Part Number: BQ25120F3A
Other Parts Discussed in Thread: BQ25120
Does datasheet have explain about MR function detail?
I have read "9.3.23 Manual Reset Timer and Reset Output ( MR and RESET)", but can't understand the time sequence.
If I pull MR pin to low, it enter to Hi-Z mode, right?
How do I leave the Hi-Z mode?
Need set any register or pull what pin to active the BQ25120? I can't use I2C command to BQ25120 after I pull MR pin to low.
Thanks!
Jeff
