Hi Team,
Please comfirm TPS562201 snuber circuit(R92;C82;R94;C100),
Cause when programming the code in mcu,
TPS562201 have EMC issue to influences system stable.
Hi Team,
Hi Kevin,
R92,C82,R94 value is reasonable, C100 is feedforward capacitor which is used to improve loop stability, have no effect on EMI issues.
Could you capture SW pin waveforms to see the amplitude of ring?
Jiandong
Hi Kevin,
Sorry for missed your attached analysis report. From report, customer has solved this issue by adding snubber circuit. Snubber circuit values seems reasonable from my side. Are there any other concerns from customer?
Jiandong
Hi Kevin,
As there are no reply from you for days, I'll close this thread.
Jiandong
