As mentioned our product uses removable cylindrical batteries and the PCM will be mounted on the carrier board PCB. In this case, we need the system to wake up immediately after inserting the battery. Couldn't find any IC part number mentioned in the datasheet with UV_SHUT disabled. Is it possible to disable the shutdown feature by any method? A default pull down on the pack+ pin is enough for this? Please suggest.
