- I'm using DRV8328A variant wondering how to manage DT using this part? Should it be set using DT pin or by Gate resistor?
I'm using IAUC120N06S5N011 mosfet and gate resistor value comes to 8Ohm(8.06Ohm part available). Is it okay to skip gate resistors in case the DT is set via DT pin? - Can nFault be pulled up at MCU side with 10K at 3.3V?
- We do not want to use VDSLVL. Should it be tied to GND or left open?
- Should nSleep also be pulled up with 10K resistor to 3.3V?
Thank you!
