Part Number: TPS23753A
Hi Darwin san
I have new question.
I know several spec of TPS23753A.
1.What is the maximum Ivc value?
2.What is the minimum Dvc value?
I can not find in datasheet.
I refer this datasheet:
Thank you for your strong support.
Hi Darwin san
1. The current on VC is an input current to the IC -- a sink current. If you are planning to power other circuits with the VC current (optocoupler for example), then the limit actually comes from the transformer auxiliary winding. This information is in the transformer datasheet.
During startup, this is the maximum current draw of the Ivc:
2. Dvc is a diode on the Vc line. This rectifies the transformer auxiliary voltage for the IC. It is not a switching diode, so we do not need to worry about small reverse recovery time or small capacitance. We just have to have the correct voltage and current ratings. I would use the diode in the EVM as a baseline.
Let me know if you have any other questions!
If this post answers your question, please indicate so by marking this thread as resolved. Thank you.
Michael P.
Applications Engineer
Texas Instruments
Hello Michael san
Thank you for your quick reply.
I have summarized the problems, so please give me some advice.
Attach the file.Summar of Issue _25-Aug-2021.xlsx
Can you send me a full schematic?
Michael P.
Texas Instruments
Hello Michael san
Thank you for your support.
I send the schematic data.(our schematic and reference schematic)
Hello Ohkawa san,
Thank you for providing schematic. I focus on the circuit on VC.
I am curious, does the design damage if there is a large current on VC? Additionally, something interesting is that this does not happen on every board. Could that be different Betas for different BJT's? Can you test this?
To me, it makes sense as we decrease the zener diode voltage it decreased voltage on the base of the NPN resistor so the current flow is less. I just wonder if now there is not enough current for VC or too low of a voltage? What is the voltage on VC with the lower zener diode? I reviewed other buck designs, and if there is a circuit like this, the zener is 11V-12V.
Michael P.
Texas Instruments
こんにちはマイケルさん
ご支援いただきありがとうございます。
> VCに大電流が流れると、設計が損傷しますか?
->はい、実際に壊れています。Q1が過負荷になったので壊れたと思います。
>それは異なるBJTの異なるベータである可能性がありますか?
->申し訳ありませんが、意味がわかりません ので、改めてご説明ください。
>下部ツェナーダイオードを使用したVCの電圧はいくつですか?
->ツェナー電圧が9.4vの場合、Vc電圧は7.5vです。
ツェナー電圧が9.8vの場合、Vc電圧は7.9vです。
この現象の発生率は4%です。
Please tell me if you have any concerns.
Regards.
Hello Michael san
->Yes, actually broken. I think overloads Q1.
->Sorry I can't understand meaning. Please explain again.
->When the zener voltage is 9.4v, the Vc voltage is 7.5v.
When the zener voltage is 9.8v, the Vc voltage is 7.9v.
This is a 4% incidence.
Regards.
Okay thank you for the information.
Do you notice if the issue follows the BJT, if you try moving a BJT to a different board?
Hello Michael san
Already tried.
Result, the phenomenon does not move.
Example:
When PWB=A & BJT(Q1)=A, Vc is 5mA
When PWB=B & BJT(Q1)=B, Vc is 40mA
PWB=A & BJT(Q1)=B -> Vc is 5mA
PWB=B & BJT(Q1)=A -> Vc is 40mA
Thank you for confirming, must not be the BJT then. I will check with the original designer on this phenomenon. For now, will the 10V diode work?
I think an issue with lower voltage diode could be that VC voltage is not above 9V UVLO rising threshold.
Michael P.
Texas Instruments
Hello Michael san
I can not arrange 10.0V but I can 10.2V, so I try 10.2V but do not work. In this time, the Vc voltage is 8.3v.
Is the IC the cause of this phenomenon?
Regards.
Oh okay understood. No I do not think it is the IC, but there is a minimum VC threshold we must meet at ~9V.
I talked with circuit designer and these are his suggestions for debug:
Michael P.
Texas Instruments
Hello Michael san
Thank you for your supports.
I try the suggested debug 1 & 2 this weekend. Please wait a few days. And I will report results.
Regards.
Thank you, let us know the results.
Michael P.
Texas Instruments
Hello Michael san
I tried 1 & 2 debug.
Please refer to attached excel file(Sheet1).
Regards.
Summar of Issue _03-Sep-2021.xlsx
Thank you for the reply. I am OOO today, but I can review these materials on 9/7. Thank you!
So i see we tried the experiment with an external supply, and that did not change the VCC current. However, are we observing any damage with this circuit?
Michael P.
Texas Instruments
Thank you, let us know if device is damaging.
Michael P.
Texas Instruments
Hello Michael san
Sorry too late my reply.
I checked circuit, but there was no damage.
And I tried, please refer to Sheet2 of attached file.
What do you think of this phenomenon?
And I would like to know following, please let me know.
-Maximum current rating of Vc.
Regards.
Hello Michael san
I made a mistake in the description.
I replaced U1(IC), not Q1.
Attach the modified file.
Summar of Issue _13-Sep-2021-2.xlsx
Regards.
I do find that very interesting that the different IC's have different currents. I wonder if we need to submit a request for quality control? I will contact that team and get their opinion.
However, if the design is not damaging, but works with 12V zener, do we still want to pursue issue?
Michael P.
Texas Instruments
Hello Michael san
I would like to hear from the quality team, but is it costly?
I think the Vc current of 46mA (for example No.22) is a large current.
From the results, I think this phenomenon is caused by the IC(U1).
The first thing I want to solve is to know the tolerance of Vc current(Maximum rating).
(How about specifications?)
Is the Vc current 20mA OK?
Is the Vc current 30mA OK?
Is the Vc current 46mA OK?
Next,
If 46mA(example) is abnormal, I want to know if the IC is damaged.
If normal, I will consider changing Q1.
Regards.
So i do not think that the IC is damaged and probably will not be. But we expect that the BJT is damaging from thermal/high current.
I talked with quality and they will not look at the issue since there is no damage to our part. I will check with another power expert for his opinion on this matter.
Michael P.
Texas Instruments
Hello Michael san
Thank you for your big supports.
I will wait your(another power expert) comments.
Regards.
hello,
i am in discussion, and we wanted to know, does the IC experience any heating if there is a large VC current?
Additionally, is VC connected to anything else? Is it driving any optocuplers?
Michael P.
Texas Instruments
Hello Michael san
->Yes, the higher the current, the higher the heat of the IC.
->No, It is as the circuit diagram I sent before.
Regards.
Okay thank you very much. And another question, does VC stay regulated? when the IC is hot, is the VC voltage stable?
Hello Michael san
->Yes, voltage is stable.
Regards.
Thank you for your answer, let me circle back with the team. Thank you
Michael P.
Texas Instruments
Hello Michael san
I would like to know the tolerance of Vc current(Maximum rating).
Because redesign the Q1 or D1 and other device.
Regards.
after reviewing the design with internal services, we believe that it could be a quality issue. I am going to work with your local sales representative to move this issue forward internally, we will move the conversation to email.
if you could mark the thread resolved that would be appreciated, thank you.
Michael Pahl
Hello Michael san
Thank you for your strong supports.
I understand and will tell the factory this information.
