SSI reading data Issue
Part Number: EK-TM4C1294XL
Hello
I have issues using SSIDataGet() and the advanced mode SSI_ADV_MODE_READ_WRITE, I try to read the manufacturer ID of FT800 but I don't know why it need send the read function many times becouse the first value is not correct.
I tried to using another GPIO (e.g. PORTJ   GPIO_PIN_2) as CS instead of Fss and the things improved a little bit but was not the solution
the FT800 ID is 0x7C and I get this values:
*** SSI_0 & UART_0 done ***
Dato8 Addr= 0x102400 Read= 0x42
Dato8 Addr= 0x102400 Read= 0x4a
Dato8 Addr= 0x102400 Read= 0x43
Dato8 Addr= 0x102400 Read= 0x7c
Please help!
- Angel Nino
I share the code.
SSI configure function
void ConfigureSSI(void)
     MAP_SysCtlPeripheralReset (SYSCTL_PERIPH_GPIOA);
     MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
     MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI0);
     MAP_GPIOPinConfigure(GPIO_PA2_SSI0CLK);	//SCK
     MAP_GPIOPinConfigure(GPIO_PA3_SSI0FSS);	//CS
     MAP_GPIOPinConfigure(GPIO_PA4_SSI0XDAT0);	//Tx (MOSI)
     MAP_GPIOPinConfigure(GPIO_PA5_SSI0XDAT1);	//RX (MISO)
     MAP_GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_5 | GPIO_PIN_4 | GPIO_PIN_3 | GPIO_PIN_2);
     MAP_SSIConfigSetExpClk(SSI0_BASE, 120000000, SSI_FRF_MOTO_MODE_0, SSI_MODE_MASTER, 8000000, 8);
     MAP_SSIAdvModeSet(SSI0_BASE, SSI_ADV_MODE_READ_WRITE);
     MAP_SSIAdvFrameHoldEnable(SSI0_BASE);
     MAP_SSIEnable(SSI0_BASE);
write and read functions
void ft800cmd_Write(unsigned char ftCommand)
//    GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_CS, 0);              	// Set chip select low
//    while(SSIDataGetNonBlocking(SSI0_BASE, &pui32DataRx));
    SSIDataPut(SSI0_BASE, ftCommand);                           	// Send command
    SSIDataPut(SSI0_BASE, 0x00);                                	// Send first filler byte
    SSIAdvDataPutFrameEnd(SSI0_BASE, 0x00);                         // Send second filler byte
//    while(SSIBusy(SSI0_BASE));
//    GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_CS, GPIO_PIN_CS);    	// Set chip select high
unsigned char ft800mem_Read8(unsigned long ftAddress)
    unsigned char ftData8 = 0;                                  	// Place-holder for 8-bits being read
    unsigned char cTempAddr[3];                                 	// FT800 Memory Address
    unsigned char cZeroFill = ZERO;
    cTempAddr[2] = (char) (ftAddress >> 16) | MEM_READ;        		// Compose the command and address to send
    cTempAddr[1] = (char) (ftAddress >> 8);                     	// middle byte
    cTempAddr[0] = (char) (ftAddress);                          	// low byte
    SSIDataPut(SSI0_BASE, cTempAddr[2]);                 	   		// Send Memory Write plus high address byte
    SSIDataPut(SSI0_BASE, cTempAddr[1]);
    SSIDataPut(SSI0_BASE, cTempAddr[0]);
    SSIAdvDataPutFrameEnd(SSI0_BASE, cZeroFill);                	// Send dummy byte
    SSIDataGet(SSI0_BASE, &ftData8);                        		// Receive data byte
  return ftData8;                                               	// Return 8-bits
unsigned int ft800mem_Read16(unsigned long ftAddress)
    unsigned int ftData16 = 0;                                  	// 16-bits to return
    unsigned char cTempData[2];                                 	// Place-holder for 16-bits being read
    SSIDataGet(SSI0_BASE, &cTempData[0]); 				    		// Receive data byte
    SSIDataGet(SSI0_BASE, &cTempData[1]);
    ftData16 = (cTempData[1]<< 8) |                             	// Compose value to return - high byte
                       (cTempData[0]);                          	// low byte
  return ftData16;                                          		// Return 16-bits
main function
int main(void)
	int value;
	unsigned char ft800Gpio;
    MAP_SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |
                    		SYSCTL_OSC_MAIN | SYSCTL_USE_PLL |
							SYSCTL_CFG_VCO_480), 120000000);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOJ);
    GPIOPinTypeGPIOInput(GPIO_PORTJ_BASE, GPIO_PIN_0 | GPIO_PIN_1);
    GPIOPadConfigSet(GPIO_PORTJ_BASE, GPIO_PIN_0, GPIO_STRENGTH_2MA, GPIO_PIN_TYPE_STD_WPU);         //enable pin for SW_1 and pull_up
    GPIOPadConfigSet(GPIO_PORTJ_BASE, GPIO_PIN_1, GPIO_STRENGTH_2MA, GPIO_PIN_TYPE_STD_WPU);         //enable pin for SW_1 and pull_up
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPION);
    GPIOPinTypeGPIOInput(GPIO_PORTN_BASE, GPIO_PIN_INT);
    GPIOPinTypeGPIOOutput(GPIO_PORTN_BASE, GPIO_PIN_PD | GPIO_PIN_CS | GPIO_PIN_1 | GPIO_PIN_0); 	 //enable pines for LED_2 and LED_1
    ConfigureSSI();
    ConfigureUART();
    UARTprintf("*** SSI_0 & UART_0 done ***\n");
    GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_PD, GPIO_PIN_PD);                    // Initial state of PD_N - high
    GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_CS, GPIO_PIN_CS);                    // Initial state of SPI CS - high
    MAP_SysCtlDelay((120000000 * 0.02) / 3);									// delay 20ms
    ft800cmd_Write(FT800_ACTIVE);                                               // Start FT800
    while(1)
      if((GPIOPinRead(GPIO_PORTJ_BASE, GPIO_PIN_0) & GPIO_PIN_0) == 0)
          SysCtlDelay((120000000 * 0.15) / 3);
          if (value == 0)
           unsigned char dato8 = ft800mem_Read8(REG_ID); // REG_GPIO, REG_GPIO_DIR, REG_ID, ROM_CHIPID
           UARTprintf("Dato8  Addr= 0x%x\tRead= 0x%x\n", REG_ID, dato8);
           value = 1;
      else if((GPIOPinRead(GPIO_PORTJ_BASE, GPIO_PIN_1) & GPIO_PIN_1) == 0)
          if (value == 0)
              unsigned int dato16 = ft800mem_Read16(REG_PLAYBACK_FREQ); // REG_CMD_READ, REG_CMD_WRITE
              UARTprintf("Dato16 Addr= 0x%x\tRead= 0x%x\n", REG_PLAYBACK_FREQ, dato16);
              value = 1;
      else
          value = 0;
  • using the PORTJ  GPIO_PIN_2 as CS I got the follow:
    Dato16 Addr= 0x1024b0 Read= 0x4a7c
    Dato16 Addr= 0x1024b0 Read= 0x4a40
    the things improved a little but it needs to send the read function twice.
    changes that I made:
    SSI configure funtion
    //     MAP_GPIOPinConfigure(GPIO_PA3_SSI0FSS);	//CS
         MAP_GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_5 | GPIO_PIN_4 | GPIO_PIN_2); //| GPIO_PIN_3
    //     MAP_SSIAdvModeSet(SSI0_BASE, SSI_ADV_MODE_READ_WRITE);
    //     MAP_SSIAdvFrameHoldEnable(SSI0_BASE);
    read function
        SSIDataPut(SSI0_BASE, cZeroFill);                    			// Send dummy byte
    //    SSIAdvDataPutFrameEnd(SSI0_BASE, cZeroFill);
    oscilloscope signals using CS
    1st read
    2nd read
    The SPI interface is, from hardware point of  view , a ring shifting register - what is in master is transferred to slave and vice-versa. But, the first byte sent, the command, is not processed or known until fully saved into internal buffer, so after that is parsed (decoded) and starting  with the second byte, you may have a wanted result.
    In other words, from software point of view, the first received byte is dummy and should be trashed and the second and followings could make a good result. The data sheet of your device specify the number of dummy bytes to be escaped/trashed before the good result. (IIRC that document is one of application notes specified by you in previous thread). So read the documentation again.
    Also, IIRC, your device need the last address byte to be sent first - little endian system - so after parsing the address into bytes you must start sending them from index 0, not 2. Am I correct?
  • Hello Petrei
    thanks for you response, really it helped me a lot.
    I didn't understand that part in the document, it is necessary make a flush operation Amit said, becouse the master sends a byte and the slave answers. the address bytes and the dummy byte answer a data trash after, the slave gives the good bytes, is it correct?
    and the document mention "send the MSB first" but the order of bytes is [2] first, [1] second, [0] last. So, I made the necessary changes in my functions and it works awesome! Using the Fss pin or any pin as CS it works very well, now I'm able to write and read any register
    thank you so much
    - Angel Nino
    sharing my SSI configuration:
         MAP_GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_5 | GPIO_PIN_4 | GPIO_PIN_3 | GPIO_PIN_2); //
    // Read 32 bits
    void ft800mem_Write32(unsigned long ftAddress, unsigned long ftData32) { unsigned char cTempAddr[3]; // FT800 Memory Address unsigned char cTempData[4]; // 32-bit data to write cTempAddr[2] = (char) (ftAddress >> 16) | MEM_WRITE; // Compose the command and address to send cTempAddr[1] = (char) (ftAddress >> 8); // middle byte cTempAddr[0] = (char) (ftAddress); // low byte cTempData[3] = (char) (ftData32 >> 24); // Compose data to be sent - high byte cTempData[2] = (char) (ftData32 >> 16); // cTempData[1] = (char) (ftData32 >> 8); // cTempData[0] = (char) (ftData32); // low byte // GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_CS, 0); // Set chip select low while(SSIDataGetNonBlocking(SSI0_BASE, &pui32DataRx)); SSIDataPut(SSI0_BASE, cTempAddr[2]); // Send Memory Write plus high address byte SSIDataPut(SSI0_BASE, cTempAddr[1]); SSIDataPut(SSI0_BASE, cTempAddr[0]); SSIDataPut(SSI0_BASE, cTempData[0]); // Send data byte SSIDataPut(SSI0_BASE, cTempData[1]); SSIDataPut(SSI0_BASE, cTempData[2]); // SSIDataPut(SSI0_BASE, cTempData[3]); SSIAdvDataPutFrameEnd(SSI0_BASE, cTempData[3]); // while(SSIBusy(SSI0_BASE)); // GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_CS, GPIO_PIN_CS); // Set chip select high }
  • Hello Angel
    Advanced modes work differently from Legacy mode for the QSPI peripheral. In advanced mode the CS control is also handled by the peripheral and depending on whether you use the Advanced write or Advanced read-write operation, the requirement of flushing the RXFIFO may not or may be required.
  • Hello Amit
    seems what in this case was necessary if I understood the correct using from advanced mode, I hope to be correct. I'll continue make more probes.
    (comment: I'm practicing my english too, if I have any bad expression or incorrect word please tell me)
    Thank you
    -Angel Nino
  • Hello Angel
    You can refer to use model of the QSPI in the following TI Design
    www.ti.com/.../TIDM-TM4C129SDRAMNVM
    Where it is interfaced to a Serial Flash interface.
  • sharing my read function:
    //    SSIDataPut(SSI0_BASE, cZeroFill);
        SSIDataGet(SSI0_BASE, &pui32DataRx);
    -Angel Nino
  • Hello Angel
    Please see the reference code for Advanced mode use. The above pasted code is not the correct model for advanced mode.
