BQ76952: Charge MOSFET failing when charging cutoff by BMS
Part Number: BQ76952
Our BMS uses BQ76952, the discharge MOSFET's behavior is good when discharge FET is turned OFF during short circuit event. Now, we are facing issue with charge MOSFET turn OFF when COV is triggered (Interrupting a current of 25A), the charge MOSFET keeps on failing (Discharge MOSFET doesn't fail).
Please let me know what can be the cause, the charger we are using is a simple CC-CV charger which might produce some overvoltage when the BMS suddenly cuts off the charging current. I can send you the schematic on personal message if needed.
