Part Number: MSP430FR5994
Other Parts Discussed in Thread: ENERGIA,
I'm trying to use launch PrintOncePerSec example from Energia RTC_B library (https://github.com/spirilis/RTC_B) on MSP430FR5994 Launch Pad, but compiler says " Your microcontroller does not contain the RTC_B peripheral".
It is very confusing because in the manual (https://www.ti.com/lit/ug/slau367p/slau367p.pdf?ts=1615895768291) on the page 690 that module is described. Please advise.
Thank you,
Misha
Full error report:
Energia: 1.8.11E23 (Windows 10), Board: "MSP-EXP430FR5994LP"
C:\Users\Administrator\Downloads\energia-1.8.10E23-windows\energia-1.8.10E23\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\Administrator\Downloads\energia-1.8.10E23-windows\energia-1.8.10E23\hardware -hardware C:\Users\Administrator\AppData\Local\Energia15\packages -tools C:\Users\Administrator\Downloads\energia-1.8.10E23-windows\energia-1.8.10E23\tools-builder -tools C:\Users\Administrator\Downloads\energia-1.8.10E23-windows\energia-1.8.10E23\hardware\tools\msp430 -tools C:\Users\Administrator\AppData\Local\Energia15\packages -built-in-libraries C:\Users\Administrator\Downloads\energia-1.8.10E23-windows\energia-1.8.10E23\libraries -libraries C:\Users\Administrator\Documents\Energia\libraries -fqbn=energia:msp430:MSP-EXP430FR5994LP -vid-pid=2047_0013 -ide-version=10811 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_776061 -warnings=all -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_800260 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.msp430-gcc.path=C:\Users\Administrator\AppData\Local\Energia15\packages\energia\tools\msp430-gcc\4.6.6 -prefs=runtime.tools.msp430-gcc-4.6.6.path=C:\Users\Administrator\AppData\Local\Energia15\packages\energia\tools\msp430-gcc\4.6.6 -prefs=runtime.tools.dslite.path=C:\Users\Administrator\AppData\Local\Energia15\packages\energia\tools\dslite\9.3.0.1863 -prefs=runtime.tools.dslite-9.3.0.1863.path=C:\Users\Administrator\AppData\Local\Energia15\packages\energia\tools\dslite\9.3.0.1863 -prefs=runtime.tools.mspdebug.path=C:\Users\Administrator\AppData\Local\Energia15\packages\energia\tools\mspdebug\0.24 -prefs=runtime.tools.mspdebug-0.24.path=C:\Users\Administrator\AppData\Local\Energia15\packages\energia\tools\mspdebug\0.24 -verbose C:\Users\Administrator\Documents\Energia\libraries\RTC_B-master\examples\PrintOncePerSec\PrintOncePerSec.ino
C:\Users\Administrator\Downloads\energia-1.8.10E23-windows\energia-1.8.10E23\arduino-builder -compile -logger=machine -hardware C:\Users\Administrator\Downloads\energia-1.8.10E23-windows\energia-1.8.10E23\hardware -hardware C:\Users\Administrator\AppData\Local\Energia15\packages -tools C:\Users\Administrator\Downloads\energia-1.8.10E23-windows\energia-1.8.10E23\tools-builder -tools C:\Users\Administrator\Downloads\energia-1.8.10E23-windows\energia-1.8.10E23\hardware\tools\msp430 -tools C:\Users\Administrator\AppData\Local\Energia15\packages -built-in-libraries C:\Users\Administrator\Downloads\energia-1.8.10E23-windows\energia-1.8.10E23\libraries -libraries C:\Users\Administrator\Documents\Energia\libraries -fqbn=energia:msp430:MSP-EXP430FR5994LP -vid-pid=2047_0013 -ide-version=10811 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_776061 -warnings=all -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_800260 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.msp430-gcc.path=C:\Users\Administrator\AppData\Local\Energia15\packages\energia\tools\msp430-gcc\4.6.6 -prefs=runtime.tools.msp430-gcc-4.6.6.path=C:\Users\Administrator\AppData\Local\Energia15\packages\energia\tools\msp430-gcc\4.6.6 -prefs=runtime.tools.dslite.path=C:\Users\Administrator\AppData\Local\Energia15\packages\energia\tools\dslite\9.3.0.1863 -prefs=runtime.tools.dslite-9.3.0.1863.path=C:\Users\Administrator\AppData\Local\Energia15\packages\energia\tools\dslite\9.3.0.1863 -prefs=runtime.tools.mspdebug.path=C:\Users\Administrator\AppData\Local\Energia15\packages\energia\tools\mspdebug\0.24 -prefs=runtime.tools.mspdebug-0.24.path=C:\Users\Administrator\AppData\Local\Energia15\packages\energia\tools\mspdebug\0.24 -verbose C:\Users\Administrator\Documents\Energia\libraries\RTC_B-master\examples\PrintOncePerSec\PrintOncePerSec.ino
Using board 'MSP-EXP430FR5994LP' from platform in folder: C:\Users\Administrator\AppData\Local\Energia15\packages\energia\hardware\msp430\1.0.7
Using core 'msp430' from platform in folder: C:\Users\Administrator\AppData\Local\Energia15\packages\energia\hardware\msp430\1.0.7
Detecting libraries used...
"C:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\tools\\msp430-gcc\\4.6.6/bin/msp430-g++" -c -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=msp430fr5994 -DF_CPU=16000000L -DARDUINO=10811 -DENERGIA=10811 -DENERGIA_MSP_EXP430FR5994LP -DENERGIA_ARCH_MSP430 "-IC:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\tools\\msp430-gcc\\4.6.6/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\hardware\\msp430\\1.0.7\\cores\\msp430" "-IC:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\hardware\\msp430\\1.0.7\\variants\\MSP-EXP430FR5994LP" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_776061\\sketch\\PrintOncePerSec.ino.cpp" -o nul
Alternatives for RTC_B.h: [RTC_B-master]
ResolveLibrary(RTC_B.h)
-> candidates: [RTC_B-master]
"C:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\tools\\msp430-gcc\\4.6.6/bin/msp430-g++" -c -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=msp430fr5994 -DF_CPU=16000000L -DARDUINO=10811 -DENERGIA=10811 -DENERGIA_MSP_EXP430FR5994LP -DENERGIA_ARCH_MSP430 "-IC:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\tools\\msp430-gcc\\4.6.6/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\hardware\\msp430\\1.0.7\\cores\\msp430" "-IC:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\hardware\\msp430\\1.0.7\\variants\\MSP-EXP430FR5994LP" "-IC:\\Users\\Administrator\\Documents\\Energia\\libraries\\RTC_B-master" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_776061\\sketch\\PrintOncePerSec.ino.cpp" -o nul
Error while detecting libraries included by C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_776061\sketch\PrintOncePerSec.ino.cpp
"C:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\tools\\msp430-gcc\\4.6.6/bin/msp430-g++" -c -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=msp430fr5994 -DF_CPU=16000000L -DARDUINO=10811 -DENERGIA=10811 -DENERGIA_MSP_EXP430FR5994LP -DENERGIA_ARCH_MSP430 "-IC:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\tools\\msp430-gcc\\4.6.6/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\hardware\\msp430\\1.0.7\\cores\\msp430" "-IC:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\hardware\\msp430\\1.0.7\\variants\\MSP-EXP430FR5994LP" "-IC:\\Users\\Administrator\\Documents\\Energia\\libraries\\RTC_B-master" "C:\\Users\\Administrator\\Documents\\Energia\\libraries\\RTC_B-master\\RTC_B.cpp" -o nul
Error while detecting libraries included by C:\Users\Administrator\Documents\Energia\libraries\RTC_B-master\RTC_B.cpp
Generating function prototypes...
"C:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\tools\\msp430-gcc\\4.6.6/bin/msp430-g++" -c -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=msp430fr5994 -DF_CPU=16000000L -DARDUINO=10811 -DENERGIA=10811 -DENERGIA_MSP_EXP430FR5994LP -DENERGIA_ARCH_MSP430 "-IC:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\tools\\msp430-gcc\\4.6.6/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\hardware\\msp430\\1.0.7\\cores\\msp430" "-IC:\\Users\\Administrator\\AppData\\Local\\Energia15\\packages\\energia\\hardware\\msp430\\1.0.7\\variants\\MSP-EXP430FR5994LP" "-IC:\\Users\\Administrator\\Documents\\Energia\\libraries\\RTC_B-master" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_776061\\sketch\\PrintOncePerSec.ino.cpp" -o "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_776061\\preproc\\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Users\Administrator\Documents\Energia\libraries\RTC_B-master\examples\PrintOncePerSec\PrintOncePerSec.ino:7:0:
C:\Users\Administrator\Documents\Energia\libraries\RTC_B-master/RTC_B.h:27:2: error: #error "Your microcontroller does not contain the RTC_B peripheral."
Multiple libraries were found for "RTC_B.h"
Used: C:\Users\Administrator\Documents\Energia\libraries\RTC_B-master
Using library RTC_B-master in folder: C:\Users\Administrator\Documents\Energia\libraries\RTC_B-master (legacy)
exit status 1
Error compiling for board MSP-EXP430FR5994LP.
