TPS54229E: Replace TPS54229 with TPS54229E
Part Number: TPS54229E
Other Parts Discussed in Thread: TPS54229
Hello team,
Our customer is planning to replace TPS54229DDAR for delivery issue, and assumed if TPS54229E could be considered as an alternative.
As far as I saw the datasheet, it seemed fine, but could you confirm if there are any characteristic differences?
Also, is it OK to think that this IC will automatically transition to ECO mode without any configuration or external circuit required?
Ryotaro Fukui
  • Hi  Fukui
    Amod is looking into this and will feedback to you soon.
    BR
    Ruby
  • Yep, TPS54229E can be considered alternate part for TPS54229. Only difference is the eco-mode operation which does not require any external circuit or special configuration to work. IC will automatically transition from PWM to PFM and vice versa due to this eco-mode feature.
    Amod
  • Hi Amod,
    Sorry for the late reply.
    I'm glad to hear that no external circuit or special configuration needed to replace.
    Now that the customer is satisfied, I want to declare this case closed.
    Thank you for your help.
    Ryotaro Fukui
