Part Number: TIDM-02003
Hi Team,
Can we ask for the design files of the 3D printable pipe used in TIDM-02003?
Thanks in advance!
Kind Regards,
Jejomar
Hi Team,
Thanks in advance!
Kind Regards,
Jejomar
Hi Jejomar,
It turns out the engineer that has that design file is out on vacation until the April 5th, so let me see if I can track this file down.
Hi Jejomar,
This is a parametric open scad file - please post this script into your open scad tool to render to stl and 3D print:
TRANSDUCER_RADIUS=8.25;//9.25;//5.1;7.5;//
PIPE_RADIUS=17;//13.4;
PIPE_LENGTH=95;//75//55
CHANNEL_WIDTH=15;//12;//7-15
CHANNEL_HEIGHT=24;
ULTRASONIC_ANGLE=35;//60
ULTRASONIC_LENGTH=90;//42;//52
union(){
difference(){
union(){
translate ([0, 0, -25])
rotate([0, 0, 0])
cylinder (h = PIPE_LENGTH, r = PIPE_RADIUS);
translate ([-(PIPE_RADIUS+9), .1, -14.9])
rotate([0, ULTRASONIC_ANGLE, 0])
cylinder (h = ULTRASONIC_LENGTH, r = TRANSDUCER_RADIUS+2);
union(){
translate ([-(CHANNEL_HEIGHT/2), -CHANNEL_WIDTH/2, -25])
rotate([0, 0, 0])
cube ([CHANNEL_HEIGHT,CHANNEL_WIDTH,PIPE_LENGTH]);
translate ([-(PIPE_RADIUS+9), 0, -15])
cylinder (h = 150, r = TRANSDUCER_RADIUS);
union(){
translate ([-(CHANNEL_HEIGHT/2), -CHANNEL_WIDTH, -15])
rotate([0, 0, 0])
cube ([CHANNEL_HEIGHT,CHANNEL_WIDTH/2,PIPE_LENGTH-20]);
translate ([-(CHANNEL_HEIGHT/2), CHANNEL_WIDTH/2, -15])
rotate([0, 0, 0])
// Laminarizing Fins Option
translate ([-(CHANNEL_HEIGHT/2), -.25, -25])
rotate([0, 0, 0])
cube ([CHANNEL_HEIGHT,.8,PIPE_LENGTH]);
translate ([-(CHANNEL_HEIGHT/2), -(CHANNEL_WIDTH/4)-.5, -25])
rotate([0, 0, 0])
translate ([-(CHANNEL_HEIGHT/2), (CHANNEL_WIDTH/4)-.25, -25])
rotate([0, 0, 0])
// Flow plates
translate ([-(CHANNEL_HEIGHT/2)-1, -CHANNEL_WIDTH/2, -25])
rotate([0, 0, 0])
cube ([1,CHANNEL_WIDTH,20]);
translate ([-(CHANNEL_HEIGHT/2)-1, -CHANNEL_WIDTH/2, 12])
rotate([0, 0, 0])
translate ([(CHANNEL_HEIGHT/2), -CHANNEL_WIDTH/2, PIPE_LENGTH-45])
rotate([0, 0, 0])
translate ([(CHANNEL_HEIGHT/2), -CHANNEL_WIDTH/2, PIPE_LENGTH-85])
rotate([0, 0, 0])
BR,
Leo
