MSP430FR2676: program does not fit into available memory
Part Number: MSP430FR2676
Other Parts Discussed in Thread: LP5012
When building my program I get the following error:
#10099-D program will not fit into available memory, or the section contains a call site that requires a trampoline that can't be generated for this section. placement with alignment fails for section "ALL_FRAM" size 0x7ff8. Available memory ranges: lnk_msp430fr2676.cmd
the MCU has a capacity of 64KByte. I am using:
CODE size (bytes): 30648
CONST size (bytes): 1168
DATA size (bytes): 2769
If I delete a few lines of source code the compilation is succesful.
How can I solve the problem?
  • Hi Antonio,
    Can you share you linker .cmd file and your .map file that is generated when you successfully build the project?
    BR,
    Leo
  • Hi Leo
    Thanks for the answer. I copy and paste both files:
    lnk_msp430fr2676.cmd******************************************************************************************************************************************************************************************************************
    * Copyright (C) 2012 - 2019 Texas Instruments Incorporated - http://www.ti.com/
    * Redistribution and use in source and binary forms, with or without
    * modification, are permitted provided that the following conditions
    * are met:
    * Redistributions of source code must retain the above copyright
    * notice, this list of conditions and the following disclaimer.
    * Redistributions in binary form must reproduce the above copyright
    * notice, this list of conditions and the following disclaimer in the
    * documentation and/or other materials provided with the
    * distribution.
    * Neither the name of Texas Instruments Incorporated nor the names of
    * its contributors may be used to endorse or promote products derived
    * from this software without specific prior written permission.
    * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    * Default linker command file for Texas Instruments MSP430FR2676
    /* Usage: lnk430 <obj files...> -o <out file> -m <map file> lnk.cmd */
    /* cl430 <src files...> -z -o <out file> -m <map file> lnk.cmd */
    /* These linker options are for command line linking only. For IDE linking, */
    /* you should set your linker options in Project Properties */
    /* -c LINK USING C CONVENTIONS */
    /* -stack 0x0100 SOFTWARE STACK SIZE */
    /* -heap 0x0100 HEAP AREA SIZE */
    /* 1.207 */
    /* SPECIFY THE SYSTEM MEMORY MAP */
    MEMORY
    TINYRAM : origin = 0x6, length = 0x1A
    BSL0 : origin = 0x1000, length = 0x800
    INFO : origin = 0x1800, length = 0x200
    TLVMEM : origin = 0x1A00, length = 0x200
    BOOTCODE : origin = 0x1C00, length = 0x400
    RAM : origin = 0x2000, length = 0x2000
    FRAM : origin = 0x8000, length = 0x7F80
    FRAM2 : origin = 0x10000,length = 0x8000
    ROMLIB : origin = 0xC0000, length = 0x4000
    BSL1 : origin = 0xFFC00, length = 0x400
    JTAGSIGNATURE : origin = 0xFF80, length = 0x0004, fill = 0xFFFF
    BSLSIGNATURE : origin = 0xFF84, length = 0x0004, fill = 0xFFFF
    BSLCONFIGURATIONSIGNATURE: origin = 0xFF88, length = 0x0002, fill = 0xFFFF
    BSLCONFIGURATION : origin = 0xFF8A, length = 0x0002, fill = 0xFFFF
    BSLI2CADDRESS : origin = 0xFFA0, length = 0x0002, fill = 0xFFFF
    INT00 : origin = 0xFFA2, length = 0x0002
    INT01 : origin = 0xFFA4, length = 0x0002
    INT02 : origin = 0xFFA6, length = 0x0002
    INT03 : origin = 0xFFA8, length = 0x0002
    INT04 : origin = 0xFFAA, length = 0x0002
    INT05 : origin = 0xFFAC, length = 0x0002
    INT06 : origin = 0xFFAE, length = 0x0002
    INT07 : origin = 0xFFB0, length = 0x0002
    INT08 : origin = 0xFFB2, length = 0x0002
    INT09 : origin = 0xFFB4, length = 0x0002
    INT10 : origin = 0xFFB6, length = 0x0002
    INT11 : origin = 0xFFB8, length = 0x0002
    INT12 : origin = 0xFFBA, length = 0x0002
    INT13 : origin = 0xFFBC, length = 0x0002
    INT14 : origin = 0xFFBE, length = 0x0002
    INT15 : origin = 0xFFC0, length = 0x0002
    INT16 : origin = 0xFFC2, length = 0x0002
    INT17 : origin = 0xFFC4, length = 0x0002
    INT18 : origin = 0xFFC6, length = 0x0002
    INT19 : origin = 0xFFC8, length = 0x0002
    INT20 : origin = 0xFFCA, length = 0x0002
    INT21 : origin = 0xFFCC, length = 0x0002
    INT22 : origin = 0xFFCE, length = 0x0002
    INT23 : origin = 0xFFD0, length = 0x0002
    INT24 : origin = 0xFFD2, length = 0x0002
    INT25 : origin = 0xFFD4, length = 0x0002
    INT26 : origin = 0xFFD6, length = 0x0002
    INT27 : origin = 0xFFD8, length = 0x0002
    INT28 : origin = 0xFFDA, length = 0x0002
    INT29 : origin = 0xFFDC, length = 0x0002
    INT30 : origin = 0xFFDE, length = 0x0002
    INT31 : origin = 0xFFE0, length = 0x0002
    INT32 : origin = 0xFFE2, length = 0x0002
    INT33 : origin = 0xFFE4, length = 0x0002
    INT34 : origin = 0xFFE6, length = 0x0002
    INT35 : origin = 0xFFE8, length = 0x0002
    INT36 : origin = 0xFFEA, length = 0x0002
    INT37 : origin = 0xFFEC, length = 0x0002
    INT38 : origin = 0xFFEE, length = 0x0002
    INT39 : origin = 0xFFF0, length = 0x0002
    INT40 : origin = 0xFFF2, length = 0x0002
    INT41 : origin = 0xFFF4, length = 0x0002
    INT42 : origin = 0xFFF6, length = 0x0002
    INT43 : origin = 0xFFF8, length = 0x0002
    INT44 : origin = 0xFFFA, length = 0x0002
    INT45 : origin = 0xFFFC, length = 0x0002
    RESET : origin = 0xFFFE, length = 0x0002
    /* SPECIFY THE SECTIONS ALLOCATION INTO MEMORY */
    SECTIONS
    GROUP(ALL_FRAM)
    GROUP(READ_WRITE_MEMORY)
    .TI.persistent : {} /* For #pragma persistent */
    .cio : {} /* C I/O Buffer */
    .sysmem : {} /* Dynamic memory allocation area */
    } PALIGN(0x0400), RUN_START(fram_rw_start) RUN_END(fram_rx_start)
    GROUP(READ_ONLY_MEMORY)
    .cinit : {} /* Initialization tables */
    .pinit : {} /* C++ constructor tables */
    .binit : {} /* Boot-time Initialization tables */
    .init_array : {} /* C++ constructor tables */
    .mspabi.exidx : {} /* C++ constructor tables */
    .mspabi.extab : {} /* C++ constructor tables */
    .const : {} /* Constant data */
    GROUP(EXECUTABLE_MEMORY)
    .text : {} /* Code */
    .text:_isr : {} /* Code ISRs */
    } > FRAM
    #ifndef __LARGE_DATA_MODEL__
    .const : {} > FRAM /* Constant data */
    #else
    .const : {} >> FRAM | FRAM2 /* Constant data */
    #endif
    #ifndef __LARGE_CODE_MODEL__
    .text : {} > FRAM /* Code */
    #else
    .text : {} >> FRAM2 | FRAM /* Code */
    #endif
    #ifdef __TI_COMPILER_VERSION__
    #if __TI_COMPILER_VERSION__ >= 15009000
    .TI.ramfunc : {} load=FRAM, run=RAM, table(BINIT)
    #else
    .TI.ramfunc : {} load=FRAM | FRAM2, run=RAM, table(BINIT)
    #endif
    #endif
    #endif
    .jtagsignature : {} > JTAGSIGNATURE
    .bslsignature : {} > BSLSIGNATURE
    .bslconfigsignature : {} > BSLCONFIGURATIONSIGNATURE
    .bslconfig : {} > BSLCONFIGURATION
    .bsli2caddress : {} > BSLI2CADDRESS
    .bss : {} > RAM /* Global & static vars */
    .data : {} > RAM /* Global & static vars */
    .TI.noinit : {} > RAM /* For #pragma noinit */
    .stack : {} > RAM (HIGH) /* Software system stack */
    .tinyram : {} > TINYRAM /* Tiny RAM */
    /* MSP430 INFO memory segments */
    .info : type = NOINIT{} > INFO
    /* MSP430 interrupt vectors */
    .int00 : {} > INT00
    .int01 : {} > INT01
    .int02 : {} > INT02
    .int03 : {} > INT03
    .int04 : {} > INT04
    .int05 : {} > INT05
    .int06 : {} > INT06
    .int07 : {} > INT07
    .int08 : {} > INT08
    .int09 : {} > INT09
    .int10 : {} > INT10
    .int11 : {} > INT11
    .int12 : {} > INT12
    .int13 : {} > INT13
    .int14 : {} > INT14
    .int15 : {} > INT15
    .int16 : {} > INT16
    .int17 : {} > INT17
    .int18 : {} > INT18
    CAPTIVATE : { * ( .int19 ) } > INT19 type = VECT_INIT
    ECOMP0 : { * ( .int20 ) } > INT20 type = VECT_INIT
    PORT6 : { * ( .int21 ) } > INT21 type = VECT_INIT
    PORT5 : { * ( .int22 ) } > INT22 type = VECT_INIT
    PORT4 : { * ( .int23 ) } > INT23 type = VECT_INIT
    PORT3 : { * ( .int24 ) } > INT24 type = VECT_INIT
    PORT2 : { * ( .int25 ) } > INT25 type = VECT_INIT
    PORT1 : { * ( .int26 ) } > INT26 type = VECT_INIT
    ADC : { * ( .int27 ) } > INT27 type = VECT_INIT
    EUSCI_B1 : { * ( .int28 ) } > INT28 type = VECT_INIT
    EUSCI_B0 : { * ( .int29 ) } > INT29 type = VECT_INIT
    EUSCI_A1 : { * ( .int30 ) } > INT30 type = VECT_INIT
    EUSCI_A0 : { * ( .int31 ) } > INT31 type = VECT_INIT
    WDT : { * ( .int32 ) } > INT32 type = VECT_INIT
    RTC : { * ( .int33 ) } > INT33 type = VECT_INIT
    TIMER0_B1 : { * ( .int34 ) } > INT34 type = VECT_INIT
    TIMER0_B0 : { * ( .int35 ) } > INT35 type = VECT_INIT
    TIMER3_A1 : { * ( .int36 ) } > INT36 type = VECT_INIT
    TIMER3_A0 : { * ( .int37 ) } > INT37 type = VECT_INIT
    TIMER2_A1 : { * ( .int38 ) } > INT38 type = VECT_INIT
    TIMER2_A0 : { * ( .int39 ) } > INT39 type = VECT_INIT
    TIMER1_A1 : { * ( .int40 ) } > INT40 type = VECT_INIT
    TIMER1_A0 : { * ( .int41 ) } > INT41 type = VECT_INIT
    TIMER0_A1 : { * ( .int42 ) } > INT42 type = VECT_INIT
    TIMER0_A0 : { * ( .int43 ) } > INT43 type = VECT_INIT
    UNMI : { * ( .int44 ) } > INT44 type = VECT_INIT
    SYSNMI : { * ( .int45 ) } > INT45 type = VECT_INIT
    .reset : {} > RESET /* MSP430 reset vector */
    /* FRAM WRITE PROTECTION SEGMENT DEFINITONS */
    #ifdef _FRWP_ENABLE
    __mpu_enable=1;
    start_protection_offset_address = (fram_rx_start - fram_rw_start) >> 10;
    program_fram_protection = 0x1;
    #ifdef _INFO_FRWP_ENABLE
    info_fram_protection = 0x1;
    #else
    info_fram_protection = 0x0;
    #endif
    #endif
    /* INCLUDE PERIPHERALS MEMORY MAP */
    -l msp430fr2676.cmd
    File *.map:******************************************************************************************************************************************************************************************************************
    MSP430 Linker PC v20.2.1
    >> Linked Mon Feb 1 11:09:35 2021
    OUTPUT FILE NAME: <FR2676_KOHLER_1_7.out>
    ENTRY POINT SYMBOL: "_c_int00_noargs_mpu" address: 0000fce2
    MEMORY CONFIGURATION
    name origin length used unused attr fill
    TINYRAM 00000006 0000001a 00000000 0000001a RWIX
    BSL0 00001000 00000800 00000000 00000800 RWIX
    INFO 00001800 00000200 00000000 00000200 RWIX
    TLVMEM 00001a00 00000200 00000000 00000200 RWIX
    BOOTCODE 00001c00 00000400 00000000 00000400 RWIX
    RAM 00002000 00002000 00000adb 00001525 RWIX
    FRAM 00008000 00007f80 00007d3c 00000244 RWIX
    JTAGSIGNATURE 0000ff80 00000004 00000004 00000000 RWIX ffff
    BSLSIGNATURE 0000ff84 00000004 00000004 00000000 RWIX ffff
    BSLCONFIGURATIONSIGNA 0000ff88 00000002 00000002 00000000 RWIX ffff
    BSLCONFIGURATION 0000ff8a 00000002 00000002 00000000 RWIX ffff
    BSLI2CADDRESS 0000ffa0 00000002 00000002 00000000 RWIX ffff
    INT00 0000ffa2 00000002 00000000 00000002 RWIX
    INT01 0000ffa4 00000002 00000000 00000002 RWIX
    INT02 0000ffa6 00000002 00000000 00000002 RWIX
    INT03 0000ffa8 00000002 00000000 00000002 RWIX
    INT04 0000ffaa 00000002 00000000 00000002 RWIX
    INT05 0000ffac 00000002 00000000 00000002 RWIX
    INT06 0000ffae 00000002 00000000 00000002 RWIX
    INT07 0000ffb0 00000002 00000000 00000002 RWIX
    INT08 0000ffb2 00000002 00000000 00000002 RWIX
    INT09 0000ffb4 00000002 00000000 00000002 RWIX
    INT10 0000ffb6 00000002 00000000 00000002 RWIX
    INT11 0000ffb8 00000002 00000000 00000002 RWIX
    INT12 0000ffba 00000002 00000000 00000002 RWIX
    INT13 0000ffbc 00000002 00000000 00000002 RWIX
    INT14 0000ffbe 00000002 00000000 00000002 RWIX
    INT15 0000ffc0 00000002 00000000 00000002 RWIX
    INT16 0000ffc2 00000002 00000000 00000002 RWIX
    INT17 0000ffc4 00000002 00000000 00000002 RWIX
    INT18 0000ffc6 00000002 00000000 00000002 RWIX
    INT19 0000ffc8 00000002 00000002 00000000 RWIX
    INT20 0000ffca 00000002 00000002 00000000 RWIX
    INT21 0000ffcc 00000002 00000002 00000000 RWIX
    INT22 0000ffce 00000002 00000002 00000000 RWIX
    INT23 0000ffd0 00000002 00000002 00000000 RWIX
    INT24 0000ffd2 00000002 00000002 00000000 RWIX
    INT25 0000ffd4 00000002 00000002 00000000 RWIX
    INT26 0000ffd6 00000002 00000002 00000000 RWIX
    INT27 0000ffd8 00000002 00000002 00000000 RWIX
    INT28 0000ffda 00000002 00000002 00000000 RWIX
    INT29 0000ffdc 00000002 00000002 00000000 RWIX
    INT30 0000ffde 00000002 00000002 00000000 RWIX
    INT31 0000ffe0 00000002 00000002 00000000 RWIX
    INT32 0000ffe2 00000002 00000002 00000000 RWIX
    INT33 0000ffe4 00000002 00000002 00000000 RWIX
    INT34 0000ffe6 00000002 00000002 00000000 RWIX
    INT35 0000ffe8 00000002 00000002 00000000 RWIX
    INT36 0000ffea 00000002 00000002 00000000 RWIX
    INT37 0000ffec 00000002 00000002 00000000 RWIX
    INT38 0000ffee 00000002 00000002 00000000 RWIX
    INT39 0000fff0 00000002 00000002 00000000 RWIX
    INT40 0000fff2 00000002 00000002 00000000 RWIX
    INT41 0000fff4 00000002 00000002 00000000 RWIX
    INT42 0000fff6 00000002 00000002 00000000 RWIX
    INT43 0000fff8 00000002 00000002 00000000 RWIX
    INT44 0000fffa 00000002 00000002 00000000 RWIX
    INT45 0000fffc 00000002 00000002 00000000 RWIX
    RESET 0000fffe 00000002 00000002 00000000 RWIX
    FRAM2 00010000 00008000 00000000 00008000 RWIX
    ROMLIB 000c0000 00004000 00000000 00004000 RWIX
    BSL1 000ffc00 00000400 00000000 00000400 RWIX
    SECTION ALLOCATION MAP
    output attributes/
    section page origin length input sections
    .TI.persistent
    * 0 00008000 00000012
    00008000 00000012 persist.obj (.TI.persistent:xVarFlash)
    .cio 0 00008012 00000000 UNINITIALIZED
    .sysmem 0 00008012 00000000 UNINITIALIZED
    .cinit 0 00008400 000000ec
    00008400 000000c9 (.cinit..data.load) [load image, compression = lzss]
    000084c9 00000001 --HOLE-- [fill = 0]
    000084ca 0000000c (__TI_handler_table)
    000084d6 00000006 (.cinit..bss.load) [load image, compression = zero_init]
    000084dc 00000010 (__TI_cinit_table)
    .pinit 0 000084ec 00000000 UNINITIALIZED
    .binit 0 000084ec 00000000
    .init_array
    * 0 000084ec 00000000 UNINITIALIZED
    .mspabi.exidx
    .mspabi.extab
    .const 0 000084ec 00000328
    000084ec 000000a0 utilbgxdriver.obj (.const:.string)
    0000858c 0000009a sds_batteryManagement.obj (.const:.string)
    00008626 00000096 touch.obj (.const:.string)
    000086bc 0000008a BGX.obj (.const:.string)
    00008746 00000074 TLV493D.obj (.const:.string)
    000087ba 0000001a util.obj (.const:.string)
    000087d4 00000018 CAPT_Interface.obj (.const:g_UARTPort)
    000087ec 00000014 rts430x_lc_ld_eabi.lib : _printfi_min.c.obj (.const:.string)
    00008800 00000014 CAPT_UserConfig.obj (.const:g_EMCConfig)
    .text 0 00008814 00007296
    00008814 00000786 BGX.obj (.text:BGX_Motor)
    00008f9a 0000039a LP5012.obj (.text:LED_LP5012_Alarm_Motor)
    00009334 000002f4 captivate_fr2676_family.lib : CAPT_Calibration.o (.text:CAPT_calibrateBiasCurrentTrim)
    00009628 000002e0 rts430x_lc_ld_eabi.lib : addd.c.obj (.text:__mspabi_addd)
    00009908 000002ca TLV493D.obj (.text:TLV493D_Motor)
    00009bd2 00000298 LP5012.obj (.text:LED_LP5012_Inmediate_Motor)
    00009e6a 00000280 rts430x_lc_ld_eabi.lib : frcmpyd.c.obj (.text:__TI_frcmpyd)
    0000a0ea 00000266 : mpyd.c.obj (.text:__mspabi_mpyd)
    0000a350 00000256 captivate_fr2676_family.lib : CAPT_HAL.o (.text:CAPT_saveCycleResultsAutoMultiFreq)
    0000a5a6 00000248 rts430x_lc_ld_eabi.lib : frcaddd.c.obj (.text:__TI_frcaddd)
    0000a7ee 0000022a captivate_fr2676_family.lib : CAPT_Calibration.o (.text:CAPT_calibrateOffset)
    0000aa18 0000020e Periferico.obj (.text:PER_IscuDriverMotor)
    0000ac26 00000204 eusci_I2C_driver.obj (.text:UCB1_I2C_read)
    0000ae2a 000001ea LP5012.obj (.text:LED_LP5012_Charging_Motor)
    0000b014 000001e6 TLV493D.obj (.text:vReadTLV493D)
    0000b1fa 000001c0 CAPT_Interface.obj (.text:CAPT_accessControllerParameter)
    0000b3ba 000001b6 Periferico.obj (.text:PER_ParseIscuCommand)
    0000b570 000001ac utilbgxdriver.obj (.text:BGXUTIL_parseScanAnswerparseBGXIncomingDataClient)
    0000b71c 00000186 eusci_I2C_driver.obj (.text:UCB0_I2C_write)
    0000b8a2 00000186 eusci_I2C_driver.obj (.text:UCB1_I2C_write)
    0000ba28 00000182 rts430x_lc_ld_eabi.lib : _printfi_min.c.obj (.text:_setfield)
    0000bbaa 0000017e sds_batteryManagement.obj (.text:task_batteryChargingStatus)
    0000bd28 00000154 captivate_fr2676_family.lib : CAPT_Touch.o (.text:CAPT_updateSensorWithEMCAuto)
    0000be7c 0000014a : CAPT_Protocol.o (.text:CAPT_accessSpecialSensorParameter)
    0000bfc6 00000134 : CAPT_EMC.o (.text:CAPT_testConversionFrequencyForNoise)
    0000c0fa 00000132 rts430x_lc_ld_eabi.lib : fs_add.asm.obj (.text)
    0000c22c 0000012a TLV493D.obj (.text:TLV493D_Calibrate)
    0000c356 00000126 touch.obj (.text:TOUCH_BotonMotor)
    0000c47c 00000114 captivate_fr2676_family.lib : CAPT_EMC.o (.text:CAPT_correctInvalidMultiFreqCalibration)
    0000c590 00000104 util.obj (.text:UTIL_calculateGradoDeGiro)
    0000c694 000000fe Periferico.obj (.text:PER_newFrameFromIscu2)
    0000c792 000000fa CAPT_BSP.obj (.text:BSP_configureMCU)
    0000c88c 000000ea CAPT_Interface.obj (.text:CAPT_checkForInboundPacket)
    0000c976 000000e8 TLV493D.obj (.text:TLV493D_PublishSensorChange)
    0000ca5e 000000e6 LP5012.obj (.text:LED_LP5012_ArranqueAcabado)
    0000cb44 000000e4 rts430x_lc_ld_eabi.lib : _printfi_min.c.obj (.text:__TI_printfi_minimal)
    0000cc28 000000da driverlib_fr2676_family.lib : cs.o (.text:CS_initClockSignal)
    0000cd02 000000da rts430x_lc_ld_eabi.lib : _printfi_min.c.obj (.text:_pproc_diouxp)
    0000cddc 000000d2 Periferico.obj (.text:PER_KeyBoardEvent)
    0000ceae 000000c8 sds_gpio.obj (.text:NTmbatteryStatus)
    0000cf76 000000c4 driverlib_fr2676_family.lib : cs.o (.text:CS_initFLL)
    0000d03a 000000c2 utilbgxdriver.obj (.text:BGXUTIL_calculaKey)
    0000d0fc 000000c0 LP5012.obj (.text:LP5012_led_color_basic)
    0000d1bc 000000b8 CAPT_Manager.obj (.text:CAPT_updateUI)
    0000d274 000000b8 util.obj (.text:UTIL_calculateGradoDeGiro2)
    0000d32c 000000b8 rts430x_lc_ld_eabi.lib : fs_mpy.asm.obj (.text)
    0000d3e4 000000b6 captivate_fr2676_family.lib : CAPT_Calibration.o (.text:CAPT_calibrateSensorWithEMC)
    0000d49a 000000b4 touch.obj (.text:BTN00_callback)
    0000d54e 000000b2 rts430x_lc_ld_eabi.lib : renormd.c.obj (.text:__TI_renormd)
    0000d600 000000ae BGX.obj (.text:BGX_sendPassword)
    0000d6ae 000000a4 timer.obj (.text:SetTimer)
    0000d752 000000a2 CAPT_Interface.obj (.text:CAPT_writeElementData)
    0000d7f4 000000a2 LP5012.obj (.text:LED_LP5012_ButtonPressed)
    0000d896 0000009e sds_batteryManagement.obj (.text:task_batteryLevelStatus)
    0000d934 00000098 UART.obj (.text:UART_openPort)
    0000d9cc 00000090 util.obj (.text:UTIL_hexBufferToHexString)
    0000da5c 00000090 rts430x_lc_ld_eabi.lib : fs_div.asm.obj (.text)
    0000daec 0000008e touch.obj (.text:singlePressed)
    0000db7a 0000008a LP5012.obj (.text:LP5012_Init)
    0000dc04 00000088 CAPT_Manager.obj (.text:CAPT_initUI)
    0000dc8c 00000086 Periferico.obj (.text:PER_BuildFrameToIscu)
    0000dd12 00000080 rts430x_lc_ld_eabi.lib : fltuld.c.obj (.text:__mspabi_fltuld)
    0000dd92 00000078 captivate_fr2676_family.lib : CAPT_Touch.o (.text:CAPT_initSensor)
    0000de0a 00000078 rts430x_lc_ld_eabi.lib : autoinit.c.obj (.text:__TI_auto_init_nobinit_nopinit_hold_wdt:__TI_auto_init_nobinit_nopinit_hold_wdt)
    0000de82 00000076 LP5012.obj (.text:LED_LP012_LedBlink)
    0000def8 00000076 util.obj (.text:UTIL_ulitoad)
    0000df6e 00000076 rts430x_lc_ld_eabi.lib : copy_decompress_lzss.c.obj (.text:decompress:lzss:__TI_decompress_lzss)
    0000dfe4 00000074 BGX.obj (.text:BGX_sendCommand)
    0000e058 00000074 CAPT_Interface.obj (.text:CAPT_writeSensorData)
    0000e0cc 0000006c util.obj (.text:UTIL_CalculaCRC)
    0000e138 0000006a captivate_fr2676_family.lib : CAPT_Touch.o (.text:CAPT_processFSMCycle)
    0000e1a2 0000006a : CAPT_Touch.o (.text:CAPT_processSensor)
    0000e20c 00000068 rts430x_lc_ld_eabi.lib : fixdul.c.obj (.text:__mspabi_fixdul)
    0000e274 00000068 : fs_toi.asm.obj (.text)
    0000e2dc 00000066 timer.obj (.text:InitTimerService)
    0000e342 00000064 UART.obj (.text:UART_transmitBuffer)
    0000e3a6 00000062 main.obj (.text:main)
    0000e408 00000060 LP5012.obj (.text:LP5012_led_brightness)
    0000e468 00000060 timer.obj (.text:TimerIntProc)
    0000e4c8 0000005e LP5012.obj (.text:LP5012_config1)
    0000e526 0000005c CAPT_Interface.obj (.text:CAPT_initCommInterface)
    0000e582 00000058 BGX.obj (.text:BGXSendCommand)
    0000e5da 00000058 captivate_fr2676_family.lib : CAPT_ByteQueue.o (.text:CAPT_pushOntoByteQueue)
    0000e632 00000058 DRV_UART1.obj (.text:DRV_UART1_Init)
    0000e68a 00000058 rts430x_lc_ld_eabi.lib : div32u.asm.obj (.text)
    0000e6e2 00000056 persist.obj (.text:PERSIST_GetMagneticSensorCalibrationParams)
    0000e738 00000056 Periferico.obj (.text:PER_sendACK)
    0000e78e 00000054 persist.obj (.text:PERSIST_SetMagneticSensorCalibrationParams)
    0000e7e2 00000054 sds_batteryManagement.obj (.text:task_batteryManagement)
    0000e836 00000052 TLV493D.obj (.text:TLV493D_Ini)
    0000e888 00000050 BGX.obj (.text:BGX_sendDebugMsg)
    0000e8d8 0000004e captivate_fr2676_family.lib : CAPT_EMC.o (.text:CAPT_getEMCConversionSettings)
    0000e926 0000004e : CAPT_Touch.o (.text:CAPT_preProcessSlider)
    0000e974 0000004e : CAPT_HAL.o (.text:CAPT_selectInputImpedanceBiasCurrentTrim)
    0000e9c2 0000004e rts430x_lc_ld_eabi.lib : strncpy.c.obj (.text:strncpy)
    0000ea10 0000004a LP5012.obj (.text:LP5012_led_bank_enable)
    0000ea5a 0000004a touch.obj (.text:continuoslyPressed)
    0000eaa4 0000004a rts430x_lc_ld_eabi.lib : fs_cmp.asm.obj (.text)
    0000eaee 00000048 DRV_UART1.obj (.text:DRV_UART1_Transmit)
    0000eb36 00000048 rts430x_lc_ld_eabi.lib : _printfi_min.c.obj (.text:_pproc_str)
    0000eb7e 00000044 CAPT_App.obj (.text:CAPT_appHandler)
    0000ebc2 00000044 CAPT_App.obj (.text:CAPT_appStart)
    0000ec06 00000044 CAPT_Manager.obj (.text:CAPT_getGlobalUIProximityStatus)
    0000ec4a 00000044 TLV493D.obj (.text:TLV493D_PowerDown)
    0000ec8e 00000044 rts430x_lc_ld_eabi.lib : sprintf.c.obj (.text:sprintf)
    0000ecd2 0000003e captivate_fr2676_family.lib : CAPT_Calibration.o (.text:CAPT_calibrateSensor)
    0000ed10 0000003e driverlib_fr2676_family.lib : cs.o (.text:CS_turnOnXT1LFWithTimeout)
    0000ed4e 0000003e Periferico.obj (.text:PER_setMagneticSensorValues)
    0000ed8c 0000003e TLV493D.obj (.text:TLV493D_ReadRegisterValues)
    0000edca 0000003e rts430x_lc_ld_eabi.lib : asr32.asm.obj (.text:l_asr_const)
    0000ee08 0000003e : lsl32.asm.obj (.text:l_lsl_const)
    0000ee46 0000003e : lsr32.asm.obj (.text:l_lsr_const)
    0000ee84 0000003c sds_gpio.obj (.text:ADC_CH1_init)
    0000eec0 0000003c DRV_UART1.obj (.text:DRV_UART1_Send)
    0000eefc 0000003c FRWP_INIT_LIB_CCS_msp430_large_code_large_data.lib : frwp_init.obj (.text:__mpu_init)
    0000ef38 0000003c util.obj (.text:getUnidadesGradoAngular)
    0000ef74 0000003c rts430x_lc_ld_eabi.lib : memcpy.c.obj (.text:memcpy)
    0000efb0 0000003c sds_main.obj (.text:sds_main)
    0000efec 0000003c rts430x_lc_ld_eabi.lib : strstr.c.obj (.text:strstr)
    0000f028 0000003a BGX.obj (.text:BGX_sendFAC)
    0000f062 0000003a TLV493D.obj (.text:TLV493D_CalibratePoint)
    0000f09c 00000038 CAPT_Manager.obj (.text:CAPT_calibrateUI)
    0000f0d4 00000038 rts430x_lc_ld_eabi.lib : strncmp.c.obj (.text:strncmp)
    0000f10c 00000038 touch.obj (.text:updateButtons)
    0000f144 00000036 rts430x_lc_ld_eabi.lib : fs_itof.asm.obj (.text)
    0000f17a 00000034 BGX.obj (.text:BGX_Init)
    0000f1ae 00000034 rts430x_lc_ld_eabi.lib : memccpy.c.obj (.text:memccpy)
    0000f1e2 00000034 sds_main.obj (.text:sds_init)
    0000f216 00000032 sds_gpio.obj (.text:NTmLedBF)
    0000f248 00000030 LP5012.obj (.text:LP5012_ActivaColorEnTodosLosLeds)
    0000f278 00000030 util.obj (.text:UTIL_StartsWith)
    0000f2a8 0000002e CAPT_App.obj (.text:CAPT_appSleep)
    0000f2d6 0000002c LP5012.obj (.text:LP5012_mode)
    0000f302 0000002c timer.obj (.text:TICKS_DifTicks)
    0000f32e 0000002c util.obj (.text:UTIL_Delay)
    0000f35a 0000002c rts430x_lc_ld_eabi.lib : div16s.asm.obj (.text)
    0000f386 0000002a BGX.obj (.text:BGX_ClearRxData)
    0000f3b0 0000002a BGX.obj (.text:BGX_sendSetDeviceName)
    0000f3da 0000002a LP5012.obj (.text:LED_LP5012_ApagaTodosLeds)
    0000f404 00000028 captivate_fr2676_family.lib : CAPT_ByteQueue.o (.text:CAPT_isByteQueueFull)
    0000f42c 00000028 rts430x_lc_ld_eabi.lib : sprintf.c.obj (.text:_outs)
    0000f454 00000026 LP5012.obj (.text:LED_LP5012_SetRegisterValue)
    0000f47a 00000026 util.obj (.text:UTIL_StringContains)
    0000f4a0 00000026 util.obj (.text:UTIL_sulitoad)
    0000f4c6 00000024 captivate_fr2676_family.lib : CAPT_HAL.o (.text:CAPT_init)
    0000f4ea 00000024 timer.obj (.text:HdInitTimerService)
    0000f50e 00000024 rts430x_lc_ld_eabi.lib : copy_zero_init.c.obj (.text:decompress:ZI:__TI_zero_init)
    0000f532 00000024 sds_gpio.obj (.text:getBatteryLevel_init)
    0000f556 00000024 rts430x_lc_ld_eabi.lib : mult32_f5hw.asm.obj (.text)
    0000f57a 00000022 TLV493D.obj (.text:TLV493D_GetYCoordinates)
    0000f59c 00000022 UART.obj (.text:UART_closePort)
    0000f5be 00000022 sds_gpio.obj (.text:task_ledBF_init)
    0000f5e0 00000020 timer.obj (.text:ArmTimer)
    0000f600 00000020 captivate_fr2676_family.lib : CAPT_Touch.o (.text:CAPT_testForMaxCountRecalibration)
    0000f620 00000020 Periferico.obj (.text:PER_Init)
    0000f640 00000020 rts430x_lc_ld_eabi.lib : memset.c.obj (.text:memset)
    0000f660 0000001e driverlib_fr2676_family.lib : cs.o (.text:CS_clearAllOscFlagsWithTimeout)
    0000f67e 0000001e sds_gpio.obj (.text:enableBLE)
    0000f69c 0000001e sds_gpio.obj (.text:enableLeds)
    0000f6ba 0000001e touch.obj (.text:task_touch_init)
    0000f6d8 0000001c captivate_fr2676_family.lib : CAPT_Protocol.o (.text:CAPT_getChecksum)
    0000f6f4 0000001c : CAPT_EMC.o (.text:CAPT_loadEMCConfig)
    0000f710 0000001c LP5012.obj (.text:LED_LP5012_Motor)
    0000f72c 0000001c timer.obj (.text:TICKS_GetTicks)
    0000f748 0000001c eusci_I2C_driver.obj (.text:UCB1_MasterI2C_init)
    0000f764 0000001a captivate_fr2676_family.lib : CAPT_HAL.o (.text:CAPT_selectInputImpedanceBiasCurrent)
    0000f77e 0000001a sds_gpio.obj (.text:enableDevicesPower)
    0000f798 0000001a sds_gpio.obj (.text:enableSensorMagentico2)
    0000f7b2 0000001a sds_gpio.obj (.text:resetBLE)
    0000f7cc 0000001a sds_gpio.obj (.text:setSDA_UCB1)
    0000f7e6 00000018 captivate_fr2676_family.lib : CAPT_Touch.o (.text:CAPT_testForNegativeTouchRecalibration)
    0000f7fe 00000018 LP5012.obj (.text:LP5012_reset)
    0000f816 00000018 persist.obj (.text:PERSIST_BGXConfigured)
    0000f82e 00000018 rts430x_lc_ld_eabi.lib : mult16_f5hw.asm.obj (.text)
    0000f846 00000016 CAPT_Interface.obj (.text:CAPT_UARTReceiveHandler)
    0000f85c 00000016 DRV_UART1.obj (.text:DRV_UART1_ClearRxData)
    0000f872 00000016 driverlib_fr2676_family.lib : framctl.o (.text:FRAMCtl_configureWaitStateControl)
    0000f888 00000016 eusci_I2C_driver.obj (.text:UCB0_MasterI2C_init)
    0000f89e 00000016 rts430x_lc_ld_eabi.lib : copy_decompress_none.c.obj (.text:decompress:none:__TI_decompress_none)
    0000f8b4 00000016 : div16u.asm.obj (.text)
    0000f8ca 00000014 sds_gpio.obj (.text:ADC_CH1_getValue)
    0000f8de 00000014 rts430x_lc_ld_eabi.lib : sprintf.c.obj (.text:_outc)
    0000f8f2 00000012 CAPT_Interface.obj (.text:CAPT_checkForRecalibrationRequest)
    0000f904 00000012 persist.obj (.text:PERSIST_BGXNotConfigured)
    0000f916 00000012 rts430x_lc_ld_eabi.lib : fixdu.c.obj (.text:__mspabi_fixdu)
    0000f928 00000012 : strcpy.c.obj (.text:strcpy)
    0000f93a 00000012 : strlen.c.obj (.text:strlen)
    0000f94c 00000010 BGX.obj (.text:BGX_isConnected)
    0000f95c 00000010 DRV_UART1.obj (.text:DRV_UART1_GetByteFromRXBuffer)
    0000f96c 00000010 rts430x_lc_ld_eabi.lib : asr32.asm.obj (.text:l_asr)
    0000f97c 00000010 : lsl32.asm.obj (.text:l_lsl)
    0000f98c 00000010 : lsr32.asm.obj (.text:l_lsr)
    0000f99c 0000000e BGX.obj (.text:BGX_ConfigAction)
    0000f9aa 0000000e LP5012.obj (.text:LP5012_DisableWarningFlushConfirmation)
    0000f9b8 0000000e TLV493D.obj (.text:TLV493D_Reset)
    0000f9c6 0000000c captivate_fr2676_family.lib : CAPT_HAL.o (.text:CAPT_selectElectrodeChargeVoltageSource)
    0000f9d2 0000000c LP5012.obj (.text:LP5012_DisWarningUnLinked)
    0000f9de 0000000a captivate_fr2676_family.lib : CAPT_Buttons.o (.text:CAPT_getDominantButton)
    0000f9e8 0000000a : CAPT_HAL.o (.text:CAPT_getInputImpedanceBiasCurrent)
    0000f9f2 0000000a driverlib_fr2676_family.lib : cs.o (.text:CS_setExternalClockSource)
    0000f9fc 0000000a CAPT_BSP.obj (.text:_system_pre_init)
    0000fa06 0000000a rts430x_lc_ld_eabi.lib : abs.c.obj (.text:abs)
    0000fa10 0000000a : lsl16.asm.obj (.text)
    0000fa1a 0000000a LP5012.obj (.text:setChargeLed)
    0000fa24 0000000a touch.obj (.text:task_touch)
    0000fa2e 00000008 captivate_fr2676_family.lib : CAPT_HAL.o (.text:CAPT_clearInputImpedanceBiasCurrent)
    0000fa36 00000008 LP5012.obj (.text:LP5012_EnableWarningFlushConfirmation)
    0000fa3e 00000008 TLV493D.obj (.text:TLV493D_task_init)
    0000fa46 00000006 captivate_fr2676_family.lib : CAPT_HAL.o (.text:CAPT_getInterruptVector)
    0000fa4c 00000006 : CAPT_Touch.o (.text:CAPT_registerCallback)
    0000fa52 00000006 DRV_UART1.obj (.text:DRV_UART1_GetNumRXBytes)
    0000fa58 00000006 LP5012.obj (.text:LED_LP5012_RxShowerStatus)
    0000fa5e 00000006 LP5012.obj (.text:LP5012_EnableAlarm)
    0000fa64 00000006 LP5012.obj (.text:LP5012_EnableWarningLinkRequest)
    0000fa6a 00000006 LP5012.obj (.text:LP5012_EnableWarningUnLinked)
    0000fa70 00000006 persist.obj (.text:PERSIST_IsBGXConfigured)
    0000fa76 00000006 Periferico.obj (.text:PER_getLastCommandSent)
    0000fa7c 00000006 sistema.obj (.text:SIS_Init)
    0000fa82 00000006 eusci_I2C_driver.obj (.text:UCB1_MasterI2C_deinit)
    0000fa88 00000006 rts430x_lc_ld_eabi.lib : fltud.c.obj (.text:__mspabi_fltud)
    0000fa8e 00000006 : exit.c.obj (.text:abort)
    0000fa94 00000006 sds_gpio.obj (.text:batteryCheckStatus)
    0000fa9a 00000006 sds_gpio.obj (.text:getBatteryLevel)
    0000faa0 00000006 sds_batteryManagement.obj (.text:task_batteryManagement_init)
    0000faa6 00000002 persist.obj (.text:PERSIST_Init)
    0000faa8 00000002 rts430x_lc_ld_eabi.lib : startup.c.obj (.text:_system_post_cinit)
    .text:_isr
    * 0 0000faaa 00000292
    0000faaa 00000124 UART.obj (.text:_isr:UART_ISR)
    0000fbce 00000078 DRV_UART1.obj (.text:_isr:USCI_A1_ISR)
    0000fc46 00000044 CAPT_ISR.obj (.text:_isr:CAPT_ISR)
    0000fc8a 00000038 sds_gpio.obj (.text:_isr:ADC_ISR)
    0000fcc2 00000020 timer.obj (.text:_isr:Timer_A)
    0000fce2 00000020 rts430x_lc_ld_eabi.lib : boot.c.obj (.text:_isr:_c_int00_noargs_mpu)
    0000fd02 0000001c main.obj (.text:_isr:WDT_ISR)
    0000fd1e 00000016 main.obj (.text:_isr:RTC_ISR)
    0000fd34 00000008 rts430x_lc_ld_eabi.lib : isr_trap.asm.obj (.text:_isr:__TI_ISR_TRAP)
    .bss 0 00002000 000008b1 UNINITIALIZED
    00002000 00000162 (.common:BGXstruct)
    00002162 00000156 (.common:xRegGlobal)
    000022b8 00000140 timer.obj (.bss:timer)
    000023f8 00000100 CAPT_Interface.obj (.bss:g_ui8QueueBuffer)
    000024f8 00000088 (.common:xRegTLV493D)
    00002580 00000078 (.common:xRegIscDrv)
    000025f8 00000064 DRV_UART1.obj (.bss:SerialRxData)
    0000265c 0000003a (.common:xRegTouch)
    00002696 00000030 CAPT_Interface.obj (.bss:g_ui8TransmitBuffer_ping)
    000026c6 00000030 CAPT_Interface.obj (.bss:g_ui8TransmitBuffer_pong)
    000026f6 0000002c (.common:xRegInmediate)
    00002722 0000002c (.common:xRegLeds)
    0000274e 0000001e (.common:xRegCharging)
    0000276c 0000001a timer.obj (.bss)
    00002786 00000012 sds_gpio.obj (.bss)
    00002798 00000012 (.common:xRegArranque)
    000027aa 00000011 sds_batteryManagement.obj (.bss)
    000027bb 00000001 touch.obj (.bss)
    000027bc 00000010 (.common:BTN00_E00_Tuning)
    000027cc 00000010 (.common:BTN00_E01_Tuning)
    000027dc 00000010 (.common:BTN00_E02_Tuning)
    000027ec 00000010 (.common:BTN00_E03_Tuning)
    000027fc 0000000c CAPT_Interface.obj (.bss:g_parameterPacket)
    00002808 0000000c (.common:xRegAlarm)
    00002814 0000000a TLV493D.obj (.bss:bufRead)
    0000281e 0000000a CAPT_Interface.obj (.bss:g_ReceiveQueue)
    00002828 0000000a (.common:BTN00_Params)
    00002832 00000008 DRV_UART1.obj (.bss)
    0000283a 00000008 CAPT_Interface.obj (.bss:g_PingPongBuffer)
    00002842 00000008 (.common:BTN00_E00_RawCnts)
    0000284a 00000008 (.common:BTN00_E01_RawCnts)
    00002852 00000008 (.common:BTN00_E02_RawCnts)
    0000285a 00000008 (.common:BTN00_E03_RawCnts)
    00002862 00000008 (.common:xRegAux)
    0000286a 00000006 CAPT_Interface.obj (.bss)
    00002870 00000006 TLV493D.obj (.bss)
    00002876 00000006 (.common:swB)
    0000287c 00000004 BGX.obj (.bss)
    00002880 00000004 TLV493D.obj (.bss:bufWrite)
    00002884 00000004 eusci_I2C_driver.obj (.bss)
    00002888 00000004 main.obj (.bss)
    0000288c 00000004 sds_main.obj (.bss)
    00002890 00000004 (.common:g_filteredGlobalNoiseLevel)
    00002894 00000004 (.common:g_pHighestNoiseElement)
    00002898 00000004 (.common:g_pUARTPort)
    0000289c 00000004 (.common:g_pUARTTransmitPtr)
    000028a0 00000004 (.common:utilDelay)
    000028a4 00000002 CAPT_Interface.obj (.bss:g_protocolProcessingVars)
    000028a6 00000002 (.common:g_ui16UARTTransmitBytesLeft)
    000028a8 00000002 (.common:iborra)
    000028aa 00000001 (.common:RXData)
    000028ab 00000001 (.common:g_UARTStatus)
    000028ac 00000001 (.common:g_bConvCounterFlag)
    000028ad 00000001 (.common:g_bConvTimerFlag)
    000028ae 00000001 (.common:g_bDetectionFlag)
    000028af 00000001 (.common:g_bEndOfConversionFlag)
    000028b0 00000001 (.common:g_bMaxCountErrorFlag)
    .data 0 000028b2 0000012a UNINITIALIZED
    000028b2 00000024 CAPT_UserConfig.obj (.data:BTN00)
    000028d6 0000001e CAPT_UserConfig.obj (.data:BTN00_E00)
    000028f4 0000001e CAPT_UserConfig.obj (.data:BTN00_E01)
    00002912 0000001e CAPT_UserConfig.obj (.data:BTN00_E02)
    00002930 0000001e CAPT_UserConfig.obj (.data:BTN00_E03)
    0000294e 00000018 util.obj (.data:vGradosDeGiroS1)
    00002966 00000018 util.obj (.data:vGradosDeGiroS2)
    0000297e 00000010 CAPT_UserConfig.obj (.data:BTN00_Cycles)
    0000298e 00000010 CAPT_UserConfig.obj (.data:g_uiApp)
    0000299e 00000006 CAPT_UserConfig.obj (.data:BTN00_C00)
    000029a4 00000006 CAPT_UserConfig.obj (.data:BTN00_C01)
    000029aa 00000006 CAPT_UserConfig.obj (.data:BTN00_C02)
    000029b0 00000006 CAPT_UserConfig.obj (.data:BTN00_C03)
    000029b6 00000005 TLV493D.obj (.data)
    000029bb 00000001 CAPT_App.obj (.data)
    000029bc 00000004 CAPT_UserConfig.obj (.data:BTN00_C00_Elements)
    000029c0 00000004 CAPT_UserConfig.obj (.data:BTN00_C01_Elements)
    000029c4 00000004 CAPT_UserConfig.obj (.data:BTN00_C02_Elements)
    000029c8 00000004 CAPT_UserConfig.obj (.data:BTN00_C03_Elements)
    000029cc 00000004 Periferico.obj (.data)
    000029d0 00000004 captivate_fr2676_family.lib : CAPT_EMC.o (.data)
    000029d4 00000004 driverlib_fr2676_family.lib : cs.o (.data)
    000029d8 00000004 CAPT_UserConfig.obj (.data:g_pCaptivateSensorArray)
    .stack 0 00003f00 00000100 UNINITIALIZED
    00003f00 00000004 rts430x_lc_ld_eabi.lib : boot.c.obj (.stack)
    00003f04 000000fc --HOLE--
    CAPTIVATE
    * 0 0000ffc8 00000002
    0000ffc8 00000002 CAPT_ISR.obj (.int19)
    ECOMP0 0 0000ffca 00000002
    0000ffca 00000002 rts430x_lc_ld_eabi.lib : int20.asm.obj (.int20)
    PORT6 0 0000ffcc 00000002
    0000ffcc 00000002 rts430x_lc_ld_eabi.lib : int21.asm.obj (.int21)
    PORT5 0 0000ffce 00000002
    0000ffce 00000002 rts430x_lc_ld_eabi.lib : int22.asm.obj (.int22)
    PORT4 0 0000ffd0 00000002
    0000ffd0 00000002 rts430x_lc_ld_eabi.lib : int23.asm.obj (.int23)
    PORT3 0 0000ffd2 00000002
    0000ffd2 00000002 rts430x_lc_ld_eabi.lib : int24.asm.obj (.int24)
    PORT2 0 0000ffd4 00000002
    0000ffd4 00000002 rts430x_lc_ld_eabi.lib : int25.asm.obj (.int25)
    PORT1 0 0000ffd6 00000002
    0000ffd6 00000002 rts430x_lc_ld_eabi.lib : int26.asm.obj (.int26)
    ADC 0 0000ffd8 00000002
    0000ffd8 00000002 sds_gpio.obj (.int27)
    EUSCI_B1 0 0000ffda 00000002
    0000ffda 00000002 rts430x_lc_ld_eabi.lib : int28.asm.obj (.int28)
    EUSCI_B0 0 0000ffdc 00000002
    0000ffdc 00000002 rts430x_lc_ld_eabi.lib : int29.asm.obj (.int29)
    EUSCI_A1 0 0000ffde 00000002
    0000ffde 00000002 DRV_UART1.obj (.int30)
    EUSCI_A0 0 0000ffe0 00000002
    0000ffe0 00000002 UART.obj (.int31)
    WDT 0 0000ffe2 00000002
    0000ffe2 00000002 main.obj (.int32)
    RTC 0 0000ffe4 00000002
    0000ffe4 00000002 main.obj (.int33)
    TIMER0_B1
    * 0 0000ffe6 00000002
    0000ffe6 00000002 rts430x_lc_ld_eabi.lib : int34.asm.obj (.int34)
    TIMER0_B0
    * 0 0000ffe8 00000002
    0000ffe8 00000002 rts430x_lc_ld_eabi.lib : int35.asm.obj (.int35)
    TIMER3_A1
    * 0 0000ffea 00000002
    0000ffea 00000002 rts430x_lc_ld_eabi.lib : int36.asm.obj (.int36)
    TIMER3_A0
    * 0 0000ffec 00000002
    0000ffec 00000002 rts430x_lc_ld_eabi.lib : int37.asm.obj (.int37)
    TIMER2_A1
    * 0 0000ffee 00000002
    0000ffee 00000002 rts430x_lc_ld_eabi.lib : int38.asm.obj (.int38)
    TIMER2_A0
    * 0 0000fff0 00000002
    0000fff0 00000002 rts430x_lc_ld_eabi.lib : int39.asm.obj (.int39)
    TIMER1_A1
    * 0 0000fff2 00000002
    0000fff2 00000002 rts430x_lc_ld_eabi.lib : int40.asm.obj (.int40)
    TIMER1_A0
    * 0 0000fff4 00000002
    0000fff4 00000002 rts430x_lc_ld_eabi.lib : int41.asm.obj (.int41)
    TIMER0_A1
    * 0 0000fff6 00000002
    0000fff6 00000002 rts430x_lc_ld_eabi.lib : int42.asm.obj (.int42)
    TIMER0_A0
    * 0 0000fff8 00000002
    0000fff8 00000002 timer.obj (.int43)
    UNMI 0 0000fffa 00000002
    0000fffa 00000002 rts430x_lc_ld_eabi.lib : int44.asm.obj (.int44)
    SYSNMI 0 0000fffc 00000002
    0000fffc 00000002 rts430x_lc_ld_eabi.lib : int45.asm.obj (.int45)
    .reset 0 0000fffe 00000002
    0000fffe 00000002 rts430x_lc_ld_eabi.lib : boot.c.obj (.reset)
    $fill000 0 0000ff80 00000004
    0000ff80 00000004 --HOLE-- [fill = ffff]
    $fill001 0 0000ff84 00000004
    0000ff84 00000004 --HOLE-- [fill = ffff]
    $fill002 0 0000ff88 00000002
    0000ff88 00000002 --HOLE-- [fill = ffff]
    $fill003 0 0000ff8a 00000002
    0000ff8a 00000002 --HOLE-- [fill = ffff]
    $fill004 0 0000ffa0 00000002
    0000ffa0 00000002 --HOLE-- [fill = ffff]
    MODULE SUMMARY
    Module code ro data rw data
    main.obj 148 4 4
    Total: 148 4 4
    .\captivate\ADVANCED\
    CAPT_Manager.obj 444 0 0
    Total: 444 0 0
    .\captivate\BASE\
    CAPT_ISR.obj 68 2 5
    Total: 68 2 5
    .\captivate\COMM\
    CAPT_Interface.obj 1092 24 390
    UART.obj 578 2 11
    Total: 1670 26 401
    .\captivate_app\
    CAPT_BSP.obj 260 0 0
    CAPT_App.obj 182 0 1
    Total: 442 0 1
    .\captivate_config\
    CAPT_UserConfig.obj 0 20 338
    Total: 0 20 338
    .\sedal\
    sds_main.obj 112 0 4
    Total: 112 0 4
    .\sedal\BGX_BTH\
    BGX.obj 2608 138 358
    utilbgxdriver.obj 622 160 0
    Total: 3230 298 358
    .\sedal\Bateria\
    sds_batteryManagement.obj 630 154 17
    Total: 630 154 17
    .\sedal\I2CMaster\
    eusci_I2C_driver.obj 1352 0 4
    Total: 1352 0 4
    .\sedal\Led_I2C_LP5012\
    LP5012.obj 3472 0 156
    Total: 3472 0 156
    .\sedal\MagSensor_I2C_TLV493D\
    TLV493D.obj 2056 116 167
    Total: 2056 116 167
    .\sedal\gpio\
    sds_gpio.obj 632 2 18
    Total: 632 2 18
    .\sedal\periferico\
    Periferico.obj 1748 0 126
    Total: 1748 0 126
    .\sedal\persistencia\
    persist.obj 220 0 18
    Total: 220 0 18
    .\sedal\serialPort\
    DRV_UART1.obj 384 2 109
    Total: 384 2 109
    .\sedal\sistema\
    sistema.obj 6 0 342
    Total: 6 0 342
    .\sedal\timer\
    timer.obj 534 2 346
    Total: 534 2 346
    .\sedal\touch\
    touch.obj 786 150 59
    Total: 786 150 59
    .\sedal\util\
    util.obj 1042 26 52
    Total: 1042 26 52
    ../captivate/BASE/libraries/captivate_fr2676_family.lib
    CAPT_Calibration.o 1554 0 0
    CAPT_Touch.o 812 0 0
    CAPT_HAL.o 774 0 0
    CAPT_EMC.o 690 0 12
    CAPT_Protocol.o 358 0 0
    CAPT_ByteQueue.o 128 0 0
    CAPT_Buttons.o 10 0 0
    Total: 4326 0 12
    ../driverlib/MSP430FR2xx_4xx/libraries/driverlib_fr2676_family.lib
    cs.o 516 0 4
    framctl.o 22 0 0
    Total: 538 0 4
    C:\ti\ccs1010\ccs\ccs_base\msp430\lib\FR2xx\FRWP_INIT_LIB_CCS_msp430_large_code_large_data.lib
    frwp_init.obj 60 0 0
    Total: 60 0 0
    C:\ti\ccs1010\ccs\tools\compiler\ti-cgt-msp430_20.2.1.LTS\lib\rts430x_lc_ld_eabi.lib
    _printfi_min.c.obj 904 20 0
    addd.c.obj 736 0 0
    frcmpyd.c.obj 640 0 0
    mpyd.c.obj 614 0 0
    frcaddd.c.obj 584 0 0
    fs_add.asm.obj 306 0 0
    fs_mpy.asm.obj 184 0 0
    renormd.c.obj 178 0 0
    fs_div.asm.obj 144 0 0
    fltuld.c.obj 128 0 0
    sprintf.c.obj 128 0 0
    autoinit.c.obj 120 0 0
    copy_decompress_lzss.c.obj 118 0 0
    fixdul.c.obj 104 0 0
    fs_toi.asm.obj 104 0 0
    div32u.asm.obj 88 0 0
    asr32.asm.obj 78 0 0
    lsl32.asm.obj 78 0 0
    lsr32.asm.obj 78 0 0
    strncpy.c.obj 78 0 0
    fs_cmp.asm.obj 74 0 0
    memcpy.c.obj 60 0 0
    strstr.c.obj 60 0 0
    strncmp.c.obj 56 0 0
    fs_itof.asm.obj 54 0 0
    memccpy.c.obj 52 0 0
    div16s.asm.obj 44 0 0
    copy_zero_init.c.obj 36 0 0
    mult32_f5hw.asm.obj 36 0 0
    boot.c.obj 32 2 0
    memset.c.obj 32 0 0
    mult16_f5hw.asm.obj 24 0 0
    copy_decompress_none.c.obj 22 0 0
    div16u.asm.obj 22 0 0
    fixdu.c.obj 18 0 0
    strcpy.c.obj 18 0 0
    strlen.c.obj 18 0 0
    abs.c.obj 10 0 0
    lsl16.asm.obj 10 0 0
    isr_trap.asm.obj 8 0 0
    exit.c.obj 6 0 0
    fltud.c.obj 6 0 0
    int20.asm.obj 0 2 0
    int21.asm.obj 0 2 0
    int22.asm.obj 0 2 0
    int23.asm.obj 0 2 0
    int24.asm.obj 0 2 0
    int25.asm.obj 0 2 0
    int26.asm.obj 0 2 0
    int28.asm.obj 0 2 0
    int29.asm.obj 0 2 0
    int34.asm.obj 0 2 0
    int35.asm.obj 0 2 0
    int36.asm.obj 0 2 0
    int37.asm.obj 0 2 0
    int38.asm.obj 0 2 0
    int39.asm.obj 0 2 0
    int40.asm.obj 0 2 0
    int41.asm.obj 0 2 0
    int42.asm.obj 0 2 0
    int44.asm.obj 0 2 0
    int45.asm.obj 0 2 0
    startup.c.obj 2 0 0
    Total: 6092 62 0
    Stack: 0 0 256
    Linker Generated: 0 235 0
    Grand Total: 29992 1099 2797
    LINKER GENERATED COPY TABLES
    __TI_cinit_table @ 000084dc records: 2, size/record: 8, table size: 16
    .data: load addr=00008400, load size=000000c9 bytes, run addr=000028b2, run size=0000012a bytes, compression=lzss
    .bss: load addr=000084d6, load size=00000006 bytes, run addr=00002000, run size=000008b1 bytes, compression=zero_init
    LINKER GENERATED HANDLER TABLE
    __TI_handler_table @ 000084ca records: 3, size/record: 4, table size: 12
    index: 0, handler: __TI_zero_init
    index: 1, handler: __TI_decompress_lzss
    index: 2, handler: __TI_decompress_none
    GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
    address name
    00000700 ADCCTL0
    00000701 ADCCTL0_H
    00000700 ADCCTL0_L
    00000702 ADCCTL1
    00000703 ADCCTL1_H
    00000702 ADCCTL1_L
    00000704 ADCCTL2
    00000705 ADCCTL2_H
    00000704 ADCCTL2_L
    00000708 ADCHI
    00000709 ADCHI_H
    00000708 ADCHI_L
    0000071a ADCIE
    0000071b ADCIE_H
    0000071a ADCIE_L
    0000071c ADCIFG
    0000071d ADCIFG_H
    0000071c ADCIFG_L
    0000071e ADCIV
    0000071f ADCIV_H
    0000071e ADCIV_L
    00000706 ADCLO
    00000707 ADCLO_H
    00000706 ADCLO_L
    0000070a ADCMCTL0
    0000070b ADCMCTL0_H
    0000070a ADCMCTL0_L
    00000712 ADCMEM0
    00000713 ADCMEM0_H
    00000712 ADCMEM0_L
    0000f8ca ADC_CH1_getValue
    0000ee84 ADC_CH1_init
    0000fc8a ADC_ISR
    0000f5e0 ArmTimer
    00000660 BAKMEM0
    00000661 BAKMEM0_H
    00000660 BAKMEM0_L
    00000662 BAKMEM1
    00000674 BAKMEM10
    00000675 BAKMEM10_H
    00000674 BAKMEM10_L
    00000676 BAKMEM11
    00000677 BAKMEM11_H
    00000676 BAKMEM11_L
    00000678 BAKMEM12
    00000679 BAKMEM12_H
    00000678 BAKMEM12_L
    0000067a BAKMEM13
    0000067b BAKMEM13_H
    0000067a BAKMEM13_L
    0000067c BAKMEM14
    0000067d BAKMEM14_H
    0000067c BAKMEM14_L
    0000067e BAKMEM15
    0000067f BAKMEM15_H
    0000067e BAKMEM15_L
    00000663 BAKMEM1_H
    00000662 BAKMEM1_L
    00000664 BAKMEM2
    00000665 BAKMEM2_H
    00000664 BAKMEM2_L
    00000666 BAKMEM3
    00000667 BAKMEM3_H
    00000666 BAKMEM3_L
    00000668 BAKMEM4
    00000669 BAKMEM4_H
    00000668 BAKMEM4_L
    0000066a BAKMEM5
    0000066b BAKMEM5_H
    0000066a BAKMEM5_L
    0000066c BAKMEM6
    0000066d BAKMEM6_H
    0000066c BAKMEM6_L
    0000066e BAKMEM7
    0000066f BAKMEM7_H
    0000066e BAKMEM7_L
    00000670 BAKMEM8
    00000671 BAKMEM8_H
    00000670 BAKMEM8_L
    00000672 BAKMEM9
    00000673 BAKMEM9_H
    00000672 BAKMEM9_L
    0000e582 BGXSendCommand
    0000d03a BGXUTIL_calculaKey
    0000b570 BGXUTIL_parseScanAnswerparseBGXIncomingDataClient
    0000f386 BGX_ClearRxData
    0000f99c BGX_ConfigAction
    0000f17a BGX_Init
    00008814 BGX_Motor
    0000f94c BGX_isConnected
    0000dfe4 BGX_sendCommand
    0000e888 BGX_sendDebugMsg
    0000f028 BGX_sendFAC
    0000d600 BGX_sendPassword
    0000f3b0 BGX_sendSetDeviceName
    00002000 BGXstruct
    0000c792 BSP_configureMCU
    000028b2 BTN00
    0000299e BTN00_C00
    000029bc BTN00_C00_Elements
    000029a4 BTN00_C01
    000029c0 BTN00_C01_Elements
    000029aa BTN00_C02
    000029c4 BTN00_C02_Elements
    000029b0 BTN00_C03
    000029c8 BTN00_C03_Elements
    0000297e BTN00_Cycles
    000028d6 BTN00_E00
    00002842 BTN00_E00_RawCnts
    000027bc BTN00_E00_Tuning
    000028f4 BTN00_E01
    0000284a BTN00_E01_RawCnts
    000027cc BTN00_E01_Tuning
    00002912 BTN00_E02
    00002852 BTN00_E02_RawCnts
    000027dc BTN00_E02_Tuning
    00002930 BTN00_E03
    0000285a BTN00_E03_RawCnts
    000027ec BTN00_E03_Tuning
    00002828 BTN00_Params
    0000d49a BTN00_callback
    0000fa8e C$$EXIT
    00000b20 CAPIE
    00000b21 CAPIE_H
    00000b20 CAPIE_L
    00000b22 CAPIFG
    00000b23 CAPIFG_H
    00000b22 CAPIFG_L
    00000b24 CAPIV
    00000b25 CAPIV_H
    00000b24 CAPIV_L
    0000fc46 CAPT_ISR
    0000be7c CAPT_accessSpecialSensorParameter
    0000eb7e CAPT_appHandler
    0000f2a8 CAPT_appSleep
    0000ebc2 CAPT_appStart
    00009334 CAPT_calibrateBiasCurrentTrim
    0000a7ee CAPT_calibrateOffset
    0000ecd2 CAPT_calibrateSensor
    0000d3e4 CAPT_calibrateSensorWithEMC
    0000f09c CAPT_calibrateUI
    0000c88c CAPT_checkForInboundPacket
    0000f8f2 CAPT_checkForRecalibrationRequest
    0000fa2e CAPT_clearInputImpedanceBiasCurrent
    0000c47c CAPT_correctInvalidMultiFreqCalibration
    0000f6d8 CAPT_getChecksum
    0000f9de CAPT_getDominantButton
    0000e8d8 CAPT_getEMCConversionSettings
    0000ec06 CAPT_getGlobalUIProximityStatus
    0000f9e8 CAPT_getInputImpedanceBiasCurrent
    0000fa46 CAPT_getInterruptVector
    0000f4c6 CAPT_init
    0000e526 CAPT_initCommInterface
    0000dd92 CAPT_initSensor
    0000dc04 CAPT_initUI
    0000f404 CAPT_isByteQueueFull
    0000f6f4 CAPT_loadEMCConfig
    0000e926 CAPT_preProcessSlider
    0000e138 CAPT_processFSMCycle
    0000e1a2 CAPT_processSensor
    0000e5da CAPT_pushOntoByteQueue
    0000fa4c CAPT_registerCallback
    0000a350 CAPT_saveCycleResultsAutoMultiFreq
    0000f9c6 CAPT_selectElectrodeChargeVoltageSource
    0000f764 CAPT_selectInputImpedanceBiasCurrent
    0000e974 CAPT_selectInputImpedanceBiasCurrentTrim
    0000bfc6 CAPT_testConversionFrequencyForNoise
    0000f600 CAPT_testForMaxCountRecalibration
    0000f7e6 CAPT_testForNegativeTouchRecalibration
    0000bd28 CAPT_updateSensorWithEMCAuto
    0000d1bc CAPT_updateUI
    0000d752 CAPT_writeElementData
    0000e058 CAPT_writeSensorData
    000008e0 CP0CTL0
    000008e1 CP0CTL0_H
    000008e0 CP0CTL0_L
    000008e2 CP0CTL1
    000008e3 CP0CTL1_H
    000008e2 CP0CTL1_L
    000008f0 CP0DACCTL
    000008f1 CP0DACCTL_H
    000008f0 CP0DACCTL_L
    000008f2 CP0DACDATA
    000008f3 CP0DACDATA_H
    000008f2 CP0DACDATA_L
    000008e6 CP0INT
    000008e7 CP0INT_H
    000008e6 CP0INT_L
    000008e8 CP0IV
    000008e9 CP0IV_H
    000008e8 CP0IV_L
    000001c0 CRCDI
    000001c2 CRCDIRB
    000001c3 CRCDIRB_H
    000001c2 CRCDIRB_L
    000001c1 CRCDI_H
    000001c0 CRCDI_L
    000001c4 CRCINIRES
    000001c5 CRCINIRES_H
    000001c4 CRCINIRES_L
    000001c6 CRCRESR
    000001c7 CRCRESR_H
    000001c6 CRCRESR_L
    00000180 CSCTL0
    00000181 CSCTL0_H
    00000180 CSCTL0_L
    00000182 CSCTL1
    00000183 CSCTL1_H
    00000182 CSCTL1_L
    00000184 CSCTL2
    00000185 CSCTL2_H
    00000184 CSCTL2_L
    00000186 CSCTL3
    00000187 CSCTL3_H
    00000186 CSCTL3_L
    00000188 CSCTL4
    00000189 CSCTL4_H
    00000188 CSCTL4_L
    0000018a CSCTL5
    0000018b CSCTL5_H
    0000018a CSCTL5_L
    0000018c CSCTL6
    0000018d CSCTL6_H
    0000018c CSCTL6_L
    0000018e CSCTL7
    0000018f CSCTL7_H
    0000018e CSCTL7_L
    00000190 CSCTL8
    00000191 CSCTL8_H
    00000190 CSCTL8_L
    0000f660 CS_clearAllOscFlagsWithTimeout
    0000cc28 CS_initClockSignal
    0000cf76 CS_initFLL
    0000f9f2 CS_setExternalClockSource
    0000ed10 CS_turnOnXT1LFWithTimeout
    0000f85c DRV_UART1_ClearRxData
    0000f95c DRV_UART1_GetByteFromRXBuffer
    0000fa52 DRV_UART1_GetNumRXBytes
    0000e632 DRV_UART1_Init
    0000eec0 DRV_UART1_Send
    0000f872 FRAMCtl_configureWaitStateControl
    000001a0 FRCTL0
    000001a1 FRCTL0_H
    000001a0 FRCTL0_L
    000001a4 GCCTL0
    000001a5 GCCTL0_H
    000001a4 GCCTL0_L
    000001a6 GCCTL1
    000001a7 GCCTL1_H
    000001a6 GCCTL1_L
    0000e2dc InitTimerService
    0000de82 LED_LP012_LedBlink
    00008f9a LED_LP5012_Alarm_Motor
    0000f3da LED_LP5012_ApagaTodosLeds
    0000ca5e LED_LP5012_ArranqueAcabado
    0000d7f4 LED_LP5012_ButtonPressed
    0000ae2a LED_LP5012_Charging_Motor
    00009bd2 LED_LP5012_Inmediate_Motor
    0000f710 LED_LP5012_Motor
    0000fa58 LED_LP5012_RxShowerStatus
    0000f454 LED_LP5012_SetRegisterValue
    0000f248 LP5012_ActivaColorEnTodosLosLeds
    0000f9d2 LP5012_DisWarningUnLinked
    0000f9aa LP5012_DisableWarningFlushConfirmation
    0000fa5e LP5012_EnableAlarm
    0000fa36 LP5012_EnableWarningFlushConfirmation
    0000fa64 LP5012_EnableWarningLinkRequest
    0000fa6a LP5012_EnableWarningUnLinked
    0000db7a LP5012_Init
    0000e4c8 LP5012_config1
    0000ea10 LP5012_led_bank_enable
    0000e408 LP5012_led_brightness
    0000d0fc LP5012_led_color_basic
    0000f2d6 LP5012_mode
    0000f7fe LP5012_reset
    000004c4 MAC
    000004da MAC32H
    000004db MAC32H_H
    000004da MAC32H_L
    000004d8 MAC32L
    000004d9 MAC32L_H
    000004d8 MAC32L_L
    000004c6 MACS
    000004de MACS32H
    000004df MACS32H_H
    000004de MACS32H_L
    000004dc MACS32L
    000004dd MACS32L_H
    000004dc MACS32L_L
    000004c7 MACS_H
    000004c6 MACS_L
    000004c5 MAC_H
    000004c4 MAC_L
    000004c0 MPY
    000004ec MPY32CTL0
    000004ed MPY32CTL0_H
    000004ec MPY32CTL0_L
    000004d2 MPY32H
    000004d3 MPY32H_H
    000004d2 MPY32H_L
    000004d0 MPY32L
    000004d1 MPY32L_H
    000004d0 MPY32L_L
    000004c2 MPYS
    000004d6 MPYS32H
    000004d7 MPYS32H_H
    000004d6 MPYS32H_L
    000004d4 MPYS32L
    000004d5 MPYS32L_H
    000004d4 MPYS32L_L
    000004c3 MPYS_H
    000004c2 MPYS_L
    000004c1 MPY_H
    000004c0 MPY_L
    000004c8 OP2
    000004e2 OP2H
    000004e3 OP2H_H
    000004e2 OP2H_L
    000004e0 OP2L
    000004e1 OP2L_H
    000004e0 OP2L_L
    000004c9 OP2_H
    000004c8 OP2_L
    00000285 P10DIR
    0000029b P10IE
    00000299 P10IES
    0000029d P10IFG
    00000281 P10IN
    00000283 P10OUT
    00000287 P10REN
    0000028b P10SEL0
    0000028d P10SEL1
    00000297 P10SELC
    00000204 P1DIR
    0000021a P1IE
    00000218 P1IES
    0000021c P1IFG
    00000200 P1IN
    0000020e P1IV
    0000020f P1IV_H
    0000020e P1IV_L
    00000202 P1OUT
    00000206 P1REN
    0000020a P1SEL0
    0000020c P1SEL1
    00000216 P1SELC
    00000205 P2DIR
    0000021b P2IE
    00000219 P2IES
    0000021d P2IFG
    00000201 P2IN
    0000021e P2IV
    0000021f P2IV_H
    0000021e P2IV_L
    00000203 P2OUT
    00000207 P2REN
    0000020b P2SEL0
    0000020d P2SEL1
    00000217 P2SELC
    00000224 P3DIR
    0000023a P3IE
    00000238 P3IES
    0000023c P3IFG
    00000220 P3IN
    0000022e P3IV
    0000022f P3IV_H
    0000022e P3IV_L
    00000222 P3OUT
    00000226 P3REN
    0000022a P3SEL0
    0000022c P3SEL1
    00000236 P3SELC
    00000225 P4DIR
    0000023b P4IE
    00000239 P4IES
    0000023d P4IFG
    00000221 P4IN
    0000023e P4IV
    0000023f P4IV_H
    0000023e P4IV_L
    00000223 P4OUT
    00000227 P4REN
    0000022b P4SEL0
    0000022d P4SEL1
    00000237 P4SELC
    00000244 P5DIR
    0000025a P5IE
    00000258 P5IES
    0000025c P5IFG
    00000240 P5IN
    0000024e P5IV
    0000024f P5IV_H
    0000024e P5IV_L
    00000242 P5OUT
    00000246 P5REN
    0000024a P5SEL0
    0000024c P5SEL1
    00000256 P5SELC
    00000245 P6DIR
    0000025b P6IE
    00000259 P6IES
    0000025d P6IFG
    00000241 P6IN
    0000025e P6IV
    0000025f P6IV_H
    0000025e P6IV_L
    00000243 P6OUT
    00000247 P6REN
    0000024b P6SEL0
    0000024d P6SEL1
    00000257 P6SELC
    00000264 P7DIR
    0000027a P7IE
    00000278 P7IES
    0000027c P7IFG
    00000260 P7IN
    00000262 P7OUT
    00000266 P7REN
    0000026a P7SEL0
    0000026c P7SEL1
    00000276 P7SELC
    00000265 P8DIR
    0000027b P8IE
    00000279 P8IES
    0000027d P8IFG
    00000261 P8IN
    00000263 P8OUT
    00000267 P8REN
    0000026b P8SEL0
    0000026d P8SEL1
    00000277 P8SELC
    00000284 P9DIR
    0000029a P9IE
    00000298 P9IES
    0000029c P9IFG
    00000280 P9IN
    00000282 P9OUT
    00000286 P9REN
    0000028a P9SEL0
    0000028c P9SEL1
    00000296 P9SELC
    00000204 PADIR
    00000205 PADIR_H
    00000204 PADIR_L
    0000021a PAIE
    00000218 PAIES
    00000219 PAIES_H
    00000218 PAIES_L
    0000021b PAIE_H
    0000021a PAIE_L
    0000021c PAIFG
    0000021d PAIFG_H
    0000021c PAIFG_L
    00000200 PAIN
    00000201 PAIN_H
    00000200 PAIN_L
    00000202 PAOUT
    00000203 PAOUT_H
    00000202 PAOUT_L
    00000206 PAREN
    00000207 PAREN_H
    00000206 PAREN_L
    0000020a PASEL0
    0000020b PASEL0_H
    0000020a PASEL0_L
    0000020c PASEL1
    0000020d PASEL1_H
    0000020c PASEL1_L
    00000216 PASELC
    00000217 PASELC_H
    00000216 PASELC_L
    00000224 PBDIR
    00000225 PBDIR_H
    00000224 PBDIR_L
    0000023a PBIE
    00000238 PBIES
    00000239 PBIES_H
    00000238 PBIES_L
    0000023b PBIE_H
    0000023a PBIE_L
    0000023c PBIFG
    0000023d PBIFG_H
    0000023c PBIFG_L
    00000220 PBIN
    00000221 PBIN_H
    00000220 PBIN_L
    00000222 PBOUT
    00000223 PBOUT_H
    00000222 PBOUT_L
    00000226 PBREN
    00000227 PBREN_H
    00000226 PBREN_L
    0000022a PBSEL0
    0000022b PBSEL0_H
    0000022a PBSEL0_L
    0000022c PBSEL1
    0000022d PBSEL1_H
    0000022c PBSEL1_L
    00000236 PBSELC
    00000237 PBSELC_H
    00000236 PBSELC_L
    00000244 PCDIR
    00000245 PCDIR_H
    00000244 PCDIR_L
    0000025a PCIE
    00000258 PCIES
    00000259 PCIES_H
    00000258 PCIES_L
    0000025b PCIE_H
    0000025a PCIE_L
    0000025c PCIFG
    0000025d PCIFG_H
    0000025c PCIFG_L
    00000240 PCIN
    00000241 PCIN_H
    00000240 PCIN_L
    00000242 PCOUT
    00000243 PCOUT_H
    00000242 PCOUT_L
    00000246 PCREN
    00000247 PCREN_H
    00000246 PCREN_L
    0000024a PCSEL0
    0000024b PCSEL0_H
    0000024a PCSEL0_L
    0000024c PCSEL1
    0000024d PCSEL1_H
    0000024c PCSEL1_L
    00000256 PCSELC
    00000257 PCSELC_H
    00000256 PCSELC_L
    00000264 PDDIR
    00000265 PDDIR_H
    00000264 PDDIR_L
    0000027a PDIE
    00000278 PDIES
    00000279 PDIES_H
    00000278 PDIES_L
    0000027b PDIE_H
    0000027a PDIE_L
    0000027c PDIFG
    0000027d PDIFG_H
    0000027c PDIFG_L
    00000260 PDIN
    00000261 PDIN_H
    00000260 PDIN_L
    00000262 PDOUT
    00000263 PDOUT_H
    00000262 PDOUT_L
    00000266 PDREN
    00000267 PDREN_H
    00000266 PDREN_L
    0000026a PDSEL0
    0000026b PDSEL0_H
    0000026a PDSEL0_L
    0000026c PDSEL1
    0000026d PDSEL1_H
    0000026c PDSEL1_L
    00000276 PDSELC
    00000277 PDSELC_H
    00000276 PDSELC_L
    00000284 PEDIR
    00000285 PEDIR_H
    00000284 PEDIR_L
    0000029a PEIE
    00000298 PEIES
    00000299 PEIES_H
    00000298 PEIES_L
    0000029b PEIE_H
    0000029a PEIE_L
    0000029c PEIFG
    0000029d PEIFG_H
    0000029c PEIFG_L
    00000280 PEIN
    00000281 PEIN_H
    00000280 PEIN_L
    00000282 PEOUT
    00000283 PEOUT_H
    00000282 PEOUT_L
    00000286 PEREN
    00000287 PEREN_H
    00000286 PEREN_L
    0000f816 PERSIST_BGXConfigured
    0000f904 PERSIST_BGXNotConfigured
    0000e6e2 PERSIST_GetMagneticSensorCalibrationParams
    0000faa6 PERSIST_Init
    0000fa70 PERSIST_IsBGXConfigured
    0000e78e PERSIST_SetMagneticSensorCalibrationParams
    0000dc8c PER_BuildFrameToIscu
    0000f620 PER_Init
    0000aa18 PER_IscuDriverMotor
    0000cddc PER_KeyBoardEvent
    0000b3ba PER_ParseIscuCommand
    0000fa76 PER_getLastCommandSent
    0000c694 PER_newFrameFromIscu2
    0000e738 PER_sendACK
    0000ed4e PER_setMagneticSensorValues
    0000028a PESEL0
    0000028b PESEL0_H
    0000028a PESEL0_L
    0000028c PESEL1
    0000028d PESEL1_H
    0000028c PESEL1_L
    00000296 PESELC
    00000297 PESELC_H
    00000296 PESELC_L
    00000324 PJDIR
    00000325 PJDIR_H
    00000324 PJDIR_L
    00000320 PJIN
    00000321 PJIN_H
    00000320 PJIN_L
    00000322 PJOUT
    00000323 PJOUT_H
    00000322 PJOUT_L
    00000326 PJREN
    00000327 PJREN_H
    00000326 PJREN_L
    0000032a PJSEL0
    0000032b PJSEL0_H
    0000032a PJSEL0_L
    0000032c PJSEL1
    0000032d PJSEL1_H
    0000032c PJSEL1_L
    00000336 PJSELC
    00000337 PJSELC_H
    00000336 PJSELC_L
    00000130 PM5CTL0
    00000131 PM5CTL0_H
    00000130 PM5CTL0_L
    00000120 PMMCTL0
    00000121 PMMCTL0_H
    00000120 PMMCTL0_L
    00000122 PMMCTL1
    00000123 PMMCTL1_H
    00000122 PMMCTL1_L
    00000124 PMMCTL2
    00000125 PMMCTL2_H
    00000124 PMMCTL2_L
    0000012a PMMIFG
    0000012b PMMIFG_H
    0000012a PMMIFG_L
    000004e4 RES0
    000004e5 RES0_H
    000004e4 RES0_L
    000004e6 RES1
    000004e7 RES1_H
    000004e6 RES1_L
    000004e8 RES2
    000004e9 RES2_H
    000004e8 RES2_L
    000004ea RES3
    000004eb RES3_H
    000004ea RES3_L
    000004cc RESHI
    000004cd RESHI_H
    000004cc RESHI_L
    000004ca RESLO
    000004cb RESLO_H
    000004ca RESLO_L
    0000030c RTCCNT
    0000030d RTCCNT_H
    0000030c RTCCNT_L
    00000300 RTCCTL
    00000301 RTCCTL_H
    00000300 RTCCTL_L
    00000304 RTCIV
    00000305 RTCIV_H
    00000304 RTCIV_L
    00000308 RTCMOD
    00000309 RTCMOD_H
    00000308 RTCMOD_L
    0000fd1e RTC_ISR
    000028aa RXData
    00000100 SFRIE1
    00000101 SFRIE1_H
    00000100 SFRIE1_L
    00000102 SFRIFG1
    00000103 SFRIFG1_H
    00000102 SFRIFG1_L
    00000104 SFRRPCR
    00000105 SFRRPCR_H
    00000104 SFRRPCR_L
    0000fa7c SIS_Init
    000004ce SUMEXT
    000004cf SUMEXT_H
    000004ce SUMEXT_L
    00000142 SYSBSLC
    00000143 SYSBSLC_H
    00000142 SYSBSLC_L
    00000160 SYSCFG0
    00000161 SYSCFG0_H
    00000160 SYSCFG0_L
    00000162 SYSCFG1
    00000163 SYSCFG1_H
    00000162 SYSCFG1_L
    00000164 SYSCFG2
    00000165 SYSCFG2_H
    00000164 SYSCFG2_L
    00000166 SYSCFG3
    00000167 SYSCFG3_H
    00000166 SYSCFG3_L
    00000140 SYSCTL
    00000141 SYSCTL_H
    00000140 SYSCTL_L
    00000146 SYSJMBC
    00000147 SYSJMBC_H
    00000146 SYSJMBC_L
    00000148 SYSJMBI0
    00000149 SYSJMBI0_H
    00000148 SYSJMBI0_L
    0000014a SYSJMBI1
    0000014b SYSJMBI1_H
    0000014a SYSJMBI1_L
    0000014c SYSJMBO0
    0000014d SYSJMBO0_H
    0000014c SYSJMBO0_L
    0000014e SYSJMBO1
    0000014f SYSJMBO1_H
    0000014e SYSJMBO1_L
    0000015e SYSRSTIV
    0000015f SYSRSTIV_H
    0000015e SYSRSTIV_L
    0000015c SYSSNIV
    0000015d SYSSNIV_H
    0000015c SYSSNIV_L
    0000015a SYSUNIV
    0000015b SYSUNIV_H
    0000015a SYSUNIV_L
    0000d6ae SetTimer
    00000392 TA0CCR0
    00000393 TA0CCR0_H
    00000392 TA0CCR0_L
    00000394 TA0CCR1
    00000395 TA0CCR1_H
    00000394 TA0CCR1_L
    00000396 TA0CCR2
    00000397 TA0CCR2_H
    00000396 TA0CCR2_L
    00000382 TA0CCTL0
    00000383 TA0CCTL0_H
    00000382 TA0CCTL0_L
    00000384 TA0CCTL1
    00000385 TA0CCTL1_H
    00000384 TA0CCTL1_L
    00000386 TA0CCTL2
    00000387 TA0CCTL2_H
    00000386 TA0CCTL2_L
    00000380 TA0CTL
    00000381 TA0CTL_H
    00000380 TA0CTL_L
    000003a0 TA0EX0
    000003a1 TA0EX0_H
    000003a0 TA0EX0_L
    000003ae TA0IV
    000003af TA0IV_H
    000003ae TA0IV_L
    00000390 TA0R
    00000391 TA0R_H
    00000390 TA0R_L
    000003d2 TA1CCR0
    000003d3 TA1CCR0_H
    000003d2 TA1CCR0_L
    000003d4 TA1CCR1
    000003d5 TA1CCR1_H
    000003d4 TA1CCR1_L
    000003d6 TA1CCR2
    000003d7 TA1CCR2_H
    000003d6 TA1CCR2_L
    000003c2 TA1CCTL0
    000003c3 TA1CCTL0_H
    000003c2 TA1CCTL0_L
    000003c4 TA1CCTL1
    000003c5 TA1CCTL1_H
    000003c4 TA1CCTL1_L
    000003c6 TA1CCTL2
    000003c7 TA1CCTL2_H
    000003c6 TA1CCTL2_L
    000003c0 TA1CTL
    000003c1 TA1CTL_H
    000003c0 TA1CTL_L
    000003e0 TA1EX0
    000003e1 TA1EX0_H
    000003e0 TA1EX0_L
    000003ee TA1IV
    000003ef TA1IV_H
    000003ee TA1IV_L
    000003d0 TA1R
    000003d1 TA1R_H
    000003d0 TA1R_L
    00000412 TA2CCR0
    00000413 TA2CCR0_H
    00000412 TA2CCR0_L
    00000414 TA2CCR1
    00000415 TA2CCR1_H
    00000414 TA2CCR1_L
    00000416 TA2CCR2
    00000417 TA2CCR2_H
    00000416 TA2CCR2_L
    00000402 TA2CCTL0
    00000403 TA2CCTL0_H
    00000402 TA2CCTL0_L
    00000404 TA2CCTL1
    00000405 TA2CCTL1_H
    00000404 TA2CCTL1_L
    00000406 TA2CCTL2
    00000407 TA2CCTL2_H
    00000406 TA2CCTL2_L
    00000400 TA2CTL
    00000401 TA2CTL_H
    00000400 TA2CTL_L
    00000420 TA2EX0
    00000421 TA2EX0_H
    00000420 TA2EX0_L
    0000042e TA2IV
    0000042f TA2IV_H
    0000042e TA2IV_L
    00000410 TA2R
    00000411 TA2R_H
    00000410 TA2R_L
    00000452 TA3CCR0
    00000453 TA3CCR0_H
    00000452 TA3CCR0_L
    00000454 TA3CCR1
    00000455 TA3CCR1_H
    00000454 TA3CCR1_L
    00000456 TA3CCR2
    00000457 TA3CCR2_H
    00000456 TA3CCR2_L
    00000442 TA3CCTL0
    00000443 TA3CCTL0_H
    00000442 TA3CCTL0_L
    00000444 TA3CCTL1
    00000445 TA3CCTL1_H
    00000444 TA3CCTL1_L
    00000446 TA3CCTL2
    00000447 TA3CCTL2_H
    00000446 TA3CCTL2_L
    00000440 TA3CTL
    00000441 TA3CTL_H
    00000440 TA3CTL_L
    00000460 TA3EX0
    00000461 TA3EX0_H
    00000460 TA3EX0_L
    0000046e TA3IV
    0000046f TA3IV_H
    0000046e TA3IV_L
    00000450 TA3R
    00000451 TA3R_H
    00000450 TA3R_L
    00000492 TB0CCR0
    00000493 TB0CCR0_H
    00000492 TB0CCR0_L
    00000494 TB0CCR1
    00000495 TB0CCR1_H
    00000494 TB0CCR1_L
    00000496 TB0CCR2
    00000497 TB0CCR2_H
    00000496 TB0CCR2_L
    00000498 TB0CCR3
    00000499 TB0CCR3_H
    00000498 TB0CCR3_L
    0000049a TB0CCR4
    0000049b TB0CCR4_H
    0000049a TB0CCR4_L
    0000049c TB0CCR5
    0000049d TB0CCR5_H
    0000049c TB0CCR5_L
    0000049e TB0CCR6
    0000049f TB0CCR6_H
    0000049e TB0CCR6_L
    00000482 TB0CCTL0
    00000483 TB0CCTL0_H
    00000482 TB0CCTL0_L
    00000484 TB0CCTL1
    00000485 TB0CCTL1_H
    00000484 TB0CCTL1_L
    00000486 TB0CCTL2
    00000487 TB0CCTL2_H
    00000486 TB0CCTL2_L
    00000488 TB0CCTL3
    00000489 TB0CCTL3_H
    00000488 TB0CCTL3_L
    0000048a TB0CCTL4
    0000048b TB0CCTL4_H
    0000048a TB0CCTL4_L
    0000048c TB0CCTL5
    0000048d TB0CCTL5_H
    0000048c TB0CCTL5_L
    0000048e TB0CCTL6
    0000048f TB0CCTL6_H
    0000048e TB0CCTL6_L
    00000480 TB0CTL
    00000481 TB0CTL_H
    00000480 TB0CTL_L
    000004a0 TB0EX0
    000004a1 TB0EX0_H
    000004a0 TB0EX0_L
    000004ae TB0IV
    000004af TB0IV_H
    000004ae TB0IV_L
    00000490 TB0R
    00000491 TB0R_H
    00000490 TB0R_L
    0000f302 TICKS_DifTicks
    0000f72c TICKS_GetTicks
    0000c22c TLV493D_Calibrate
    0000f062 TLV493D_CalibratePoint
    0000f57a TLV493D_GetYCoordinates
    00009908 TLV493D_Motor
    0000c976 TLV493D_PublishSensorChange
    0000ed8c TLV493D_ReadRegisterValues
    0000fa3e TLV493D_task_init
    0000c356 TOUCH_BotonMotor
    0000e468 TimerIntProc
    0000fcc2 Timer_A
    0000faaa UART_ISR
    0000f59c UART_closePort
    0000d934 UART_openPort
    0000e342 UART_transmitBuffer
    00000510 UCA0ABCTL
    00000511 UCA0ABCTL_H
    00000510 UCA0ABCTL_L
    00000506 UCA0BRW
    00000507 UCA0BRW_H
    00000506 UCA0BRW_L
    00000500 UCA0CTLW0
    00000501 UCA0CTLW0_H
    00000500 UCA0CTLW0_L
    00000502 UCA0CTLW1
    00000503 UCA0CTLW1_H
    00000502 UCA0CTLW1_L
    0000051a UCA0IE
    0000051b UCA0IE_H
    0000051a UCA0IE_L
    0000051c UCA0IFG
    0000051d UCA0IFG_H
    0000051c UCA0IFG_L
    00000512 UCA0IRCTL
    00000513 UCA0IRCTL_H
    00000512 UCA0IRCTL_L
    0000051e UCA0IV
    0000051f UCA0IV_H
    0000051e UCA0IV_L
    00000508 UCA0MCTLW
    00000509 UCA0MCTLW_H
    00000508 UCA0MCTLW_L
    0000050c UCA0RXBUF
    0000050d UCA0RXBUF_H
    0000050c UCA0RXBUF_L
    0000050a UCA0STATW
    0000050b UCA0STATW_H
    0000050a UCA0STATW_L
    0000050e UCA0TXBUF
    0000050f UCA0TXBUF_H
    0000050e UCA0TXBUF_L
    00000530 UCA1ABCTL
    00000531 UCA1ABCTL_H
    00000530 UCA1ABCTL_L
    00000526 UCA1BRW
    00000527 UCA1BRW_H
    00000526 UCA1BRW_L
    00000520 UCA1CTLW0
    00000521 UCA1CTLW0_H
    00000520 UCA1CTLW0_L
    00000522 UCA1CTLW1
    00000523 UCA1CTLW1_H
    00000522 UCA1CTLW1_L
    0000053a UCA1IE
    0000053b UCA1IE_H
    0000053a UCA1IE_L
    0000053c UCA1IFG
    0000053d UCA1IFG_H
    0000053c UCA1IFG_L
    00000532 UCA1IRCTL
    00000533 UCA1IRCTL_H
    00000532 UCA1IRCTL_L
    0000053e UCA1IV
    0000053f UCA1IV_H
    0000053e UCA1IV_L
    00000528 UCA1MCTLW
    00000529 UCA1MCTLW_H
    00000528 UCA1MCTLW_L
    0000052c UCA1RXBUF
    0000052d UCA1RXBUF_H
    0000052c UCA1RXBUF_L
    0000052a UCA1STATW
    0000052b UCA1STATW_H
    0000052a UCA1STATW_L
    0000052e UCA1TXBUF
    0000052f UCA1TXBUF_H
    0000052e UCA1TXBUF_L
    0000055e UCB0ADDMASK
    0000055f UCB0ADDMASK_H
    0000055e UCB0ADDMASK_L
    0000055c UCB0ADDRX
    0000055d UCB0ADDRX_H
    0000055c UCB0ADDRX_L
    00000546 UCB0BRW
    00000547 UCB0BRW_H
    00000546 UCB0BRW_L
    00000540 UCB0CTLW0
    00000541 UCB0CTLW0_H
    00000540 UCB0CTLW0_L
    00000542 UCB0CTLW1
    00000543 UCB0CTLW1_H
    00000542 UCB0CTLW1_L
    00000554 UCB0I2COA0
    00000555 UCB0I2COA0_H
    00000554 UCB0I2COA0_L
    00000556 UCB0I2COA1
    00000557 UCB0I2COA1_H
    00000556 UCB0I2COA1_L
    00000558 UCB0I2COA2
    00000559 UCB0I2COA2_H
    00000558 UCB0I2COA2_L
    0000055a UCB0I2COA3
    0000055b UCB0I2COA3_H
    0000055a UCB0I2COA3_L
    00000560 UCB0I2CSA
    00000561 UCB0I2CSA_H
    00000560 UCB0I2CSA_L
    0000056a UCB0IE
    0000056b UCB0IE_H
    0000056a UCB0IE_L
    0000056c UCB0IFG
    0000056d UCB0IFG_H
    0000056c UCB0IFG_L
    0000056e UCB0IV
    0000056f UCB0IV_H
    0000056e UCB0IV_L
    0000054c UCB0RXBUF
    0000054d UCB0RXBUF_H
    0000054c UCB0RXBUF_L
    00000548 UCB0STATW
    00000549 UCB0STATW_H
    00000548 UCB0STATW_L
    0000054a UCB0TBCNT
    0000054b UCB0TBCNT_H
    0000054a UCB0TBCNT_L
    0000054e UCB0TXBUF
    0000054f UCB0TXBUF_H
    0000054e UCB0TXBUF_L
    0000b71c UCB0_I2C_write
    0000f888 UCB0_MasterI2C_init
    0000059e UCB1ADDMASK
    0000059f UCB1ADDMASK_H
    0000059e UCB1ADDMASK_L
    0000059c UCB1ADDRX
    0000059d UCB1ADDRX_H
    0000059c UCB1ADDRX_L
    00000586 UCB1BRW
    00000587 UCB1BRW_H
    00000586 UCB1BRW_L
    00000580 UCB1CTLW0
    00000581 UCB1CTLW0_H
    00000580 UCB1CTLW0_L
    00000582 UCB1CTLW1
    00000583 UCB1CTLW1_H
    00000582 UCB1CTLW1_L
    00000594 UCB1I2COA0
    00000595 UCB1I2COA0_H
    00000594 UCB1I2COA0_L
    00000596 UCB1I2COA1
    00000597 UCB1I2COA1_H
    00000596 UCB1I2COA1_L
    00000598 UCB1I2COA2
    00000599 UCB1I2COA2_H
    00000598 UCB1I2COA2_L
    0000059a UCB1I2COA3
    0000059b UCB1I2COA3_H
    0000059a UCB1I2COA3_L
    000005a0 UCB1I2CSA
    000005a1 UCB1I2CSA_H
    000005a0 UCB1I2CSA_L
    000005aa UCB1IE
    000005ab UCB1IE_H
    000005aa UCB1IE_L
    000005ac UCB1IFG
    000005ad UCB1IFG_H
    000005ac UCB1IFG_L
    000005ae UCB1IV
    000005af UCB1IV_H
    000005ae UCB1IV_L
    0000058c UCB1RXBUF
    0000058d UCB1RXBUF_H
    0000058c UCB1RXBUF_L
    00000588 UCB1STATW
    00000589 UCB1STATW_H
    00000588 UCB1STATW_L
    0000058a UCB1TBCNT
    0000058b UCB1TBCNT_H
    0000058a UCB1TBCNT_L
    0000058e UCB1TXBUF
    0000058f UCB1TXBUF_H
    0000058e UCB1TXBUF_L
    0000ac26 UCB1_I2C_read
    0000b8a2 UCB1_I2C_write
    0000fa82 UCB1_MasterI2C_deinit
    0000f748 UCB1_MasterI2C_init
    0000fbce USCI_A1_ISR
    0000e0cc UTIL_CalculaCRC
    0000f32e UTIL_Delay
    0000f278 UTIL_StartsWith
    0000f47a UTIL_StringContains
    0000c590 UTIL_calculateGradoDeGiro
    0000d274 UTIL_calculateGradoDeGiro2
    0000d9cc UTIL_hexBufferToHexString
    0000f4a0 UTIL_sulitoad
    0000def8 UTIL_ulitoad
    000001cc WDTCTL
    000001cd WDTCTL_H
    000001cc WDTCTL_L
    0000fd02 WDT_ISR
    00004000 __STACK_END
    00000100 __STACK_SIZE
    000084dc __TI_CINIT_Base
    000084ec __TI_CINIT_Limit
    000084ca __TI_Handler_Table_Base
    000084d6 __TI_Handler_Table_Limit
    0000fd34 __TI_ISR_TRAP
    0000de0a __TI_auto_init_nobinit_nopinit_hold_wdt
    0000df6e __TI_decompress_lzss
    0000f89e __TI_decompress_none
    0000a5a6 __TI_frcaddd
    00009e6a __TI_frcmpyd
    0000ffc8 __TI_int19
    0000ffca __TI_int20
    0000ffcc __TI_int21
    0000ffce __TI_int22
    0000ffd0 __TI_int23
    0000ffd2 __TI_int24
    0000ffd4 __TI_int25
    0000ffd6 __TI_int26
    0000ffd8 __TI_int27
    0000ffda __TI_int28
    0000ffdc __TI_int29
    0000ffde __TI_int30
    0000ffe0 __TI_int31
    0000ffe2 __TI_int32
    0000ffe4 __TI_int33
    0000ffe6 __TI_int34
    0000ffe8 __TI_int35
    0000ffea __TI_int36
    0000ffec __TI_int37
    0000ffee __TI_int38
    0000fff0 __TI_int39
    0000fff2 __TI_int40
    0000fff4 __TI_int41
    0000fff6 __TI_int42
    0000fff8 __TI_int43
    0000fffa __TI_int44
    0000fffc __TI_int45
    ffffffff __TI_pprof_out_hndl
    0000cb44 __TI_printfi_minimal
    ffffffff __TI_prof_data_size
    ffffffff __TI_prof_data_start
    0000d54e __TI_renormd
    0000f50e __TI_zero_init
    ffffffff __c_args__
    00000001 __mpu_enable
    0000eefc __mpu_init
    00009628 __mspabi_addd
    0000c100 __mspabi_addf
    0000eaa4 __mspabi_cmpf
    0000da5c __mspabi_divf
    0000f35a __mspabi_divi
    0000f8b4 __mspabi_divu
    0000e68a __mspabi_divul
    0000f916 __mspabi_fixdu
    0000e20c __mspabi_fixdul
    0000e274 __mspabi_fixfi
    0000f144 __mspabi_fltif
    0000fa88 __mspabi_fltud
    0000dd12 __mspabi_fltuld
    0000a0ea __mspabi_mpyd
    0000d32c __mspabi_mpyf
    0000f82e __mspabi_mpyi_f5hw
    0000f556 __mspabi_mpyl_f5hw
    0000f35a __mspabi_remi
    0000f8b4 __mspabi_remu
    0000e68a __mspabi_remul
    0000fa10 __mspabi_slli
    0000f97c __mspabi_slll
    0000ee40 __mspabi_slll_1
    0000ee1c __mspabi_slll_10
    0000ee18 __mspabi_slll_11
    0000ee14 __mspabi_slll_12
    0000ee10 __mspabi_slll_13
    0000ee0c __mspabi_slll_14
    0000ee08 __mspabi_slll_15
    0000ee3c __mspabi_slll_2
    0000ee38 __mspabi_slll_3
    0000ee34 __mspabi_slll_4
    0000ee30 __mspabi_slll_5
    0000ee2c __mspabi_slll_6
    0000ee28 __mspabi_slll_7
    0000ee24 __mspabi_slll_8
    0000ee20 __mspabi_slll_9
    0000f96c __mspabi_sral
    0000ee02 __mspabi_sral_1
    0000edde __mspabi_sral_10
    0000edda __mspabi_sral_11
    0000edd6 __mspabi_sral_12
    0000edd2 __mspabi_sral_13
    0000edce __mspabi_sral_14
    0000edca __mspabi_sral_15
    0000edfe __mspabi_sral_2
    0000edfa __mspabi_sral_3
    0000edf6 __mspabi_sral_4
    0000edf2 __mspabi_sral_5
    0000edee __mspabi_sral_6
    0000edea __mspabi_sral_7
    0000ede6 __mspabi_sral_8
    0000ede2 __mspabi_sral_9
    0000f98c __mspabi_srll
    0000ee7e __mspabi_srll_1
    0000ee5a __mspabi_srll_10
    0000ee56 __mspabi_srll_11
    0000ee52 __mspabi_srll_12
    0000ee4e __mspabi_srll_13
    0000ee4a __mspabi_srll_14
    0000ee46 __mspabi_srll_15
    0000ee7a __mspabi_srll_2
    0000ee76 __mspabi_srll_3
    0000ee72 __mspabi_srll_4
    0000ee6e __mspabi_srll_5
    0000ee6a __mspabi_srll_6
    0000ee66 __mspabi_srll_7
    0000ee62 __mspabi_srll_8
    0000ee5e __mspabi_srll_9
    0000c0fa __mspabi_subf
    0000fce2 _c_int00_noargs_mpu
    0000fffe _reset_vector
    00003f00 _stack
    0000faa8 _system_post_cinit
    0000f9fc _system_pre_init
    0000fa8e abort
    0000fa06 abs
    0000fa94 batteryCheckStatus
    0000f67e enableBLE
    0000f77e enableDevicesPower
    0000f69c enableLeds
    0000f798 enableSensorMagentico2
    00008000 fram_rw_start
    00008400 fram_rx_start
    00008800 g_EMCConfig
    000028ab g_UARTStatus
    000028ac g_bConvCounterFlag
    000028ad g_bConvTimerFlag
    000028ae g_bDetectionFlag
    000028af g_bEndOfConversionFlag
    000028b0 g_bMaxCountErrorFlag
    00002890 g_filteredGlobalNoiseLevel
    000029d8 g_pCaptivateSensorArray
    000029d0 g_pEMCConfig
    00002894 g_pHighestNoiseElement
    00002898 g_pUARTPort
    0000289c g_pUARTTransmitPtr
    000028a6 g_ui16UARTTransmitBytesLeft
    0000298e g_uiApp
    0000fa9a getBatteryLevel
    0000f532 getBatteryLevel_init
    0000ef38 getUnidadesGradoAngular
    000028a8 iborra
    00000001 info_fram_protection
    0000e3a6 main
    0000f1ae memccpy
    0000ef74 memcpy
    0000f640 memset
    00000001 program_fram_protection
    0000f7b2 resetBLE
    0000f1e2 sds_init
    0000efb0 sds_main
    0000fa1a setChargeLed
    0000f7cc setSDA_UCB1
    0000ec8e sprintf
    00000001 start_protection_offset_address
    0000f928 strcpy
    0000f93a strlen
    0000f0d4 strncmp
    0000e9c2 strncpy
    0000efec strstr
    00002876 swB
    0000e7e2 task_batteryManagement
    0000faa0 task_batteryManagement_init
    0000f5be task_ledBF_init
    0000fa24 task_touch
    0000f6ba task_touch_init
    000028a0 utilDelay
    0000294e vGradosDeGiroS1
    00002966 vGradosDeGiroS2
    0000b014 vReadTLV493D
    00002808 xRegAlarm
    00002798 xRegArranque
    00002862 xRegAux
    0000274e xRegCharging
    00002162 xRegGlobal
    000026f6 xRegInmediate
    00002580 xRegIscDrv
    00002722 xRegLeds
    000024f8 xRegTLV493D
    0000265c xRegTouch
    00008000 xVarFlash
    GLOBAL SYMBOLS: SORTED BY Symbol Address
    address name
    00000100 SFRIE1
    00000100 SFRIE1_L
    00000101 SFRIE1_H
    00000102 SFRIFG1
    00000102 SFRIFG1_L
    00000103 SFRIFG1_H
    00000104 SFRRPCR
    00000104 SFRRPCR_L
    00000105 SFRRPCR_H
    00000120 PMMCTL0
    00000120 PMMCTL0_L
    00000121 PMMCTL0_H
    00000122 PMMCTL1
    00000122 PMMCTL1_L
    00000123 PMMCTL1_H
    00000124 PMMCTL2
    00000124 PMMCTL2_L
    00000125 PMMCTL2_H
    0000012a PMMIFG
    0000012a PMMIFG_L
    0000012b PMMIFG_H
    00000130 PM5CTL0
    00000130 PM5CTL0_L
    00000131 PM5CTL0_H
    00000140 SYSCTL
    00000140 SYSCTL_L
    00000141 SYSCTL_H
    00000142 SYSBSLC
    00000142 SYSBSLC_L
    00000143 SYSBSLC_H
    00000146 SYSJMBC
    00000146 SYSJMBC_L
    00000147 SYSJMBC_H
    00000148 SYSJMBI0
    00000148 SYSJMBI0_L
    00000149 SYSJMBI0_H
    0000014a SYSJMBI1
    0000014a SYSJMBI1_L
    0000014b SYSJMBI1_H
    0000014c SYSJMBO0
    0000014c SYSJMBO0_L
    0000014d SYSJMBO0_H
    0000014e SYSJMBO1
    0000014e SYSJMBO1_L
    0000014f SYSJMBO1_H
    0000015a SYSUNIV
    0000015a SYSUNIV_L
    0000015b SYSUNIV_H
    0000015c SYSSNIV
    0000015c SYSSNIV_L
    0000015d SYSSNIV_H
    0000015e SYSRSTIV
    0000015e SYSRSTIV_L
    0000015f SYSRSTIV_H
    00000160 SYSCFG0
    00000160 SYSCFG0_L
    00000161 SYSCFG0_H
    00000162 SYSCFG1
    00000162 SYSCFG1_L
    00000163 SYSCFG1_H
    00000164 SYSCFG2
    00000164 SYSCFG2_L
    00000165 SYSCFG2_H
    00000166 SYSCFG3
    00000166 SYSCFG3_L
    00000167 SYSCFG3_H
    00000180 CSCTL0
    00000180 CSCTL0_L
    00000181 CSCTL0_H
    00000182 CSCTL1
    00000182 CSCTL1_L
    00000183 CSCTL1_H
    00000184 CSCTL2
    00000184 CSCTL2_L
    00000185 CSCTL2_H
    00000186 CSCTL3
    00000186 CSCTL3_L
    00000187 CSCTL3_H
    00000188 CSCTL4
    00000188 CSCTL4_L
    00000189 CSCTL4_H
    0000018a CSCTL5
    0000018a CSCTL5_L
    0000018b CSCTL5_H
    0000018c CSCTL6
    0000018c CSCTL6_L
    0000018d CSCTL6_H
    0000018e CSCTL7
    0000018e CSCTL7_L
    0000018f CSCTL7_H
    00000190 CSCTL8
    00000190 CSCTL8_L
    00000191 CSCTL8_H
    000001a0 FRCTL0
    000001a0 FRCTL0_L
    000001a1 FRCTL0_H
    000001a4 GCCTL0
    000001a4 GCCTL0_L
    000001a5 GCCTL0_H
    000001a6 GCCTL1
    000001a6 GCCTL1_L
    000001a7 GCCTL1_H
    000001c0 CRCDI
    000001c0 CRCDI_L
    000001c1 CRCDI_H
    000001c2 CRCDIRB
    000001c2 CRCDIRB_L
    000001c3 CRCDIRB_H
    000001c4 CRCINIRES
    000001c6 CRCRESR
    000001c6 CRCRESR_L
    000001c7 CRCRESR_H
    000001cc WDTCTL
    000001cc WDTCTL_L
    000001cd WDTCTL_H
    00000200 P1IN
    00000200 PAIN
    00000200 PAIN_L
    00000201 P2IN
    00000201 PAIN_H
    00000202 P1OUT
    00000202 PAOUT
    00000202 PAOUT_L
    00000203 P2OUT
    00000203 PAOUT_H
    00000204 P1DIR
    00000204 PADIR
    00000204 PADIR_L
    00000205 P2DIR
    00000205 PADIR_H
    00000206 P1REN
    00000206 PAREN
    00000206 PAREN_L
    00000207 P2REN
    00000207 PAREN_H
    0000020a P1SEL0
    0000020a PASEL0
    0000020a PASEL0_L
    0000020b P2SEL0
    0000020b PASEL0_H
    0000020c P1SEL1
    0000020c PASEL1
    0000020c PASEL1_L
    0000020d P2SEL1
    0000020d PASEL1_H
    0000020e P1IV
    0000020e P1IV_L
    0000020f P1IV_H
    00000216 P1SELC
    00000216 PASELC
    00000216 PASELC_L
    00000217 P2SELC
    00000217 PASELC_H
    00000218 P1IES
    00000218 PAIES
    00000218 PAIES_L
    00000219 P2IES
    00000219 PAIES_H
    0000021a P1IE
    0000021a PAIE
    0000021a PAIE_L
    0000021b P2IE
    0000021b PAIE_H
    0000021c P1IFG
    0000021c PAIFG
    0000021c PAIFG_L
    0000021d P2IFG
    0000021d PAIFG_H
    0000021e P2IV
    0000021e P2IV_L
    0000021f P2IV_H
    00000220 P3IN
    00000220 PBIN
    00000220 PBIN_L
    00000221 P4IN
    00000221 PBIN_H
    00000222 P3OUT
    00000222 PBOUT
    00000222 PBOUT_L
    00000223 P4OUT
    00000223 PBOUT_H
    00000224 P3DIR
    00000224 PBDIR
    00000224 PBDIR_L
    00000225 P4DIR
    00000225 PBDIR_H
    00000226 P3REN
    00000226 PBREN
    00000226 PBREN_L
    00000227 P4REN
    00000227 PBREN_H
    0000022a P3SEL0
    0000022a PBSEL0
    0000022a PBSEL0_L
    0000022b P4SEL0
    0000022b PBSEL0_H
    0000022c P3SEL1
    0000022c PBSEL1
    0000022c PBSEL1_L
    0000022d P4SEL1
    0000022d PBSEL1_H
    0000022e P3IV
    0000022e P3IV_L
    0000022f P3IV_H
    00000236 P3SELC
    00000236 PBSELC
    00000236 PBSELC_L
    00000237 P4SELC
    00000237 PBSELC_H
    00000238 P3IES
    00000238 PBIES
    00000238 PBIES_L
    00000239 P4IES
    00000239 PBIES_H
    0000023a P3IE
    0000023a PBIE
    0000023a PBIE_L
    0000023b P4IE
    0000023b PBIE_H
    0000023c P3IFG
    0000023c PBIFG
    0000023c PBIFG_L
    0000023d P4IFG
    0000023d PBIFG_H
    0000023e P4IV
    0000023e P4IV_L
    0000023f P4IV_H
    00000240 P5IN
    00000240 PCIN
    00000240 PCIN_L
    00000241 P6IN
    00000241 PCIN_H
    00000242 P5OUT
    00000242 PCOUT
    00000242 PCOUT_L
    00000243 P6OUT
    00000243 PCOUT_H
    00000244 P5DIR
    00000244 PCDIR
    00000244 PCDIR_L
    00000245 P6DIR
    00000245 PCDIR_H
    00000246 P5REN
    00000246 PCREN
    00000246 PCREN_L
    00000247 P6REN
    00000247 PCREN_H
    0000024a P5SEL0
    0000024a PCSEL0
    0000024a PCSEL0_L
    0000024b P6SEL0
    0000024b PCSEL0_H
    0000024c P5SEL1
    0000024c PCSEL1
    0000024c PCSEL1_L
    0000024d P6SEL1
    0000024d PCSEL1_H
    0000024e P5IV
    0000024e P5IV_L
    0000024f P5IV_H
    00000256 P5SELC
    00000256 PCSELC
    00000256 PCSELC_L
    00000257 P6SELC
    00000257 PCSELC_H
    00000258 P5IES
    00000258 PCIES
    00000258 PCIES_L
    00000259 P6IES
    00000259 PCIES_H
    0000025a P5IE
    0000025a PCIE
    0000025a PCIE_L
    0000025b P6IE
    0000025b PCIE_H
    0000025c P5IFG
    0000025c PCIFG
    0000025c PCIFG_L
    0000025d P6IFG
    0000025d PCIFG_H
    0000025e P6IV
    0000025e P6IV_L
    0000025f P6IV_H
    00000260 P7IN
    00000260 PDIN
    00000260 PDIN_L
    00000261 P8IN
    00000261 PDIN_H
    00000262 P7OUT
    00000262 PDOUT
    00000262 PDOUT_L
    00000263 P8OUT
    00000263 PDOUT_H
    00000264 P7DIR
    00000264 PDDIR
    00000264 PDDIR_L
    00000265 P8DIR
    00000265 PDDIR_H
    00000266 P7REN
    00000266 PDREN
    00000266 PDREN_L
    00000267 P8REN
    00000267 PDREN_H
    0000026a P7SEL0
    0000026a PDSEL0
    0000026a PDSEL0_L
    0000026b P8SEL0
    0000026b PDSEL0_H
    0000026c P7SEL1
    0000026c PDSEL1
    0000026c PDSEL1_L
    0000026d P8SEL1
    0000026d PDSEL1_H
    00000276 P7SELC
    00000276 PDSELC
    00000276 PDSELC_L
    00000277 P8SELC
    00000277 PDSELC_H
    00000278 P7IES
    00000278 PDIES
    00000278 PDIES_L
    00000279 P8IES
    00000279 PDIES_H
    0000027a P7IE
    0000027a PDIE
    0000027a PDIE_L
    0000027b P8IE
    0000027b PDIE_H
    0000027c P7IFG
    0000027c PDIFG
    0000027c PDIFG_L
    0000027d P8IFG
    0000027d PDIFG_H
    00000280 P9IN
    00000280 PEIN
    00000280 PEIN_L
    00000281 P10IN
    00000281 PEIN_H
    00000282 P9OUT
    00000282 PEOUT
    00000282 PEOUT_L
    00000283 P10OUT
    00000283 PEOUT_H
    00000284 P9DIR
    00000284 PEDIR
    00000284 PEDIR_L
    00000285 P10DIR
    00000285 PEDIR_H
    00000286 P9REN
    00000286 PEREN
    00000286 PEREN_L
    00000287 P10REN
    00000287 PEREN_H
    0000028a P9SEL0
    0000028a PESEL0
    0000028a PESEL0_L
    0000028b P10SEL0
    0000028b PESEL0_H
    0000028c P9SEL1
    0000028c PESEL1
    0000028c PESEL1_L
    0000028d P10SEL1
    0000028d PESEL1_H
    00000296 P9SELC
    00000296 PESELC
    00000296 PESELC_L
    00000297 P10SELC
    00000297 PESELC_H
    00000298 P9IES
    00000298 PEIES
    00000298 PEIES_L
    00000299 P10IES
    00000299 PEIES_H
    0000029a P9IE
    0000029a PEIE
    0000029a PEIE_L
    0000029b P10IE
    0000029b PEIE_H
    0000029c P9IFG
    0000029c PEIFG
    0000029c PEIFG_L
    0000029d P10IFG
    0000029d PEIFG_H
    00000300 RTCCTL
    00000300 RTCCTL_L
    00000301 RTCCTL_H
    00000304 RTCIV
    00000304 RTCIV_L
    00000305 RTCIV_H
    00000308 RTCMOD
    00000308 RTCMOD_L
    00000309 RTCMOD_H
    0000030c RTCCNT
    0000030c RTCCNT_L
    0000030d RTCCNT_H
    00000320 PJIN
    00000320 PJIN_L
    00000321 PJIN_H
    00000322 PJOUT
    00000322 PJOUT_L
    00000323 PJOUT_H
    00000324 PJDIR
    00000324 PJDIR_L
    00000325 PJDIR_H
    00000326 PJREN
    00000326 PJREN_L
    00000327 PJREN_H
    0000032a PJSEL0
    0000032a PJSEL0_L
    0000032b PJSEL0_H
    0000032c PJSEL1
    0000032c PJSEL1_L
    0000032d PJSEL1_H
    00000336 PJSELC
    00000336 PJSELC_L
    00000337 PJSELC_H
    00000380 TA0CTL
    00000380 TA0CTL_L
    00000381 TA0CTL_H
    00000382 TA0CCTL0
    00000382 TA0CCTL0_L
    00000383 TA0CCTL0_H
    00000384 TA0CCTL1
    00000384 TA0CCTL1_L
    00000385 TA0CCTL1_H
    00000386 TA0CCTL2
    00000386 TA0CCTL2_L
    00000387 TA0CCTL2_H
    00000390 TA0R
    00000390 TA0R_L
    00000391 TA0R_H
    00000392 TA0CCR0
    00000392 TA0CCR0_L
    00000393 TA0CCR0_H
    00000394 TA0CCR1
    00000394 TA0CCR1_L
    00000395 TA0CCR1_H
    00000396 TA0CCR2
    00000396 TA0CCR2_L
    00000397 TA0CCR2_H
    000003a0 TA0EX0
    000003a0 TA0EX0_L
    000003a1 TA0EX0_H
    000003ae TA0IV
    000003ae TA0IV_L
    000003af TA0IV_H
    000003c0 TA1CTL
    000003c0 TA1CTL_L
    000003c1 TA1CTL_H
    000003c2 TA1CCTL0
    000003c2 TA1CCTL0_L
    000003c3 TA1CCTL0_H
    000003c4 TA1CCTL1
    000003c4 TA1CCTL1_L
    000003c5 TA1CCTL1_H
    000003c6 TA1CCTL2
    000003c6 TA1CCTL2_L
    000003c7 TA1CCTL2_H
    000003d0 TA1R
    000003d0 TA1R_L
    000003d1 TA1R_H
    000003d2 TA1CCR0
    000003d2 TA1CCR0_L
    000003d3 TA1CCR0_H
    000003d4 TA1CCR1
    000003d4 TA1CCR1_L
    000003d5 TA1CCR1_H
    000003d6 TA1CCR2
    000003d6 TA1CCR2_L
    000003d7 TA1CCR2_H
    000003e0 TA1EX0
    000003e0 TA1EX0_L
    000003e1 TA1EX0_H
    000003ee TA1IV
    000003ee TA1IV_L
    000003ef TA1IV_H
    00000400 TA2CTL
    00000400 TA2CTL_L
    00000401 TA2CTL_H
    00000402 TA2CCTL0
    00000402 TA2CCTL0_L
    00000403 TA2CCTL0_H
    00000404 TA2CCTL1
    00000404 TA2CCTL1_L
    00000405 TA2CCTL1_H
    00000406 TA2CCTL2
    00000406 TA2CCTL2_L
    00000407 TA2CCTL2_H
    00000410 TA2R
    00000410 TA2R_L
    00000411 TA2R_H
    00000412 TA2CCR0
    00000412 TA2CCR0_L
    00000413 TA2CCR0_H
    00000414 TA2CCR1
    00000414 TA2CCR1_L
    00000415 TA2CCR1_H
    00000416 TA2CCR2
    00000416 TA2CCR2_L
    00000417 TA2CCR2_H
    00000420 TA2EX0
    00000420 TA2EX0_L
    00000421 TA2EX0_H
    0000042e TA2IV
    0000042e TA2IV_L
    0000042f TA2IV_H
    00000440 TA3CTL
    00000440 TA3CTL_L
    00000441 TA3CTL_H
    00000442 TA3CCTL0
    00000442 TA3CCTL0_L
    00000443 TA3CCTL0_H
    00000444 TA3CCTL1
    00000444 TA3CCTL1_L
    00000445 TA3CCTL1_H
    00000446 TA3CCTL2
    00000446 TA3CCTL2_L
    00000447 TA3CCTL2_H
    00000450 TA3R
    00000450 TA3R_L
    00000451 TA3R_H
    00000452 TA3CCR0
    00000452 TA3CCR0_L
    00000453 TA3CCR0_H
    00000454 TA3CCR1
    00000454 TA3CCR1_L
    00000455 TA3CCR1_H
    00000456 TA3CCR2
    00000456 TA3CCR2_L
    00000457 TA3CCR2_H
    00000460 TA3EX0
    00000460 TA3EX0_L
    00000461 TA3EX0_H
    0000046e TA3IV
    0000046e TA3IV_L
    0000046f TA3IV_H
    00000480 TB0CTL
    00000480 TB0CTL_L
    00000481 TB0CTL_H
    00000482 TB0CCTL0
    00000482 TB0CCTL0_L
    00000483 TB0CCTL0_H
    00000484 TB0CCTL1
    00000484 TB0CCTL1_L
    00000485 TB0CCTL1_H
    00000486 TB0CCTL2
    00000486 TB0CCTL2_L
    00000487 TB0CCTL2_H
    00000488 TB0CCTL3
    00000488 TB0CCTL3_L
    00000489 TB0CCTL3_H
    0000048a TB0CCTL4
    0000048a TB0CCTL4_L
    0000048b TB0CCTL4_H
    0000048c TB0CCTL5
    0000048c TB0CCTL5_L
    0000048d TB0CCTL5_H
    0000048e TB0CCTL6
    0000048e TB0CCTL6_L
    0000048f TB0CCTL6_H
    00000490 TB0R
    00000490 TB0R_L
    00000491 TB0R_H
    00000492 TB0CCR0
    00000492 TB0CCR0_L
    00000493 TB0CCR0_H
    00000494 TB0CCR1
    00000494 TB0CCR1_L
    00000495 TB0CCR1_H
    00000496 TB0CCR2
    00000496 TB0CCR2_L
    00000497 TB0CCR2_H
    00000498 TB0CCR3
    00000498 TB0CCR3_L
    00000499 TB0CCR3_H
    0000049a TB0CCR4
    0000049a TB0CCR4_L
    0000049b TB0CCR4_H
    0000049c TB0CCR5
    0000049c TB0CCR5_L
    0000049d TB0CCR5_H
    0000049e TB0CCR6
    0000049e TB0CCR6_L
    0000049f TB0CCR6_H
    000004a0 TB0EX0
    000004a0 TB0EX0_L
    000004a1 TB0EX0_H
    000004ae TB0IV
    000004ae TB0IV_L
    000004af TB0IV_H
    000004c0 MPY
    000004c0 MPY_L
    000004c1 MPY_H
    000004c2 MPYS
    000004c2 MPYS_L
    000004c3 MPYS_H
    000004c4 MAC
    000004c4 MAC_L
    000004c5 MAC_H
    000004c6 MACS
    000004c6 MACS_L
    000004c7 MACS_H
    000004c8 OP2
    000004c8 OP2_L
    000004c9 OP2_H
    000004ca RESLO
    000004ca RESLO_L
    000004cb RESLO_H
    000004cc RESHI
    000004cc RESHI_L
    000004cd RESHI_H
    000004ce SUMEXT
    000004ce SUMEXT_L
    000004cf SUMEXT_H
    000004d0 MPY32L
    000004d0 MPY32L_L
    000004d1 MPY32L_H
    000004d2 MPY32H
    000004d2 MPY32H_L
    000004d3 MPY32H_H
    000004d4 MPYS32L
    000004d4 MPYS32L_L
    000004d5 MPYS32L_H
    000004d6 MPYS32H
    000004d6 MPYS32H_L
    000004d7 MPYS32H_H
    000004d8 MAC32L
    000004d8 MAC32L_L
    000004d9 MAC32L_H
    000004da MAC32H
    000004da MAC32H_L
    000004db MAC32H_H
    000004dc MACS32L
    000004dc MACS32L_L
    000004dd MACS32L_H
    000004de MACS32H
    000004de MACS32H_L
    000004df MACS32H_H
    000004e0 OP2L
    000004e0 OP2L_L
    000004e1 OP2L_H
    000004e2 OP2H
    000004e2 OP2H_L
    000004e3 OP2H_H
    000004e4 RES0
    000004e4 RES0_L
    000004e5 RES0_H
    000004e6 RES1
    000004e6 RES1_L
    000004e7 RES1_H
    000004e8 RES2
    000004e8 RES2_L
    000004e9 RES2_H
    000004ea RES3
    000004ea RES3_L
    000004eb RES3_H
    000004ec MPY32CTL0
    00000500 UCA0CTLW0
    00000502 UCA0CTLW1
    00000506 UCA0BRW
    00000506 UCA0BRW_L
    00000507 UCA0BRW_H
    00000508 UCA0MCTLW
    0000050a UCA0STATW
    0000050c UCA0RXBUF
    0000050e UCA0TXBUF
    00000510 UCA0ABCTL
    00000512 UCA0IRCTL
    0000051a UCA0IE
    0000051a UCA0IE_L
    0000051b UCA0IE_H
    0000051c UCA0IFG
    0000051c UCA0IFG_L
    0000051d UCA0IFG_H
    0000051e UCA0IV
    0000051e UCA0IV_L
    0000051f UCA0IV_H
    00000520 UCA1CTLW0
    00000522 UCA1CTLW1
    00000526 UCA1BRW
    00000526 UCA1BRW_L
    00000527 UCA1BRW_H
    00000528 UCA1MCTLW
    0000052a UCA1STATW
    0000052c UCA1RXBUF
    0000052e UCA1TXBUF
    00000530 UCA1ABCTL
    00000532 UCA1IRCTL
    0000053a UCA1IE
    0000053a UCA1IE_L
    0000053b UCA1IE_H
    0000053c UCA1IFG
    0000053c UCA1IFG_L
    0000053d UCA1IFG_H
    0000053e UCA1IV
    0000053e UCA1IV_L
    0000053f UCA1IV_H
    00000540 UCB0CTLW0
    00000542 UCB0CTLW1
    00000546 UCB0BRW
    00000546 UCB0BRW_L
    00000547 UCB0BRW_H
    00000548 UCB0STATW
    0000054a UCB0TBCNT
    0000054c UCB0RXBUF
    0000054e UCB0TXBUF
    00000554 UCB0I2COA0
    00000556 UCB0I2COA1
    00000558 UCB0I2COA2
    0000055a UCB0I2COA3
    0000055c UCB0ADDRX
    00000560 UCB0I2CSA
    0000056a UCB0IE
    0000056a UCB0IE_L
    0000056b UCB0IE_H
    0000056c UCB0IFG
    0000056c UCB0IFG_L
    0000056d UCB0IFG_H
    0000056e UCB0IV
    0000056e UCB0IV_L
    0000056f UCB0IV_H
    00000580 UCB1CTLW0
    00000582 UCB1CTLW1
    00000586 UCB1BRW
    00000586 UCB1BRW_L
    00000587 UCB1BRW_H
    00000588 UCB1STATW
    0000058a UCB1TBCNT
    0000058c UCB1RXBUF
    0000058e UCB1TXBUF
    00000594 UCB1I2COA0
    00000596 UCB1I2COA1
    00000598 UCB1I2COA2
    0000059a UCB1I2COA3
    0000059c UCB1ADDRX
    000005a0 UCB1I2CSA
    000005aa UCB1IE
    000005aa UCB1IE_L
    000005ab UCB1IE_H
    000005ac UCB1IFG
    000005ac UCB1IFG_L
    000005ad UCB1IFG_H
    000005ae UCB1IV
    000005ae UCB1IV_L
    000005af UCB1IV_H
    00000660 BAKMEM0
    00000660 BAKMEM0_L
    00000661 BAKMEM0_H
    00000662 BAKMEM1
    00000662 BAKMEM1_L
    00000663 BAKMEM1_H
    00000664 BAKMEM2
    00000664 BAKMEM2_L
    00000665 BAKMEM2_H
    00000666 BAKMEM3
    00000666 BAKMEM3_L
    00000667 BAKMEM3_H
    00000668 BAKMEM4
    00000668 BAKMEM4_L
    00000669 BAKMEM4_H
    0000066a BAKMEM5
    0000066a BAKMEM5_L
    0000066b BAKMEM5_H
    0000066c BAKMEM6
    0000066c BAKMEM6_L
    0000066d BAKMEM6_H
    0000066e BAKMEM7
    0000066e BAKMEM7_L
    0000066f BAKMEM7_H
    00000670 BAKMEM8
    00000670 BAKMEM8_L
    00000671 BAKMEM8_H
    00000672 BAKMEM9
    00000672 BAKMEM9_L
    00000673 BAKMEM9_H
    00000674 BAKMEM10
    00000674 BAKMEM10_L
    00000675 BAKMEM10_H
    00000676 BAKMEM11
    00000676 BAKMEM11_L
    00000677 BAKMEM11_H
    00000678 BAKMEM12
    00000678 BAKMEM12_L
    00000679 BAKMEM12_H
    0000067a BAKMEM13
    0000067a BAKMEM13_L
    0000067b BAKMEM13_H
    0000067c BAKMEM14
    0000067c BAKMEM14_L
    0000067d BAKMEM14_H
    0000067e BAKMEM15
    0000067e BAKMEM15_L
    0000067f BAKMEM15_H
    00000700 ADCCTL0
    00000700 ADCCTL0_L
    00000701 ADCCTL0_H
    00000702 ADCCTL1
    00000702 ADCCTL1_L
    00000703 ADCCTL1_H
    00000704 ADCCTL2
    00000704 ADCCTL2_L
    00000705 ADCCTL2_H
    00000706 ADCLO
    00000706 ADCLO_L
    00000707 ADCLO_H
    00000708 ADCHI
    00000708 ADCHI_L
    00000709 ADCHI_H
    0000070a ADCMCTL0
    0000070a ADCMCTL0_L
    0000070b ADCMCTL0_H
    00000712 ADCMEM0
    00000712 ADCMEM0_L
    00000713 ADCMEM0_H
    0000071a ADCIE
    0000071a ADCIE_L
    0000071b ADCIE_H
    0000071c ADCIFG
    0000071c ADCIFG_L
    0000071d ADCIFG_H
    0000071e ADCIV
    0000071e ADCIV_L
    0000071f ADCIV_H
    000008e0 CP0CTL0
    000008e0 CP0CTL0_L
    000008e1 CP0CTL0_H
    000008e2 CP0CTL1
    000008e2 CP0CTL1_L
    000008e3 CP0CTL1_H
    000008e6 CP0INT
    000008e6 CP0INT_L
    000008e7 CP0INT_H
    000008e8 CP0IV
    000008e8 CP0IV_L
    000008e9 CP0IV_H
    000008f0 CP0DACCTL
    000008f2 CP0DACDATA
    00000b20 CAPIE
    00000b20 CAPIE_L
    00000b21 CAPIE_H
    00000b22 CAPIFG
    00000b22 CAPIFG_L
    00000b23 CAPIFG_H
    00000b24 CAPIV
    00000b24 CAPIV_L
    00000b25 CAPIV_H
    00002000 BGXstruct
    00002162 xRegGlobal
    00002580 xRegIscDrv
    0000265c xRegTouch
    00002722 xRegLeds
    00002808 xRegAlarm
    00002862 xRegAux
    00002876 swB
    000028a0 utilDelay
    000028a8 iborra
    000028aa RXData
    000028b2 BTN00
    000028d6 BTN00_E00
    000028f4 BTN00_E01
    00002912 BTN00_E02
    00002930 BTN00_E03
    0000298e g_uiApp
    0000299e BTN00_C00
    000029a4 BTN00_C01
    000029aa BTN00_C02
    000029b0 BTN00_C03
    00003f00 _stack
    00008000 xVarFlash
    00008814 BGX_Motor
    0000cf76 CS_initFLL
    0000d6ae SetTimer
    0000e3a6 main
    0000e9c2 strncpy
    0000ec8e sprintf
    0000eefc __mpu_init
    0000ef74 memcpy
    0000efb0 sds_main
    0000efec strstr
    0000f0d4 strncmp
    0000f17a BGX_Init
    0000f1ae memccpy
    0000f1e2 sds_init
    0000f32e UTIL_Delay
    0000f4c6 CAPT_init
    0000f5e0 ArmTimer
    0000f620 PER_Init
    0000f640 memset
    0000f67e enableBLE
    0000f69c enableLeds
    0000f7b2 resetBLE
    0000f928 strcpy
    0000f93a strlen
    0000fa06 abs
    0000fa24 task_touch
    0000fa7c SIS_Init
    0000fa8e C$$EXIT
    0000fa8e abort
    0000faaa UART_ISR
    0000fc46 CAPT_ISR
    0000fc8a ADC_ISR
    0000fcc2 Timer_A
    0000fd02 WDT_ISR
    0000fd1e RTC_ISR
    0000ffc8 __TI_int19
    0000ffca __TI_int20
    0000ffcc __TI_int21
    0000ffce __TI_int22
    0000ffd0 __TI_int23
    0000ffd2 __TI_int24
    0000ffd4 __TI_int25
    0000ffd6 __TI_int26
    0000ffd8 __TI_int27
    0000ffda __TI_int28
    0000ffdc __TI_int29
    0000ffde __TI_int30
    0000ffe0 __TI_int31
    0000ffe2 __TI_int32
    0000ffe4 __TI_int33
    0000ffe6 __TI_int34
    0000ffe8 __TI_int35
    0000ffea __TI_int36
    0000ffec __TI_int37
    0000ffee __TI_int38
    0000fff0 __TI_int39
    0000fff2 __TI_int40
    0000fff4 __TI_int41
    0000fff6 __TI_int42
    0000fff8 __TI_int43
    0000fffa __TI_int44
    0000fffc __TI_int45
    ffffffff __c_args__
    [1304 symbols]
  • Hi Antonio,
    There are two section for FRAM, FRAM and FRAM2. You currently have you're code allocated to go FRAM. You should change this to FRAM2 | FRAM so that both banks will be used.
    BR,
    Leo
  • Hi Leo
    How should I changed that setting?
    Antonio
  • Hi Antonio,
    Typically this is changed in the options of your project.  If you right click on your project and select "Properties" in Code Composer, you'll get a window in which you can select Build->MSP430 Compiler->Processor Options. The Code Memory Model should be selected to say "large" instead of "small".  You'll need to "Apply and Close" before rebuilding.  This should then activate the "large code memory model" in your linker command file which should be the ">> FRAM | FRAM2" option instead of "> FRAM" option for your .text section.  (you could also modify your linker command file directly - but then it may not work as expected if you subsequently change the memory model through the project properties.)
    BR,
    Leo
  • Hi Leo
    I already checked this options and they are already as you described:
    I guess the problem is somewhere else...
  • Hi Antonio,
    Let's try modifying your linker command file directly:
    change "> FRAM" to ">> FRAM | FRAM2" in your linker command file and try rebuilding.
    BR,
    Leo
  • No luck
    I have changed:
    #ifndef __LARGE_CODE_MODEL__
    .text : {} > FRAM /* Code */
    #else
    .text : {} >> FRAM2 | FRAM /* Code */
    #endif
    to:
    #else
    #endif
    and I get same result:
    "../lnk_msp430fr2676.cmd", line 129: error #10099-D: program will not fit into available memory, or the section contains a call site that requires a trampoline that can't be generated for this section. placement with alignment fails for section "ALL_FRAM" size 0x7fc0. Available memory ranges:
    CODE size (bytes): 30136
    CONST size (bytes): 1616
    DATA size (bytes): 2779
  • Hi Antonio,
    Please also change this section to read:
    GROUP(EXECUTABLE_MEMORY)
    .text : {} /* Code */
    .text:_isr : {} /* Code ISRs */
    } >> FRAM | FRAM2
    and allocate your constants to FRAM2:
    .const : {} > FRAM2
    in both locations where the .const allocation appears.
    BR,
    Leo
  • Hi Leo
    I did the changes you suggested:
    /*} > FRAM*/
    } > FRAM | FRAM2
    #ifndef __LARGE_DATA_MODEL__
    /*.const : {} > FRAM /* /*Constant data */
    .const : {} > FRAM2 /* Constant data */
    #else
    /*.const : {} >> FRAM | FRAM2 */ /* Constant data */
    #endif
    After building project  new error message appears:
    "../lnk_msp430fr2676.cmd", line 129: error #10099-D: program will not fit into available memory, or the section contains a call site that requires a trampoline that can't be generated for this section. placement with alignment fails for section "ALL_FRAM" size 0x8030. Available memory ranges:
    FRAM size: 0x7f80 unused: 0x7f80 max hole: 0x7f80
    FRAM2 size: 0x8000 unused: 0x8000 max hole: 0x8000
    error #10010: errors encountered during linking; "FR2676_KOHLER_1_7.out" not built
    FILE: FR2676_KOHLER_1_7.out
    CODE size (bytes): 30248
  • Hi Antonio,
    Could you share your project with me?
    BR,
    Leo
  • FlashSpaceProblem.rar
    Hi Leo.
    I attach you a sample project with the problem. If you comment funciontion calll
    UTIL_FlashSizeTest();
    on main.c, the problem is solved
    Best Regards
  • Hi Leo.
    Best Regards8270.FlashSpaceProblem.rar
  • Thanks Antonio,
    I'll take a look at this later today.
    BR,
    Leo
  • Hi Antonio,
    Can you comment out this line of code in the original linker command file as shown below?
    // .text : {} /* Code */
    BR,
    Leo
  • Hi Leo
    Thanks for your answer. That solves the problem. Have a nice weekend!!!
    Antonio
