  • Resolved
How to unbrick a MSP-EXP432P401R
Prodigy 50 points
Somehow I manage to brak my MSP432 eval board, I can no longer flash it using CCS or IAR tools.
MSP-EXP432P401R-LaunchPad Firmware Programmer
Programing OutOfBox_MSP432P401R.out into ......
Initializing debug probe...
Configuring Debugger (may take a few minutes on first launch)...:
Initializing Register Database...
Initializing: CS_DAP_0
Executing Startup Scripts: CS_DAP_0
Initializing: CORTEX_M4_0
Executing Startup Scripts: CORTEX_M4_0
Connecting...
Fatal: CORTEX_M4_0: Error connecting to the target: (Error -1063 @ 0x0)
Device ID is not recognized or is not supported by driver. Confirm device and de
bug probe configuration is correct, or update device driver. (Emulation package
5.1.641.0)
Failed: Failed to evaluate GEL_Connect(): Connect failed
Is there anyway to recover the board?
  • Hi Andre,
    maybe have a look here:
    Or here:
    Or here:
    Dennis
  • In reply to Dennis Eichmann:
    I was able to fix my problem, I guess we can add a 4th cause to the error @1063. In my case somehow my last download managed to lock and disable JTAG preventing any new download from happening.
    I tried to switch to CMSIS-DAP on IAR and flash and it gave me that info and suggested to do a factory reset to solve the problem. That did it.
    Thanks for the quick reply :)
  • In reply to Andre Silveira:
    hy guys i tried to do the factory reset as mentioned, but when I wanted to load the file the ccs said:
    CORTEX_M4_0: GEL: Error loading file 'C:\Users\Christoph\Downloads\2388.msp432_factory_reset.gel': function 'OnTargetConnect()' already defined
    and the status of the gel data was switched to Failed.
    Do you know how I could fix this ?
