I'm testing the TIMER CAPTURE function.
All other functions have been tested, but the prescale function does not work well.
The source code as follows.
MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER3);
MAP_TimerConfigure(TIMER3_BASE, TIMER_CFG_SPLIT_PAIR | TIMER_CFG_A_ONE_SHOT | TIMER_CFG_B_ONE_SHOT);
MAP_TimerPrescaleSet(TIMER3_BASE, TIMER_A, 10);
MAP_TimerPrescaleSet(TIMER3_BASE, TIMER_B, 20);
Since the prescale value of TIMER_A is half that of TIMER_B, the value obtained through the MAP_TimerValueGet () function is twice that of TIMER_B.
But if i set the timer to capture mode ...
MAP_TimerConfigure (TIMER3_BASE, TIMER_CFG_SPLIT_PAIR | TIMER_CFG_A_CAP_COUNT | TIMER_CFG_B_CAP_COUNT);
The same value is read.
Does prescale not work in capture mode?
I want to know more about capture mode and prescale behavior.
