Part Number: UC1825B-SP
Other Parts Discussed in Thread: TPS7H5001-SP, UC1843B-SP
Is there any Buck application note?
Hey Benjamin,
There is no buck application note for the UC1825B-SP.
Do you have approximate specifications for the topology?
Depending on efficiency requirements/schedule our TPS7H5001-SP may be a better option.
Daniel
Thank you, Daniel.
Here is my connection example. Please let me know if this is ok.
Ben
Hey Benjamin,
The design you show is using a different part than the one you listed.
That is why I questioned if it the correct design.
The design it self is somewhat confusing, because the ramp signal generated into the ISENSE pin can likely get above the 1 V threshold of the pin which seems undesirable when you are trying to force the COMP pin.
Daniel
