MSP432P401R: How convert TI-TXT file to C Array
Part Number: MSP432P401R
Hello There,
I'm following below's  's suggestion to convert bootloader's TI-TXT file to C Array with srec_cat.exe tool.
Using the srec_cat tool, run the following command: C:\ccs_msp432_ccsv7_2_msp432p401r_oad\oad_bootloader_source_MSP_EXP432P 401R_nortos_ccs\Debug>srec_cat oad_bootloader_source_MSP_EXP432P401R_nortos_ccs.txt -ti_txt -o oad_bootloader.c -ca oad_bootloader -c_comp
https://e2e.ti.com/support/microcontrollers/msp430/f/166/t/639908?RTOS-MSP432P401R-MSP432-OAD-How-to-generate-custom-bootloader-to-be-placed-0x0000-Memory-organization-is-same-as-existing-OAD-example-code
But it's not working. The application stucks at srec_cat: standard input: 1: warning: ignoring garbage lines and nothing happens.
Any help is appreciated.
Keshav Aggarwal
