Part Number: MSP430F5529
Other Parts Discussed in Thread: ENERGIA
Hi Joshua,
Energia is an open source & community-driven integrated development environment (IDE) & software framework. Please Check out the 43oh.com forums for Energia support
Thanks for your quick responce and suggestion
The problem is not with enegia, as this code was working earlier.
I seems that it is a hardware problem as (clock rate has changed) ,
Read my problem statement to see if yuo can solve the issue.
however I will post this on energia forum as well.
Hi Joshua,
I didn't find any detailed configuration for your clock system. Could you share more about this?
However, since you are using energia API to configrue the device, I would again suggest you to the energia forum.
