Other Parts Discussed in Thread: ADS1278
My requirement is to set the ADS1278 at 20ksps and read that samples using MSP432 through SPI. Can i get any example code..
usr 007 said:My requirement is to set the ADS1278 at 20ksps
The datasheet should specify which registers can be configured to achieve this sampling rate.
usr 007 said:read that samples using MSP432 through SPI. Can i get any example code..
I would recommend starting with our SPI code examples. You can find them in the TI Resource Explorer inside CCS or on dev.ti.com. Search for code examples with "spi" in the name.
https://dev.ti.com/tirex/explore/node?node=AIaHSvjn.KjUNRDtdnUpsg__z-lQYNj__LATEST
Also, I would recommend searching the forum for SPI-related threads that will probably be very helpful for your development. Another great resource is the Solutions to Common eUSCI and USCI Serial Communication Issues on MSP430™ MCUs app note.
James
