We are using DRV8711 at 48VDC and up to 6.5A setpper.
We found about 700-800 mV spikes on ISENSEx pins (see waveform and schematic below).
Is it safety or not?
I am sorry, it was measuring fault.
It was BISENP signal respect to ground. Ground position was good, but probe ground wire path made a loop (far from probe). When I twisted probe ground wire around the probe, spike voltage became less than 400 mV. Time is about 20 nS. Differential signal has no spikes.
Thank you for your idea.
I have no output capacitors. The whole schematic is:
