Compiler/TM4C123GH6PM: Unable to initialize device!, error code=4
Part Number: TM4C123GH6PM
I cannot download to the flash.
When I try to flash download or erase from the uVision4, I get the following message:
      "Could not initialize target device. Please power cycle the board and try again."
Following is the compile message
Load "F:\\Asim\\Electrical Engineering\\Keil Projects\\uart led.axf"
Connecting: Mode=JTAG, Speed=1000000Hz
Error: Flash Download failed - Target DLL has been cancelled
What to do please help...
  • Had you (earlier) downloaded code - and (only) thereafter - received such notice?
    Mistake in the System Clock setting function - or disturbing (any) of the 4 JTAG pins (PC0-PC3) - is the (usual) cause of your difficulty.
    It may be possible for you to employ the "LM Flash Programmer" - and (unlock) your board. I must go now - you may learn the required details via the "Search function" (atop this forum - enter "Unlock the MCU.")
