Other Parts Discussed in Thread: TPS61022
Hi Team,
Due to the high side switch has body diode, even the device is disable, we still have the voltage on the Output pin which is same as Vin pin.
The customer is asking that what is the maximum current that can be drawn from Vout when the device is disable. Thank you.
Mike
