Part Number: MSP-EXP432P401R
Hello everyone
I am writing an application for the MSP432 development board using TIRTOS. The structure of the application skeleton is the following (see also code below):
- There are two GPIO interrupts set up for two buttons. When a button is pressed, the associated interrupt handler sends a message over the UART to the connected PC using the `Display_printf` library function.
- In addition there is a timer set up which causes periodic interrupts every 1ms.
If I run the application and click the buttons sequentially a few times, the system always freezes in an exception handler. The decoded exception says `Hard Fault: FORCED: BUSFAULT: PRECISERR.Data Access Error. Address = 0x40000c04` and the exception call stack says `ti_sysbios_knl_Task_unblockI__E`.
I'm not quite sure why this error occurs. Is there anything I need to consider or I'm not aware of when I want to call `Display_printf`?
The application code:
/* POSIX Header files */
#include <pthread.h>
/* Driver Header files */
#include <ti/drivers/ADC.h>
#include <ti/display/Display.h>
#include <ti/drivers/PWM.h>
#include <ti/drivers/Timer.h>
#include <ti/drivers/GPIO.h>
/* Driver configuration */
#include "ti_drivers_config.h"
#include "coil_control.h"
/* State machine related variables */
enum driver_state state = INIT;
/* current timer value */
/* Open the timer */
Timer_Handle timer0;
Timer_Params t_params;
uint32_t counter_value=0;
static Display_Handle display;
* ======== controller / duty cycle thread ========
* measure the voltage produced by current sensor amplifier
void current_controller(Timer_Handle myHandle){
//counter_value+=1;
* ======== sw1 callback ========
* advance state machine forward
void sw1_callback(uint_least8_t ind){
counter_value+=1;
Display_printf(display, 0, 0, "SW1 pressed\n");
* ======== cw2 callback ========
* advance state machine backwards
void sw2_callback(uint_least8_t ind){
counter_value+=1;
Display_printf(display, 0, 0, "SW2 pressed\n");
* ======== mainThread ========
* the main thread sets up a timer for
* - periodic currentsens_voltage_measurement (current sens thread)
* - periodic adjustment of duty cycle (current control thread)
* - periodic communication with PC (communication thread)
void *mainThread(void *arg0)
// GPIO 0 Setup
GPIO_setConfig(CONFIG_GPIO_S1, GPIO_CFG_IN_PU | GPIO_CFG_IN_INT_FALLING);
GPIO_setConfig(CONFIG_GPIO_S2, GPIO_CFG_IN_PU | GPIO_CFG_IN_INT_FALLING);
GPIO_setCallback(CONFIG_GPIO_S1, sw1_callback);
GPIO_setCallback(CONFIG_GPIO_S2, sw2_callback);
GPIO_enableInt(CONFIG_GPIO_S1);
GPIO_enableInt(CONFIG_GPIO_S2);
// Timer 32 Setup
Timer_init();
Timer_Params_init(&t_params);
t_params.period = 1000;
t_params.periodUnits = Timer_PERIOD_US;
t_params.timerMode = Timer_CONTINUOUS_CALLBACK;
t_params.timerCallback = current_controller;
timer0 = Timer_open(CONFIG_TIMER_0, &t_params);
if (timer0 == NULL) {
/* Failed to initialized timer */
while (1) {}
if (Timer_start(timer0) == Timer_STATUS_ERROR) {
/* Failed to start timer */
while (1) {}
/* Open the display for output */
display = Display_open(Display_Type_UART, NULL);
if (display == NULL) {
/* Failed to open display driver */
while (1);
Display_printf(display, 0, 0, "Starting the acdcsinglechannel example\n");
return (NULL);
