IAR Workbench crashes
Other Parts Discussed in Thread: CC-DEBUGGER
I have the following Problem:
Everytime i clicked "Stop debugging" the IDE crashes.
I don't know if it has something to do with this : but this happens to me only  since i am programming in Assembler.
I just started developping my Code , so i start and stop debugger frequently to modify my code. and everytime i have to start the IDE again. it sucks.
N.B : i am using the Simulator at the moment.
does anybody have an idea.
  • Me too. IF I configure the project to use MSP-FET430UIF. Everytime I try to change some settings in the project, or I terminate debugging, the IDE crashes. Then When I restart it I can change the settings (and it works). But terminating the debugging still crashes the application.
  • before start debugging breakpoints in code are set or not ?
  • The behaviour is the same with both breakpoints set or not.
    More, the problem with the configuration change (i.e. you chage some settings in the project, no matter what, even a define in the c preprocessor, and press OK) causes the ide to crash only if Fet debugger is selected as a debugger.
    After the crash you restart the IDE, than you are able to change the settings only once (and save), as soon as you make another change and save it (i.e. you press OK in the settings dialog) the IDE crashes.
  • You don't specify which version of IAR you are using.
    IAR has a support site for their tools. You might want to try there as well.
  • You're right,
    my fault
    I'll surely do that, beside I'm starting to suspect the problem is with Windows itself.
    IAR Assembler for MSP430
      5.40.1 (5.40.1.50328)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\a430.exe
      24/Oct/2011 09:12:26, 2246144 bytes
    IAR C/C++ Compiler for MSP430
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\icc430.exe
      24/Oct/2011 09:18:08, 17668608 bytes
    C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\UpdateTool.exe
      21/Oct/2011 12:40:00, 45056 bytes
    IAR Library Builder
      5.2.4.16 (5.2.4.16)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\xar.exe
      06/Oct/2011 17:27:00, 148480 bytes
    IAR XLIB
      5.2.4.16 (5.2.4.16)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\xlib.exe
      06/Oct/2011 17:27:00, 548352 bytes
    IAR Universal Linker
      5.2.4.16 (5.2.4.16)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\xlink.exe
      06/Oct/2011 17:27:00, 2362368 bytes
    IAR C-SPY Batch Simulator Driver for MSP430
      5.40.1 (5.40.1.50373)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\430bat.dll
      21/Nov/2011 10:20:44, 546304 bytes
    IAR C-SPY Emulator Driver for MSP430
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\430fet.dll
      21/Nov/2011 10:10:46, 4941312 bytes
    IAR C-SPY Library Support Plug-in for MSP430
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\430libsupport.dll
      21/Nov/2011 10:20:12, 628736 bytes
    IAR C-SPY Processor Descriptor for MSP430
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\430proc.dll
      21/Nov/2011 10:22:34, 1975296 bytes
    IAR C-SPY Simulator Driver for MSP430
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\430sim.dll
      21/Nov/2011 10:23:34, 5991936 bytes
    CP210x
      1.2 (1.2.0.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\CP210xManufacturing.dll
      11/Jan/2011 08:47:10, 69632 bytes
    IAR Project File Converter for MSP430
      V3.21A/W32 (3.21.1.9)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\cwtd430.dll
      14/Jan/2010 16:21:20, 352256 bytes
    FTD2XX library
      3.01.06 (3.1.6.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\FTD2XX.dll
      11/Jan/2011 08:47:10, 81920 bytes
    HIL
      1, 2, 6, 0 (1.2.6.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\hil.dll
      21/Oct/2011 12:40:00, 32768 bytes
    SEGGER J-Link MSP430 interface DLL
      2.1.1.0 (2.1.1.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\JLink430.dll
      11/Jan/2011 08:47:10, 114688 bytes
    MSP430.dll for USB-MSP430-FPA 4v71 based on TI's ver.2.4.8.2
      2, 4, 8, 2 (2.4.8.2)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\MSP430-FPA.dll
      22/Apr/2011 20:52:42, 614400 bytes
    MSP430 Debug Tool Access Library
      3.2.2.0 (3.2.2.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\msp430.dll
      16/Nov/2011 15:40:36, 2765824 bytes
    MSP430 JTAG Interface Driver
      2.4.9.1 (2.4.9.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\MSP430v2.dll
      05/Aug/2011 12:30:20, 393216 bytes
      3.2.2.0 (3.2.2.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\MSP430v3.dll
    MSP430
      1, 0, 4, 2 (1.0.4.2)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\olimex.dll
      17/Jul/2011 17:31:16, 1163264 bytes
    SBMSP430_DLL DLL
      2, 3, 3, 3 (2.3.3.3)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\sbmsp430.dll
      11/Jan/2011 08:47:10, 262144 bytes
    SiUSBXp
      3.1 (3.1.0.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\SiUSBXp.dll
      17/May/2011 06:22:54, 90112 bytes
    MSP430
      Version (2.3.3.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\SoftBaugh.dll
      11/Jan/2011 08:47:10, 32768 bytes
    IAR Workbench Target Descriptor for MSP430
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\swtd430.dll
      21/Nov/2011 10:20:48, 1348608 bytes
    IAR Workbench Target Descriptor, Emulator, for MSP430
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\swtd430fet.dll
      21/Nov/2011 10:20:04, 827904 bytes
    IAR Workbench Target Descriptor, Simulator, for MSP430
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\bin\swtd430sim.dll
      21/Nov/2011 10:20:04, 774656 bytes
    Driver Installation Utility
      2.1 (2.1.0.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\USBXpressInstaller.exe
      18/Nov/2010 09:26:50, 290816 bytes
    C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\TIUSBFET\InstallDriver32.exe
      14/Jan/2010 16:21:40, 61440 bytes
    C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\TIUSBFET\InstallDriver64.exe
    C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\TIUSBFET\eZ430-UART\preinstalCDCTools.exe
      11/Oct/2011 14:27:18, 49152 bytes
    Driver Package Installer
      2.1 (2.1.0.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\TIUSBFET\Vista32\DPinst.exe
      14/Jan/2010 16:20:08, 552528 bytes
      2.1 (2.1.0.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\TIUSBFET\Vista64\DPinst64.exe
      14/Jan/2010 16:20:08, 1047632 bytes
      2.1 (2.1.0.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\TIUSBFET\Win7-32\DPinst.exe
      2.1 (2.1.0.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\TIUSBFET\Win7-64\DPinst64.exe
      2.1 (2.1.0.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\TIUSBFET\XP32\DPinst.exe
      2.1 (2.1.0.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\TIUSBFET\XP64\DPinst64.exe
    FTD2XX Dynamic Link Library
      3.02.02 (3.2.2.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\FTD2XX.dll
      17/May/2011 06:22:54, 199048 bytes
    FTDI USB Serial Converter Property Page Provider
      1.2.0.1 (1.2.0.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\32bit\amd64\ftbusui.dll
      16/Nov/2010 07:54:00, 108936 bytes
    FTDI VCP CoInstaller
      2.01.01.1 (2.1.1.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\32bit\amd64\ftcserco.dll
      16/Nov/2010 07:53:56, 64392 bytes
      3.02.02 (3.2.2.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\32bit\amd64\ftd2xx64.dll
      16/Nov/2010 07:54:16, 233352 bytes
    FTDI Multi-Lingual Property Page Text Library
      1, 5, 2, 1 (1.5.2.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\32bit\amd64\ftlang.dll
      16/Nov/2010 07:53:48, 214920 bytes
    FTDI Virtual COM Port Property Page Provider
      2.08.08  built by: WinDDK (2.8.8.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\32bit\amd64\ftserui2.dll
      16/Nov/2010 07:53:28, 55176 bytes
      1.2.0.1 (1.2.0.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\32bit\i386\ftbusui.dll
      16/Nov/2010 07:54:06, 105352 bytes
      2.01.01.1 (2.1.1.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\32bit\i386\ftcserco.dll
      16/Nov/2010 07:54:00, 67464 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\32bit\i386\ftlang.dll
      16/Nov/2010 07:53:54, 201096 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\32bit\i386\ftserui2.dll
      16/Nov/2010 07:53:38, 52616 bytes
      1.2.0.1 (1.2.0.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\64bit\amd64\ftbusui.dll
      2.01.01.1 (2.1.1.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\64bit\amd64\ftcserco.dll
      3.02.02 (3.2.2.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\64bit\amd64\ftd2xx64.dll
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\64bit\amd64\ftlang.dll
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\64bit\amd64\ftserui2.dll
      1.2.0.1 (1.2.0.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\64bit\i386\ftbusui.dll
      2.01.01.1 (2.1.1.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\64bit\i386\ftcserco.dll
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\64bit\i386\ftlang.dll
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\64bit\i386\ftserui2.dll
      1.2.0.1 (1.2.0.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\amd64\ftbusui.dll
      27/Jun/2011 14:37:34, 143688 bytes
    FT2232 VCP CoInstaller
      2.00.00.1 (2.0.0.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\amd64\ftcserco.dll
      27/Jun/2011 14:37:34, 51528 bytes
    FTD2XX library
      3.01.19 (3.1.19.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\amd64\ftd2xx64.dll
      27/Jun/2011 14:37:34, 330056 bytes
      1, 4, 0, 1 (1.4.0.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\amd64\ftlang.dll
      27/Jun/2011 14:37:34, 284992 bytes
      2.06.00.1  built by: WinDDK (2.6.0.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\amd64\ftserui2.dll
      27/Jun/2011 14:37:34, 55112 bytes
      1.2.0.1 (1.2.0.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\i386\ftbusui.dll
      27/Jun/2011 14:37:32, 120136 bytes
      2.00.00.1 (2.0.0.1)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\i386\ftcserco.dll
      27/Jun/2011 14:37:32, 54088 bytes
    FTD2XX library
      3.01.19 (3.1.19.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\i386\ftd2xx.dll
      27/Jun/2011 14:37:32, 206144 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\i386\ftlang.dll
      27/Jun/2011 14:37:32, 197952 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\Olimex\i386\ftserui2.dll
      27/Jun/2011 14:37:32, 52552 bytes
    WDF Coinstaller
      1.9.7600.16385 (win7_rtm.090713-1255) (1.9.7600.16385)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\TIUSBFET\Vista32\WdfCoInstaller01009.dll
      14/Jan/2010 16:20:08, 1461992 bytes
    WDF Coinstaller
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\TIUSBFET\Vista64\WdfCoInstaller01009.dll
      14/Jan/2010 16:20:06, 1721576 bytes
    WDF Coinstaller
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\TIUSBFET\Win7-32\WdfCoInstaller01009.dll
      14/Jan/2010 15:20:06, 1461992 bytes
    WDF Coinstaller
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\TIUSBFET\Win7-64\WdfCoInstaller01009.dll
      14/Jan/2010 16:20:08, 1721576 bytes
    WDF Coinstaller
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\TIUSBFET\XP32\WdfCoInstaller01009.dll
    WDF Coinstaller
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\drivers\TIUSBFET\XP64\WdfCoInstaller01009.dll
    LCD Plugin for EW430
      3.42A (3.42.1.9)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\plugins\Lcd\lcd.dll
      21/Nov/2011 10:20:42, 431104 bytes
    IAR C-SPY RTOS/CMX Plugin for ARM
      6.20.1.52589 (6.20.1.52589)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\plugins\rtos\CMX\CmxArmPlugin.dll
      28/Apr/2011 20:29:44, 776704 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\plugins\rtos\CMX\CmxArmPlugin.ENU.dll
      28/Apr/2011 20:28:48, 12800 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\plugins\rtos\CMX\CmxTinyArmPlugin.dll
      28/Apr/2011 20:29:50, 773120 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\plugins\rtos\CMX\CmxTinyArmPlugin.ENU.dll
      28/Apr/2011 20:29:02, 12800 bytes
    SEGGER embOS IAR-Plugin
      6, 0, 6, 4 (6.0.6.4)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\plugins\rtos\embOS\embOSPlugin.dll
      27/Apr/2011 21:02:30, 573952 bytes
    OpenRTOSPlugin DLL
      2, 0, 0, 0 (2.0.0.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\plugins\rtos\OpenRTOS\OpenRTOSPlugin.dll
      27/Apr/2011 21:02:32, 630272 bytes
    PowerPac RTOS Plugin
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\plugins\rtos\PowerPac\PowerPacRTOSPlugin.dll
      13/Apr/2011 15:43:26, 596480 bytes
    SafeRTOSPlugin DLL
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\plugins\rtos\SafeRTOS\SafeRTOSPlugin.dll
      27/Apr/2011 21:02:30, 640000 bytes
    µC/OS-II <= 2.86 KA Plug-in for C-SPY DLL
      2.5.0 (2.5.0.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\plugins\rtos\uCOS-II\uCOS-II-286-KA-CSpy.dll
      27/Apr/2011 21:06:00, 659968 bytes
    µC/OS-II >= 2.87 KA Plug-in for C-SPY DLL
      2.5.1 (2.5.1.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\plugins\rtos\uCOS-II\uCOS-II-KA-CSpy.dll
      27/Apr/2011 21:06:00, 665088 bytes
    PspUtil1Plugin DLL
      2.0 (2.0.0.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\plugins\simulation\PspPort1LED.psp.dll
      12/Mar/2010 10:18:04, 464384 bytes
    CSPY PspWatchdogPlugin DLL
      2.0 (2.0.0.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\430\plugins\simulation\PspWatchdogPlugin.psp.dll
      12/Mar/2010 10:16:56, 452096 bytes
    === Install subdirectory: common ===
    IAR CSpyBat
      6.3.11.2079 (6.3.11.2079)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\CSpyBat.exe
      24/Oct/2011 10:30:18, 2443264 bytes
    IAR CSpyServer
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\CSpyServer.exe
      24/Oct/2011 10:33:12, 2902528 bytes
    IAR Build Utility
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\IarBuild.exe
      24/Oct/2011 10:34:00, 128000 bytes
    IAR Embedded Workbench IDE
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\IarIdePm.exe
      24/Oct/2011 10:36:08, 867328 bytes
    IAR CSpyBat Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\CSpyBat.ENU.dll
      24/Oct/2011 10:25:00, 6144 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\CSpyBat.JPN.dll
      24/Oct/2011 10:25:02, 4608 bytes
    IAR CSpyServer Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\CSpyServer.ENU.dll
      24/Oct/2011 10:25:12, 7680 bytes
    C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\CSpyServices.dll
      24/Oct/2011 10:27:40, 1914880 bytes
    IAR C-SPY Debugger GUI
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\DebuggerGui.dll
      24/Oct/2011 10:42:10, 3836416 bytes
    IAR C-SPY Debugger GUI Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\DebuggerGui.ENU.dll
      24/Oct/2011 10:37:04, 71168 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\DebuggerGui.JPN.dll
      24/Oct/2011 10:37:02, 61952 bytes
    IAR Find In Files
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\FindInFiles.dll
      24/Oct/2011 10:37:00, 584192 bytes
    IAR Find In Files Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\FindInFiles.ENU.dll
      24/Oct/2011 10:35:44, 5120 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\FindInFiles.JPN.dll
    IAR Build Utility Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\IarBuild.ENU.dll
      24/Oct/2011 10:26:10, 3584 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\IarBuild.JPN.dll
      24/Oct/2011 10:26:10, 3072 bytes
    IAR Embedded Workbench IDE Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\IarIdePm.ENU.dll
      24/Oct/2011 10:26:08, 499200 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\IarIdePm.JPN.dll
      24/Oct/2011 10:26:06, 494592 bytes
    IAR IDE Framework
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\IdeFramework.dll
      24/Oct/2011 10:26:30, 1623552 bytes
    IAR IDE Framework Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\IdeFramework.ENU.dll
      24/Oct/2011 10:26:04, 7168 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\IdeFramework.JPN.dll
      24/Oct/2011 10:26:02, 6656 bytes
    IAR C-SPY Debugger Kernel
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\kernel.dll
      24/Oct/2011 10:41:40, 3793408 bytes
    IAR C-SPY Debugger Kernel Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\kernel.ENU.dll
      24/Oct/2011 10:39:46, 14848 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\kernel.JPN.dll
      24/Oct/2011 10:39:48, 10752 bytes
    IAR Log Window
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\LogWindow.dll
      24/Oct/2011 10:33:30, 327680 bytes
    IAR Log Window Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\LogWindow.ENU.dll
      24/Oct/2011 10:25:16, 10240 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\LogWindow.JPN.dll
      24/Oct/2011 10:25:16, 9728 bytes
    IAR Project Manager Engine
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\ProjectManagerEngine.dll
      24/Oct/2011 10:33:08, 1753600 bytes
    IAR Project Manager Engine Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\ProjectManagerEngine.ENU.dll
      24/Oct/2011 10:25:08, 13824 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\ProjectManagerEngine.JPN.dll
      24/Oct/2011 10:25:06, 9728 bytes
    IAR Project Manager Gui
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\ProjectManagerGui.dll
      24/Oct/2011 10:41:34, 1036288 bytes
    IAR Project Manager Gui Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\ProjectManagerGui.ENU.dll
      24/Oct/2011 10:25:06, 171008 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\ProjectManagerGui.JPN.dll
      24/Oct/2011 10:25:04, 161792 bytes
    IAR Text Editor
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\TextEditor.dll
      24/Oct/2011 10:37:10, 1070592 bytes
    IAR Text Editor Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\TextEditor.ENU.dll
      24/Oct/2011 10:26:00, 26112 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\TextEditor.JPN.dll
      24/Oct/2011 10:26:06, 24064 bytes
    IAR VCS Provider
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\VcsProvider.dll
      24/Oct/2011 10:26:16, 15872 bytes
    Shared Library for Xerces-C++ Version 3.1.1
      3, 1, 1 (3.1.1.0)
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\xerces-c_3_1.dll
      24/Oct/2011 09:47:52, 1887744 bytes
    IAR XmlLib
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\bin\XmlLib.dll
      24/Oct/2011 10:18:06, 85504 bytes
    IAR Code Coverage Plug-in
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\plugins\CodeCoverage\CodeCoverage.dll
      24/Oct/2011 10:35:42, 638464 bytes
    IAR Code Coverage Plug-in Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\plugins\CodeCoverage\CodeCoverage.ENU.dll
      24/Oct/2011 10:39:50, 11264 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\plugins\CodeCoverage\CodeCoverage.JPN.dll
    C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\plugins\LibSupportService\LibSupportService.dll
      24/Oct/2011 10:33:04, 2114048 bytes
    IAR LibSupport Plug-in Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\plugins\LibSupportService\LibSupportService.ENU.dll
      24/Oct/2011 10:25:18, 10752 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\plugins\LibSupportService\LibSupportService.JPN.dll
      24/Oct/2011 10:25:18, 9728 bytes
    IAR ORTI RTOS Plug-in
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\plugins\Orti\Orti.dll
      24/Oct/2011 10:32:14, 808448 bytes
    IAR ORTI RTOS Plug-in Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\plugins\Orti\Orti.ENU.dll
      24/Oct/2011 10:25:14, 9216 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\plugins\Orti\Orti.JPN.dll
      24/Oct/2011 10:25:14, 8192 bytes
    C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\plugins\ServiceCodeCoveragePlugin\ServiceCodeCoveragePlugin.dll
      24/Oct/2011 10:29:06, 1960448 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\plugins\ServiceCodeCoveragePlugin\ServiceCodeCoveragePlugin.ENU.dll
      24/Oct/2011 10:25:00, 11264 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\plugins\ServiceCodeCoveragePlugin\ServiceCodeCoveragePlugin.JPN.dll
      24/Oct/2011 10:24:58, 10752 bytes
    IAR Symbols Plug-in
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\plugins\SymList\SymList.dll
      24/Oct/2011 10:29:34, 608768 bytes
    IAR Symbols Plug-in Language Specific Resources
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\plugins\SymList\SymList.ENU.dll
      24/Oct/2011 10:25:10, 3584 bytes
      C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.0\common\plugins\SymList\SymList.JPN.dll
      24/Oct/2011 10:25:12, 3072 bytes
  • I have found a possible solution for this annoying problem.
    Go to your /Users/%username%/AppData/Local/Temp/ directory
    and delete the command.xcl file. (Maybe all of the files in that directory should be deleted.)
  • also works fine starting the application in win7 comaptibility mode
  • How does one do that? I'm running IAR Workbench in Windows 10. Thanks
  • I just found some clue in the following link and tried success!
    http://supp.iar.com/FilesPublic/UPDINFO/009938/common/doc/KnownProblems.pdf
    EW 24549
    Under certain circumstances, for example when changing Project>Options or selecting another configuration, automatic Windows 8 compatibility settings can cause problems for IAR Embedded Workbench. Error message(s) produced then contain information similar to: - Faulting application path: $EW_DIR$\common\bin\IarIdePm.exe - Faulting module path: $EW_DIR$\common\bin\kernel.dll.
    Workaround: Install another copy of your IAR Embedded Workbench product in a different location or rename the directory of your current installation.
    What I tried is renamed the folder name:
    C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.4
    to
    C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.4_
    And the crash issue is resolved!
  • This worked for me.  I was using IAR EW8051 version 8.30 fine on Win7.  With Win 10 it crashed every time I stopped cc-debugger or changed project options.
    I did not find a command.xcl file to delete as someone mentioned above.
    Also, tried Win7 compatibility without success.
    So, I installed EW8051 again.  It asked to put it in C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.5_2.  (Original is in C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.5) .   I okay'd that.
    Original continues to crash every time I stop the debugger, or do some other stuff.
    2nd install is fine so far.
    Makes no sense.
    THANK YOU!!!
  • I have the same problem.
    I found a strange registry on:
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
    that related to 430fet.dll.
    The problem was solved on my environment after deleted this registry by using regidit.
    Meni.
