Part Number: MSP430F6721A
Hi team,
Can you answer a couple customer question?
- Do you have an application circuit for infrared thermopile measurement ?
- How to measure positive and negative voltage of the thermopile directly with the ADC24 without additional OPAMP ?
- How would it be possible to drive the µC directly via a LDO without a buck LDO ? Supply will be via 2xAAA batteries. Which LDO voltage do you recommend?
- What is the minimum LCD voltage in practice ? Are there any limitations regarding MUX (number of common lines) ?
- Could you tell me the temperature drift of the ADC24 in µV/°C ?
Thank you,
Franz
