
    INFOC                   : origin = 0x1040, length = 0x0040
    INFOD                   : origin = 0x1000, length = 0x0040
    FLASH                   : origin = 0x2100, length = 0xDEBE
    FLASH2                  : origin = 0x10000,length = 0x9000
    BSLSIGNATURE            : origin = 0xFFBE, length = 0x0002, fill = 0xFFFF
    INT00                   : origin = 0xFFC0, length = 0x0002
    INT01                   : origin = 0xFFC2, length = 0x0002
    INT02                   : origin = 0xFFC4, length = 0x0002
    INT03                   : origin = 0xFFC6, length = 0x0002
    INT04                   : origin = 0xFFC8, length = 0x0002
    INT05                   : origin = 0xFFCA, length = 0x0002
    INT06                   : origin = 0xFFCC, length = 0x0002
    INT07                   : origin = 0xFFCE, length = 0x0002
    INT08                   : origin = 0xFFD0, length = 0x0002
    INT09                   : origin = 0xFFD2, length = 0x0002
    INT10                   : origin = 0xFFD4, length = 0x0002
    INT11                   : origin = 0xFFD6, length = 0x0002
    INT12                   : origin = 0xFFD8, length = 0x0002
    INT13                   : origin = 0xFFDA, length = 0x0002
    INT14                   : origin = 0xFFDC, length = 0x0002
    INT15                   : origin = 0xFFDE, length = 0x0002
    INT16                   : origin = 0xFFE0, length = 0x0002
    INT17                   : origin = 0xFFE2, length = 0x0002
    INT18                   : origin = 0xFFE4, length = 0x0002
    INT19                   : origin = 0xFFE6, length = 0x0002
    INT20                   : origin = 0xFFE8, length = 0x0002
    INT21                   : origin = 0xFFEA, length = 0x0002
    INT22                   : origin = 0xFFEC, length = 0x0002
    INT23                   : origin = 0xFFEE, length = 0x0002
    INT24                   : origin = 0xFFF0, length = 0x0002
    INT25                   : origin = 0xFFF2, length = 0x0002
    INT26                   : origin = 0xFFF4, length = 0x0002
    INT27                   : origin = 0xFFF6, length = 0x0002
    INT28                   : origin = 0xFFF8, length = 0x0002
    INT29                   : origin = 0xFFFA, length = 0x0002
    INT30                   : origin = 0xFFFC, length = 0x0002
    RESET                   : origin = 0xFFFE, length = 0x0002
/* Specify the sections allocation into memory                              */
SECTIONS
    .bss        : {} > RAM                  /* Global & static vars              */
    .data       : {} > RAM                  /* Global & static vars              */
    .TI.noinit  : {} > RAM                  /* For #pragma noinit                */
    .sysmem     : {} > RAM                  /* Dynamic memory allocation area    */
    .stack      : {} > RAM (HIGH)           /* Software system stack             */
#ifndef __LARGE_CODE_MODEL__
    .text       : {} > FLASH                /* Code                              */
#else
    .text       : {} >> RAM //FLASH2 | FLASH      /* Code                              */
#endif
    .text:_isr  : {} > RAM           /* ISR Code space                    */
    .cinit      : {} > RAM            /* Initialization tables             */
#ifndef __LARGE_DATA_MODEL__
    .const      : {} > RAM               /* Constant data                     */
#else
    .const      : {} >> RAM      /* Constant data                     */
#endif
    .bslsignature  : {} > BSLSIGNATURE      /* BSL Signature                     */
    .cio        : {} > RAM                  /* C I/O Buffer                      */
    .pinit      : {} > RAM                /* C++ Constructor tables            */
    .binit      : {} > RAM                /* Boot-time Initialization tables   */
    .init_array : {} > RAM                /* C++ Constructor tables            */
    .mspabi.exidx : {} > RAM              /* C++ Constructor tables            */
    .mspabi.extab : {} > RAM              /* C++ Constructor tables            */
#ifdef __TI_COMPILER_VERSION__
  #if __TI_COMPILER_VERSION__ >= 15009000
    .TI.ramfunc : {} load=FLASH, run=RAM, table(BINIT)
    #else
    .TI.ramfunc : {} load=FLASH | FLASH2, run=RAM, table(BINIT)
    #endif
  #endif
#endif
    .infoA     : {} > INFOA              /* MSP430 INFO FLASH Memory segments */
    .infoB     : {} > INFOB
    .infoC     : {} > INFOC
    .infoD     : {} > INFOD
    /* MSP430 Interrupt vectors          */
    RESERVED0    : { * ( .int00 ) } > INT00 type = VECT_INIT
    RESERVED1    : { * ( .int01 ) } > INT01 type = VECT_INIT
    RESERVED2    : { * ( .int02 ) } > INT02 type = VECT_INIT
    RESERVED3    : { * ( .int03 ) } > INT03 type = VECT_INIT
    RESERVED4    : { * ( .int04 ) } > INT04 type = VECT_INIT
    RESERVED5    : { * ( .int05 ) } > INT05 type = VECT_INIT
    RESERVED6    : { * ( .int06 ) } > INT06 type = VECT_INIT
    RESERVED7    : { * ( .int07 ) } > INT07 type = VECT_INIT
    RESERVED8    : { * ( .int08 ) } > INT08 type = VECT_INIT
    RESERVED9    : { * ( .int09 ) } > INT09 type = VECT_INIT
    RESERVED10   : { * ( .int10 ) } > INT10 type = VECT_INIT
    RESERVED11   : { * ( .int11 ) } > INT11 type = VECT_INIT
    RESERVED12   : { * ( .int12 ) } > INT12 type = VECT_INIT
    RESERVED13   : { * ( .int13 ) } > INT13 type = VECT_INIT
    RESERVED14   : { * ( .int14 ) } > INT14 type = VECT_INIT
    RESERVED15   : { * ( .int15 ) } > INT15 type = VECT_INIT
    USCIAB1TX    : { * ( .int16 ) } > INT16 type = VECT_INIT
    USCIAB1RX    : { * ( .int17 ) } > INT17 type = VECT_INIT
    PORT1        : { * ( .int18 ) } > INT18 type = VECT_INIT
    PORT2        : { * ( .int19 ) } > INT19 type = VECT_INIT
    RESERVED20   : { * ( .int20 ) } > INT20 type = VECT_INIT
    ADC12        : { * ( .int21 ) } > INT21 type = VECT_INIT
    USCIAB0TX    : { * ( .int22 ) } > INT22 type = VECT_INIT
    USCIAB0RX    : { * ( .int23 ) } > INT23 type = VECT_INIT
    TIMERA1      : { * ( .int24 ) } > INT24 type = VECT_INIT
    TIMERA0      : { * ( .int25 ) } > INT25 type = VECT_INIT
    WDT          : { * ( .int26 ) } > INT26 type = VECT_INIT
    COMPARATORA   : { * ( .int27 ) } > INT27 type = VECT_INIT
    TIMERB1      : { * ( .int28 ) } > INT28 type = VECT_INIT
    TIMERB0      : { * ( .int29 ) } > INT29 type = VECT_INIT
    NMI          : { * ( .int30 ) } > INT30 type = VECT_INIT
    .reset       : {}               > RESET  /* MSP430 Reset vector         */
/* Include peripherals memory map                                           */
-l msp430f2416.cmd
    I can think of 2 possible issues.  The first is that somehow, the code is being stored into Flash and then copied into RAM at start.  The second is that the RAM is retaining the data through your "power cycle"
    The RAM is not initialized by default.  After a full power cycle, it can't be guaranteed that RAM retained the data and should mainly come up in a somewhat random state.  But, if there is residual charge on the board/MCU, it's possible that the code remains on the board.
    Are you sure VCC is going all the way to 0V when power cycling?  Maybe short vcc and gnd after you've removed power to drain any residual voltage left on bypass caps, ect.
    Let me know how that goes.
    JD
