MSP430FR2355: Smart combo for audio processing
Part Number: MSP430FR2355
customer needs a compact solution for signalling tones, speech and sounds on a small loudspeaker and also measuring enviroments noise with a microphone. I thought to use MSP430FR2355 for this tasks. I thought of following way:
Measuring sound:
Microphone -> OA -> 12bit-ADC -> CPU
Generating sound:
Flash -> CPU/DMA -> 12bit DAC -> OA -> loudspeaker
Can this work? Is there any reference design?
Regards, Holger
  • Hi Holger!
    HS WG-FAE said:
    Measuring sound:
    I believe this is doable, but it will depend on a few things such as the max and min voltages generated from the microphone and the required drive strength of the op amp. You might also need some passives between the mic and op amp.
    HS WG-FAE said:
    Generating sound:
    Yes! This is definitely doable. One thing to mention - you will need to feed the audio output of the MSP into a dedicated audio op amp to get the required drive strength to drive the speaker. I am looking for resources on this and will get back to you soon.
    Mitch
  • Hi Holger,
    I sent you a request to connect. Please accept my request.
    Mitch
  • Hi Holger,
    I will close out the thread since we are handing this internally.
    Mitch
