Other Parts Discussed in Thread: RF430FRL152H
I want to use TIDM-RF430-TEMPSENSE solution while I am not sure about the range and accuracy of temperature converted and calculated. Could someone give me the information.
Sean
Sean
Hello Sean,
I would say the range is mainly limited by the RF430FRL152H operation temperature from 0 to 70 degrees Celsius.
The accuracy depends on the settings for the SD14 ADC which gives you a higher accuracy when you set longer conversion times.
Please see the Technical Reference Manual page 204 for more information:
http://www.ti.com/lit/ug/slau506/slau506.pdf
Helfried
