MSP430FR5964: Abnormal read operation of "SRAM" under low temperature environment
Part Number: MSP430FR5964
Other Parts Discussed in Thread: MSP-TS430RGZ48C
Hi experts,
I'm having a problem with the SRAM area of the MSP430FR5964IRGZR that my customer is using.
This is the same customer and the same device as the previous case supported in the following thread. In that case, the problem was that 0 was written to some areas of the FRAM, but this time the problem is that 1 is written to some areas of the SRAM.
https://e2e.ti.com/support/microcontrollers/msp430/f/166/p/897041/3323999#3323999
Should I ask TI to analyze the problem as in the above thread?
I tested with the following method.
  1. Put the faulty MSP430FR5964IRGZR on MSP-TS430RGZ48C and leave it in a thermostatic bath at -20°C for about 2 hours.
  2. Turn on the power and write 0xFF to the SRAM area. Then, copy the contents of the SRAM area to the FRAM area. Then, compare 0xFF with the contents of the SRAM area, and if they do not match, an error is judged.
  3. Write 0x00 to the SRAM area. Then, copy the contents of the SRAM area to the FRAM area. Then, compare 0x00 with the contents of the SRAM area, and if they do not match, an error judgment is made.
  4. An error occurs in No. 3, and when we checked the contents of the FRAM, we found that 1 was irregularly written to bit 6. (0x40 is read out).
I have attached the verification program and an excerpt of the verification result.xlsx.
Is this problem expected to be the same reason as the above thread?
I will summarize the information below.
  • The SRAM area used is 0x2082~0x3540. The area where a 1 appears on bit6 looks like 0x2802~0x2BFF.
  • The FRAM area used is 0x4000~0x54BF.
  • This problem cannot be confirmed at normal temperature, but it is reproduced -100% in the environment below -20°C.
    However, when the temperature is raised from the error state at -20°C to room temperature and read again, normal values are read out.
  • This problem has occurred in 2 out of 4000 units.One of them includes the previous FRAM failure, so it is actually one unit.
    As for the normal product, it works even at -20°C in the same test.
  • Cross-checking was performed, but the problem is still with the IC.
    Good IC + defective board = no error
    Defective IC + good board = problem occurred
    Defective IC + MSP-TS430RGZ48C = Problem occurred.
  • The Revision # of the device is "C".
  • The manufacturing lot is different from the previous lot by about half a year.
If there is anything else I should check, please let me know.
O.H
FR5964_SRAM_TEST_CODE.zip
The verification result.xlsx
    thanks for highlighting this. Is it possible to get the txt files for the expected memory content and the fail one from the 1st reading?
    This helps us to easier map to the right addresses.
    Does the device from the other E2E thread is still available? And do both behave the same applying the bench code you attached?
    In most of the cases the byte in FRAM is 0x40 instead of the expected 0x00 only at read 2 at line #515 there is a problem in RAM is this a typo or a real fail?
    Would the behavior also appear if you try this at FRAM addresses 0x8000 or 0xC000 means with an offset of 16 KB?
    Sorry. The extraction address of the SRAM was wrong in the previous verification, so we verified it again using the same program. The result was the same as the last time. When I checked the contents of the FRAM, I found that 1 was irregularly written to bit 6 (0x40 was read).I have attached a txt file of the FRAM and SRAM data at normal temperature (25°C) and at -20°C.
    I am sorry. The device used for verification in the previous thread was not available.
    I verified again 5 times, but this time I could not confirm 0x40 in SRAM. However, the current problem seems to be happening during SRAM Read, so it could be a typo, or it could be the actual read value.I extracted the SRAM (0x2082~0x3540) to txt file several times, but could not confirm 0x40.
    In another verification method, instead of writing the value written in SRAM directly to FRAM, I tried writing it once to Buffer (around 0x1C00) and then to FRAM. Then, when the value was written to the Buffer, bit 6 was set to 1, and the FRAM was written with the same content. (When I checked in View Disassembly, bit6 was set to 1 when the register was written.)
    Also, when I wrote 0x00 directly to the FRAM, there was no problem in the FRAM area. From the above, I believe that something is wrong with the SRAM when it is read (I could not check when it is written).
    I changed the write area of FRAM to 0x8000 and 0xC000, but the same phenomenon was confirmed.I am attaching a txt file.
    O.H
    1651 9 4000 0 14bf d
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    1651 9 2082 0 14bf d
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    40
    00
    40
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    1651 9 8000 0 14bf d
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    1651 9 2082 0 14bf d
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    1651 9 c000 0 14bf d
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    40
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    40
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    40
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    40
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
    00
  • O.H.,
    thanks for the experiments it looks like independed of the address offset the bit #6 changes appear always at the regions
    - if @4000 it appears between 0x4380 and go up to 0x4B80
    - if @8000 it appears between 0x8380 and go up to 0x8B80
    - if @C000 it appears between 0xC380 and go up to 0xCB80
    You also said it disappeared if you increase temperature again but most probably because you write FRAM again and again right?
    Is it possible to trigger the memory changes at -20 degC and stop FRAM writing and then go back to room temp and read FRAM again to see if the behavior is still visible?
    Also I would say the behavior of this unit (called it unit #2) is different from the one (unit #1) from the previous post, do you agree?
    What happened to unit #1 should this not delivered to TI for analysis?
  • Hi O.H.,
    I have sent you a friend request. Please accept my request so that I can provide you with information to send us your board for analysis.
    BR,
    Leo
  • Hi Dietmar Walther, Leo,
    I will be in private chat with you to confirm how to proceed.
    Thank you for your kind support.
    O.H
  • Hi O.H.
    can you please provide actual status on this thread, is the unit already shipped to TI?
    Sorry for the late reply.
    I have sent a request to TI Japan for analysis. We have received a response and are communicating with them, but the unit has not shipped yet.After talking with Leonardo, we decided to contact TI Japan first.
    O.H
