I recently received my eZ430-Chronos dev tool (868 Mhz European version).
First of all: congratulations to you TI engineers for coming up with such brilliant dev kit.
The Chronos even tops the eZ430-F2013 kit that got me started with the eZ430. Keep up the
good work, your dev kits make you stay ahead of your competition ;-)
Now here's my problem: the Chronos watch does no seem to connect to the RF access point. I
got the software and driver to install correctly on my Windows XP System, but when I start
the eZ430-Chronos Control Center 1.0, hit the "Start Transmitter" button and put the watch
in acc/ppt/sync mode and start communication with the "down arrow" button, no data seems to
be transmitted. The green LED on the RF access point flashes periodically (3 sec. on, 3 sec.
off), the transmission icon in the watch display flashes for about 18 sec, and that's it.
Now I'm wondering whether I'm missing something really basic here or whether the RF hardware
or the driver software may be faulty.
Here's what I've checked so far:
- tried it on a different computer (everything installed smoothly, same problem)
- tried to move away from other RF sources (mobile phones, wireless thermometer etc.), problem persists
- I assume the antenna of the watch is the metal back plate, right? There is a plastic sticker there on the inside; am I right to assume that this sticker is not meant to be peeled off as there is already a small round hole in the sticker to allow a small metal spring to connect to the metal back plate of the watch?
- how can I find out if both the access point and the watch RF hardware are working correctly? How can I tell that both are the same frequency (868 Mhz)?
Any ideas what might be wrong?
Thanks and Cheers, Eckard
