TPS2493: PSpice for Ti - Wrong PG polarity
Part Number: TPS2493
Other Parts Discussed in Thread: BQ25730, TPS1663, TPS25982,
  Further to this 2 year old post: https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/777227/tina-spice-tps2492-have-you-corrected-the-tps2492-broken-model-yet?tisearch=e2e-sitesearch&keymatch=TPS2493#
  I believe a similar mistake has been made somewhere. If you simulate this part in PSpice for Ti (in a very simple configuration) you will find the PG polarity is opposite to that described in the datasheet:
(please note upward edge on teal trace in lower right)
This is mirrored in fault conditions, with ~PG going low approximately 9ms after fault goes low.
i will test this on an actual chip but am concerned about this discrepancy.
Paul
