I am working on a 2KW resonant powersupply based on the UCC25600 controller. When using the calculation spreadsheet SLUC146 for this design something weird happens.
When entering the design, the ratio Lm/Lr ( in the sheet called "m" ) is entered as a design parameter, just like expected. However when I choose Lm/Lr as 5, and look at the component values, the resulting Lm/Lr has a very different value.
I calculated the powertrain components also by using an other calculating methode, and ran some simulations in spice to check the results, this is close to what I expect.
Looking at the SLUC146 sheet, the basic values like transformer ratio, Qmin and Lr are more or less identical, however the magnetising inductance Lm resulting from the spreadsheet is roughly a factor 2 too low.
regards
Geert de Vries
Duran Audio BV
What is going wrong??2844.2k9.xls
