During the learning process of making a golden file, can the Scale factor be set to 1, and after the golden file is made, change the Scale factor to a higher number (in our case 4 because of the high discharge rate).
Or is it recommended that for the learning process we use the Scale factor that will be set in the end product?
*It's implied that all the data flash values with current and capacity will be changed when changing the Scale factor
Thanks!
