I am working on a design where I need to sense water leaks. First of all, I want to know if the selected product is the most apropiate for this kind of application.
Then, I have a question regarding the parameter "Meter Constant" of the GUI. I imagine that this constant is used to calculate the Volume Flow Rate which is related with the cross section of the pipe. What is the formula to calculate the "Meter Constant" to obtain correct results in the "Volume Flow Rate" graph?
Thank you in advance.
Kind regards,
Ferran
