What is the input bias current for out pin of this IC?
Was not able to find in data-sheet.
I am not sure I understand your question, since the OUT pin for this device is actually the Drain of the Pass FET of the LDO and hence wouldn't be associated with an 'Input Bias Current'. Are you looking for leakage current coming out of the OUT pin under no load condition? If so, since the device does not have an external FB pin, we can expect no leakage current to flow out of OUT pin when no load is applied. Thanks!
Srikanth
