BQ25886: How to program temperature window
Part Number: BQ25886
The data sheet says
"Temperature Qualification Voltage – Connect a negative temperature coefficient thermistor. Program temperature window with a resistor divider from REGN to TS to GND. Charge suspends when TS pin is out of range. Recommend 103AT-2 thermistor."
I already have a 2-cell battery with a set thermistor and operating temp range. How do I set this range using the divider at S1?
